EcoFlow DELTA mini + 110W Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
€1,338.00
Sale
€1,338.00
Regular price
€1,438.00
Sold out
per
As low as $88/mo or 0% APR.
Number of Solar Panels
  • 1
  • 2
  • 3
View cart
Our lightest DELTA It’s power you can pick up, take along, and stow away for wherever a wall outlet isn’t handy.
Power bigger electronics DELTA mini’s output of 1400W handles 90% of electronics. X-Boost that number to 2200W and suddenly your toaster oven, table saw, and hairdryer become battery-powered.
All at once Power up to 9 devices with a generous array of wall-style outlets, USB outlets, and DC outlets.
Fully charged in 1.6 hours With X-Stream on, DELTA mini charges 3 to 4 times faster than other portable power stations. Faster charging means less downtime and more do-time.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
Bring along DELTA mini and keep your devices powered at all times. DELTA mini's 882Wh capacity is perfect for power outages, outdoor adventures, and professional work.
Big Capacity
Portable
Power multiple devices
300W Max Solar Input
Pint-sized Powerhouse
More possibilities open up when you bring along 1400W for up to 9 devices. Whether it's professional gear or the comforts of home, it's good to know you're good to go.
Charge Faster
DELTA mini snags up to 300W from solar panels for a full recharge in 3 to 6 hours. It can also go from 0-100% in 1.6 hours when charging from the wall.
Smarter with the App
The EcoFlow app shows how much solar you're bringing in and how many watts your slow cooker and mini-fridge are pulling. Connect it to the internet and control it from anywhere.
Specs of DELTA Mini
Approximately 11 kg
Dimension
37.0 × 18.3 × 23.6 cm (14.9 × 7.2 × 9.4 in)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
2 x 110W panels : 5-10 hrs
3 x 110W panels : 3.3-6.6 hrs
882Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
UL2743 CE WEEE ROHS UKCA RCM GOST
AC Charge Input (Power)
X-Stream Fast Charge 900W max
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-75V 13A Max, 300W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x2)
Pure Sine Wave, 1400W total (surge 2100W), 230V~ (50Hz)
2200W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x1)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x1)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Wi-Fi
Supported
Specs of 110W Solar Panel
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
6 kg (Solar Panel 4 kg)
12 months
Rated power
110W (±5W)
Efficiency
22%–23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack.
