EcoFlow WAVE 3 Portable Air Conditioner | EcoFlow EU – EcoFlow Europe EcoFlow WAVE 3 Portable Air Conditioner | EcoFlow EU - WAVE 3 + WAVE 3 Add-on Battery + 400W Portable Solar Panel - EcoFlow Europe
EcoFlow Europe
€2.348,00
Regular price €2.348,00
Sale price €2.348,00 Regular price €2.448,00
Save up to €200
Save €100 with the Early Bird Deal.
1. Exceptional cooling and heating: 6100 BTU cooling and 6800 BTU heating capacity for all-season comfort.
2. Wireless and portable: Enjoy up to 8 hours of wireless, on-the-go use.
3. Fast cooling: Drops temperatures fast—in just 15 minutes.
4. Hassle-free installation: Insulated Exhaust Duct fits diverse outdoor setups with ease.
5. Smart app control: One-tap operation from your phone.
6. Multiple charging options: Stay powered with multiple charge options for non-stop comfort.
7. 2-Year Warranty.
EcoFlow WAVE 3 Add-on Battery
€699,00
1024Wh | LFP
€2.348,00 €2.448,00 -€100,00
Why EcoFlow WAVE 3 Stands Out
Built for Every Scenario
Car
Camping
Tent
Camping
RV
Adventures
Outdoor Fun
Indoor Spaces
Semi-Trucks
Boating
Rapid cooling and heating
6100 BTU cooling power & 6800 BTU heating power
Drop 8°C/15℉ in just 15 minutes¹
with 6100 BTU power, setting an ideal environment for any scenario. Quickly warm up with 6800 BTU heating, raising the temperature by 9°C/17°F in just 15 minutes ², perfect for staying cosy during chilly outdoor activities like autumn camping.
8 Hours of Wireless Comfort
1024Wh LFP Add-On Battery*
The add-on battery offers up to 8 hours of uninterrupted use³—perfect for a full night of restful sleep. High-quality LFP cells ensure a lifespan of up to 10 years in daily use.
*The EcoFlow WAVE 3 Add-On Battery is sold separately.
It's All on the App
Powered by EcoFlow OASIS
Easily manage everything from real-time battery status to water drain notifications, mode changes, and scheduled shutdowns—all from your phone, no matter where you are.
Intelligent Modes for Maximum Comfort
Automatic
Function
Pet
Care
Dehumidification
Function
Sleep Mode
Water Drain Alert
Automatically switches to heating when temperatures drop, keeping you cozy even on chilly mountain camping trips, ensuring a good night's sleep.
Set a temperature range of 35-45°C via the app to protect your pet from heatstroke indoors. Once the set temperature is exceeded, WAVE 3 automatically starts cooling and sends you an app notification.
Adjusts humidity to your desired level, so you can stay comfortable, even during rainy seasons.
Operates at just 44 dB, about the same as a quiet conversation, ensuring peaceful rest.
When the water tank nears full, the app sends a reminder to drain it, ensuring optimal performance.
Endless Cooling On the Go
Fast charging in just 75 min
By combining AC charging and solar charging, the Add-On Battery can be fully charged in as fast as 75 minutes. With the EcoFlow Alternator Charger, you can charge while driving—1 hour of driving, and stay comfortable all night.
(400W)
(400W/800W)
AC Charging
(700W)
Car Power Outlet
(100W)
Fully charged in 3 hours. Charging port: XT60 on the Add-On Battery.
Charge while driving. In 102 minutes, you're ready to go. Charging port: Both WAVE 3 and Add-On Battery (not recommended to use WAVE 3 directly due to unstable power).
Fully charged in 2 hours. Charging port: XT150 on WAVE 3 and Add-On Battery.
Emergency charging in 10 hours. Charging port: XT60 on the Add-On Battery.
Keep Cool While Protecting the Planet
EcoFlow's use of R290 refrigerant reduces pollution compared to traditional refrigerants and protect the planet. Over 10 years, it cuts CO2 emissions by up to 4500 lb, the equivalent of saving 130 trees from being cut down.
See What's New
What's in the Box - EcoFlow WAVE 3
EcoFlow WAVE 3
EcoFlow WAVE 3
Exhaust Duct Adapter Covers (A, B, C)
Drain Pipe
Drain Pipe
Winder
Winder
Duct Size Template
Duct Size Template
Safety Instructions, Quick Start Guide, Warranty Card
What's in the Box - EcoFlow WAVE 3 Add-On Battery
Add-On Battery Cable
Car Charging Cable
Car Charging Cable
What should I do after receiving the WAVE 3?
