EcoFlow RIVER Pro + 110W Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
€1,477.00
Sale
€1,477.00
Regular price
€1,477.00
Sold out
per
As low as $88/mo or 0% APR.
Socket
  • EU (Compatible with EU sockets only)
Number of Solar Panels
  • 1
  • 2
View cart
2 x AC OUTLETS, 600W OUTPUT AND 720Wh CAPACITY The RIVER Pro can power up to 9 devices simultaneously with multiple outlet options, including 2 pure sine wave AC outlets. It offers up to 720Wh power and it weighs just 7.6kg, which makes it a portable power source for adventure on the go.
RECHARGE FROM 0-80% WITHIN 1 HOUR The patented EcoFlow X-Stream technology enables you to charge the RIVER Pro from 0%-80%  within one hour and offers a full charge in just 1.6 hours from an AC outlet.
FAST SOLAR PANEL RECHARGING: The RIVER Pro can be fully recharged from the solar panel in 9-18 hours when using one EF 110W Solar Panel depending on sunlight conditions. The EcoFlow RIVER MPPT Controller ensures a fast-solar panel recharge rate using Open Circuit Voltage: 10-25V/ 12A max, 200W max input. An Solar to XT60 Solar Cable is included.
DOUBLE CAPACITY FROM 720Wh to 1440Wh Add a RIVER Pro Extra Battery to double the capacity from 720Wh to 1440Wh. This is ideal for situations like traveling, camping, or group outdoor activities where you need more power for more devices.
POWER A WIDE RANGE OF APPLIANCES The RIVER Pro can power some devices up to 1800W with the X-Boost mode on, which lets you power about 80% of some devices like kitchen appliances and DIY tools. Use devices below 1200W for the best product use.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you’ll need.
So Much More Sun
Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow's 110W Solar Panel to a RIVER Pro portable power station.
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Net Weight *
16.8 lbs (7.6kg)
Dimensions *
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Charger)
9-18 Hours (Using 1x 110W Solar Panel)
4-8 Hours (Using 2x 110W Solar Panels, in parallel)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
