EcoFlow RIVER + 110W Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
€1,077.00
Sale
€1,077.00
Regular price
€1,077.00
Sold out
per
As low as $88/mo or 0% APR.
Version
  • EU (Compatible with EU sockets only)
Number of Solar Panels
  • 1
  • 2
View cart
Compact and portable, EcoFlow RIVER is an ideal recreational power
which gives you accessibility to handy wall outlets. EcoFlow RIVER is the perfect companion for camping, overlanding, tailgating, boating, etc.
  •  2 x AC OUTLETS, 600W OUTPUT AND 288Wh CAPACITY
  • RECHARGE FROM 0% TO 80% WITHIN 1 HOUR
  • COMPATIBLE WITH 80% HOME APPLIANCES
  • OPTION TO DOUBLE CAPACITY FROM 288Wh TO 576Wh WITH EXTRA BATTERY
Stay off the grid with EcoFlow 110W Solar Panel Charger. Made up of efficient monocrystalline silicon cells,  it can recharge DELTA and your electric devices, and keep your equipment running without interruption when connected to our portable power station.
  • COMPATIBLE WITH MOST SOLAR GENERATORS
  • HIGH CONVERSION EFFICIENCY
  • FOLDABLE KICKSTAND PROTECTION CASE
  • DURABLE, DUST & WATER RESISTANT
    Customer reviews
    4.0 563 Reviews
    • 5 star
      75%
    • 4 star
      60%
    • 3 star
      10%
    • 2 star
      8%
    • 1 star
      1%
    Reliable warranty
    Free shipping
    The centerpiece of your adventure
    Power up to 9 devices at once with all the ports you’ll need. Sporting a 288Wh capacity, you’ll have enough juice to charge your phone 21 times, triple your drone’s charge, or make 12 cups of coffee with a coffee maker. Just don’t drink them all at once
    So Much More Sun
    Premium monocrystalline silicon cells provide a high conversion efficiency of 21-22%. Recharge even faster by chaining multiple panels in a series or in parallel.
    Better Together
    Recharge freely and naturally when you link EcoFlow's 110W Solar Panel to a RIVER portable
    Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
    Yes. RIVER can power devices up to 1200W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1200W, however, it’s best to test before use. Some 600W-1200W appliances with strict voltage requirements may not function (eg. air compressors).
    Yes. You can control RIVER using your phone. Just connect to the EcoFlow app to control from afar. Here’s how: Step 1: Make sure the EcoFlow App is connected to RIVER. Step 2: Make sure RIVER is on. Step 3: Make sure your device’s WiFi is turned on Step 4: Find your device in the app. Then, you can start controlling your RIVER remotely.
    RIVER supports entry-level UPS functionality. Make sure to perform multiple tests to confirm compatibility before connecting devices such as data servers and workstations with RIVER.
    Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
    Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
    Net Weight *
    11 lbs (5kg)
    Dimension *
    11.3 x 7.3 x 7.7 in (28.8 x 18.5 x 19.4 cm)
    Charge Temperature
    32 to 113°F ± 5°F (0 to 45°C ± 3°C)
    Discharge Temperature
    -4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
    24 months
    Charge Method
    AC Wall Outlet, 12V Car Adaptor, Solar Panel
    Full Recharge Time
    1.6 Hours (AC) 3 Hours (12V Car Charger)
    3-6 Hours (Using 1x 110W Solar Panel)
    1.6-3 Hours (Using 2x 110W Solar Panels, in parallel)
    288Wh - 576Wh (With RIVER Extra Battery)
    Cell Chemistry
    Lithium-ion
    500 Cycles to 80%+ capacity
    Management Systems
    BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
    Testing and certification
    UL Standard CE FCC RoHS RCM
    AC Charge Input Power
    X-Stream Charge 250W max/500W Max (With RIVER Extra Battery)
    AC Charge Input Voltage
    220-240Vac(50Hz/60Hz)
    Solar Charge Input
    200W 10-25V DC 12A max
    Car Charger
    12V DC 8A max
    AC Output (x2)
    600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
    USB-A Output (x2)
    5V DC,2.4A,12W Max, per port
    USB-A Fast Charge (x1)
    5V/2.4A,9V/2A,12V/1.5A 18W Max
    USB-C Output (x1)
    5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
    Car Power Output (x1)
    136W, 13.6V DC, 10A Max
    DC5521 Output (x2)
    13.6V DC, 3A Max, per port