1.Check the packaging for damage. Open the box and verify all components are included.
2.Plug the device into a shore power outlet, turn it on, connect it to Wi-Fi via the EcoFlow app, and update the firmware.⚠️ Keep WAVE 3 plugged in during updates to avoid failures!
Firmware Update Tips
1.Always keep WAVE 3 connected to power during updates. Unstable power may cause failures or damage.
2.If an update fails due to power issues:Reconnect to power and retry.Contact support if the problem persists.
Usage Guidelines
1.Keep the WAVE 3 away from dust or debris to prevent strange noises.
2.Avoid direct sunlight – it reduces cooling efficiency.
3.Place the WAVE 3 flat on the ground to avoid water leakage.
How to Move the Device Safely
1.Drain all water before moving (use the drainage button).
2.Never tilt or flip the device – it may break internal parts.
3.Check battery connections if attached.
4.Turn off the device before moving.
5.Total weight ≈55 lbs (25 kg) – Don’t move it alone!
How to Drain Water Properly
1.Hold the Drainage Button for 3 seconds to start auto-draining.After draining, remove the tube and tilt the device backward slightly to remove leftover water.
WAVE 3 Power Sources
1.Shore power outlet
2.EcoFlow WAVE 2/3 Add-on Battery (XT150 port)
3.EcoFlow portable power stations (XT150 port)
How to Charge the Add-on Battery
1.Car charger (XT60 port)
2.Solar panel (XT60 port)
Can the Add-on Battery Charge Other Devices?
Yes!
USB-A: Up to 18W
USB-C: Up to 140W
How Long to Fully Charge the Battery?
Car charger (12V/96W): ~16.2 hrs
Car charger (24V/192W): ~7.3 hrs
Solar (ideal conditions): ~3.6 hrs
Actual time may vary based on usage.
Is the Battery Waterproof?
Yes! IP65 rating – protects against dust and water splashes.
Battery Lifespan
Retains ≥80% capacity after 4,000 charge cycles.
Battery Material
LFP (Lithium Iron Phosphate) – safer and longer-lasting.
WAVE 3 Won’t Turn On – How to Fix?
1.Check power connection:Plug it into a shore power outlet first. If it starts, the battery was fully drained.
2.Low battery discharging limit:If the battery is below the discharging limit, plug it in to charge.Optional: Set the discharging limit to 0% in settings. This gives you 1 extra minute of runtime before shutdown.
3.Future improvement:A firmware update will soon improve low-battery handling for smoother operation.Still stuck? Contact support for help! 😊
Specs - EcoFlow WAVE 3
Approximately 15.6 kg (34.4 lb)
519×297×336 mm
(20.4×11.7×13.2 in)
Cooling Capacity
1800W (6100BTU)
Heating Capacity
2000W (6800BTU)
Temperature Setting Range
16-30℃ (60.8-86℉)
Refrigerant/Amount
R290/112 g (R290/0.25 lb)
Air Volume
330m³/h
Rated Cooling Power (AC/DC)
690W/640W
645W/606W
Cooling Efficiency (AC/DC)
2.6/2.8
Heating Efficiency (AC/DC)
3.1/3.3
AC Input
100-240V~50/60 Hz,
820W Max
Add-on Battery Input
700W Max
Operating Temperature
5-50℃ (41-122℉)
IP Rating
IPX4
Noise Level
44-58 dB
Remote Control
App (Wi-Fi(2.4G, 5G), Bluetooth)
Run Time with EcoFlow Add-On Battery
2-8 hr
Specs - EcoFlow WAVE 3 Add-On Battery
Approximately 9.7 kg (21.4 lb )
516×281×111 mm
(20.3×11.1×4.4 in)
Battery Capacity
1024Wh 51.2V 20Ah
80%+ capacity after 4000 cycles
Maximum Input Power
1000W Max
Automobile Auxiliary Power Outlet Charging Input
12V/24V,8A Max, 200W Max
Solar Input
11-60V,13A Max, 400W Max
Maximum Output Power
858W Max
5/9/12V, 2.4/2/1.5A, 18W Max
5/9/12/15V⎓3A Max;
20V/28V⎓5A Max, 140W Max
Charge Temperature
0-45℃ (32-113℉)
Discharge Temperature
-10-50℃ (14-122℉)
IP Rating
IP65
WAVE 3 Compatibility
WAVE 3 Add-On Battery Compatibility
Set Up EcoFlow WAVE 3 in Minutes
Disclaimers:
[1] Tested in a 10 cubic meter space at 60°F/15℃. Performance may vary with room size and temperature.
[2] Tested in a 10 cubic meter space at 60°F/15℃. Results may differ depending on conditions.
[3] 8 hours of wireless use in Eco Mode under optimal conditions. Battery life may vary based on usage and environment.
EcoFlow WAVE 3 & GLACIER Classic Launch Campaign Terms & Conditions
Campaign Duration
The EcoFlow WAVE 3 & GLACIER Classic Launch Campaign runs from 25 April 2025, 9 AM (CET) to 30 July 2025, 9 AM (CET). EcoFlow reserves the right to modify or extend the campaign period at its sole discretion without prior notice.
Eligibility
The campaign is open to European citizens aged 18 and above as of 25 April 2025, 9:00 AM (CET).
Availability
This campaign, including promotions, gifts, and discounts, is available exclusively on eu.ecoflow.com. Purchases made on other platforms or websites are not eligible for campaign offers.
Campaign Details
  1. By providing your email address and subscribing, you agree to the Email Marketing Terms & Conditions, subscribe to EcoFlow marketing emails, and consent to receive updates from EcoFlow.
  2. Save €100 with the Early Bird Deal based on the Manufacturer's Suggested Retail Price (MSRP):
a.EcoFlow WAVE 3 will launch on 12 May 2025 at 9 AM (CET). EcoFlow GLACIER Classic will be launched on 29 May 2025, 9 AM (CET). The Early Bird Deal is only valid during the first month of launch. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
b. Products eligible for the Early Bird Deal*:
  • EcoFlow WAVE 3 + WAVE 3 Add-on Battery (Save €100 based on MSRP when purchased as a bundle)
  • EcoFlow GLACIER Classic 35L + Plug-in Battery (Save €100 based on MSRP when purchased as a bundle)
  • EcoFlow GLACIER Classic 45L + Plug-in Battery (Save €100 based on MSRP when purchased as a bundle)
  • EcoFlow GLACIER Classic 55L + Plug-in Battery (Save €100 based on MSRP when purchased as a bundle)
  • EcoFlow WAVE 3 (Save €100 based on MSRP)
  • EcoFlow GLACIER Classic 35L (Save €100 based on MSRP)
  • EcoFlow GLACIER Classic 45L (Save €100 based on MSRP)
  • EcoFlow GLACIER Classic 55L (Save €100 based on MSRP)
    * This product list is for reference purposes only. Please refer to the product pages of EcoFlow WAVE 3 and EcoFlow GLACIER Classic on eu.ecoflow.com for accurate and up-to-date details.
    c. All Early Bird Deal offers are subject to availability. Once stock runs out, the offer will no longer be available.
    d. Unless otherwise stated, the Early Bird Deal cannot be used with any other offers or promotions running on our website.
e. The products eligible for the Early Bird Deal are not eligible for 30-day price match offers.
f. Refurbished products are not eligible for this event.
General:
1. If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
2. To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion.
3. Participants in the Sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
4. All orders must comply with EcoFlow's purchase agreement and return policy during the sale promotion.
5. The sale promotion does not apply to wholesale or distributor orders.
6. Any unauthorised or fraudulent behaviour will result in the disqualification of participants.
7. Participants must comply with all applicable laws and regulations.
8. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
9. All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
10. EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
11. EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including participants, in connection with or arising from any acts or omissions, or in any way related to this campaign.
12. Participants agree to release and discharge EcoFlow from any liabilities and claims, including breach of contract, tort, negligence, or any other cause of action at law or equity, arising out of or in any way connected to this campaign or the participant's entry into the campaign.
13. All products and free gifts (if applicable) related to this promotion will be shipped in accordance with EcoFlow's Shipping Policy (https://eu.ecoflow.com/policies/shipping-policy)
14. There may be instances where EcoFlow is unable to accept or must cancel certain orders. EcoFlow reserves the right, at its sole discretion, to refuse or cancel any order for any reason. In such cases, EcoFlow is not responsible for any inaccuracies, errors, or potential consequences arising from the cancellation.
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
