EcoFlow STREAM Ultra/Pro | EcoFlow Europe
EcoFlow Europe
Starting at €47/payment over 12 payments with 0% APR from Alma. Learn more
Pice Guarantee
EcoFlow STREAM Ultra/Pro/Max
Regular price €564.00
Sale price €564.00 Regular price €1,099.00
Save up to €2,256.00
Days
Hours
Minutes
Seconds
Autumn Sale × EcoCredits Week: Earn Up to 2.5× EcoCredits!
Learn More>>
• Slash up to €1,109 off your electricity bills
• Effortless DIY setup—no electrician required
• Fully compatible with EcoFlow STREAM series
• AI‑driven monitoring and control via the EcoFlow app
• Seamlessly integrates with over 99% of solar panels on the market
Stay Tuned!
€564.00 €1,099.00 -€535.00
All-in-One Hybrid System
The smart core of the EcoFlow STREAM Plug & Play Power Plant — combining energy storage and a built-in microinverter in one seamless solution.
How Does It Work to Drive Your Energy Bills to 0?
As the morning sun rises, EcoFlow STREAM Ultra instantly captures solar energy for your home, storing any surplus automatically. At night, this stored power runs your appliances, directly or through the grid. Generating up to 2,218kWh annually, it meets 71.3% of household needs, cutting electricity bills to almost zero¹.
Dual-mode 2800W solar input
EcoFlow STREAM Ultra features a 4-MPPT design, supporting up to 2,000W solar input. It also works with third-party microinverters; connecting to the solar battery adds 800W more. Maximises power generation from every sunlit area.
2300W AC output
Run two appliances independently via dual AC outlets, with 1,200W output per battery and auto-boost up to 2,300W (on-grid) . Pair with another STREAM Ultra or STREAM AC Pro for full 2,300W AC output (on-grid). The built-in battery ensures off-grid use and backup during outages.
One Step Closer To 0 Bills
Build Your Home Solar Plant Around EcoFlow STREAM Ultra
Big or Small, Power It All
Go “Bills to 0” with 3 smart setups. From lights and routers to fridges and kettles, the EcoFlow STREAM Series powers appliance up to 2,300W (on-grid) — all powered by the sun.
2300W
2000W
1200W
Parallel Mode Up to 2,300W Solar Coverage
  • Device Setup: 1 × STREAM Ultra + 1 × STREAM Ultra or STREAM AC Pro
  • Connect two units with a parallel cable to power high-wattage appliances like ovens and dishwashers — all powered by solar.
  • Output:1,200W (main) + 1,100W (secondary) = 2,300W total output
Distributed ModeUp to 2,000W Solar Coverage
  • No cable required — simply plug each unit into separate wall sockets. Solar powers up to 2,000W, with support for up to 2,300W total output when needed.
  • Output: 1,200W (main) + 800W (secondary) + 300W (grid) = 2,300W total output
Single Unit Mode Up to 1,200W Solar Coverage
  • Device Setup:1 × STREAM Ultra
  • One unit powers your everyday essentials — ideal for running TVs, cookers, fans, and more with ease.
  • Output:1,200W from a single battery
Power Goes Where Appliances Live
Appliances are spread across your home. Your batteries should be too. That’s how you reach Bills to 0.
Longer Runtime with Scalable Capacity and Solar Input
EcoFlow STREAM Ultra offers flexible DIY solar storage & PV input expansion — solar storage expansion from 1.92kWh to 11.52kWh³ , and PV input expansion from 2kW(4 MPPT) to 12kW (24 MPPT), with up to 6 connected units. Easily pair two units to double your capacity or integrate with EcoFlow DELTA Series batteries for even greater storage.
Power That Flows Where It’s Needed
The AI-powered system monitors all connected devices in real time, ensuring each unit receives enough solar energy to run your appliances. If the EcoFlow STREAM AC Pro in your kitchen runs low, AI-driven load balancing automatically redirects energy from nearby units—keeping your fridge running on solar without interruption.
Don't Let Clouds or Dusk Limit Your Solar Power
The STREAM Battery uses advanced low-light technology to capture energy from even muted skies, delivering up to one extra hour of solar harvest each day compared to industry averages.
More Savings, Fewer Calculations—Through Software⁴
Boost Your Savings with the TOU Model and Solar Forecasting⁵
Time‑of‑Use (TOU)  Dynamic Electricity Pricing
Charge when prices are low, supply when prices are high.
AI-TOU model offers you the optimal bill-saving strategy every 60 minutes, based on the analysis of tariff data from Nord Pool, Epex Spot, Rabot Energy, Octopus, and more.
High Accuracy Solar Forecasts, Maximize Your Savings All Year Round⁶
Powered by Solcast's world-leading solar and weather forecasting, processing over 100 million forecasts per hour—including geolocation, satellite imagery, historical data, and TMYs (Typical Meteorological Years) —to deliver real-time insights and savings.
Smart Meter × Smart Plug: Zero Feed-in. All Solar, All Yours⁷
EcoFlow works with leading smart energy brands like Shelly, Tibber, and more, managing your home's power with the Smart Meter, Smart Plugs, and the EcoFlow app. Automatically run appliances like your sprinkler, e-bike, or ventilation using surplus solar. Let every ray of sunshine stay yours.
EcoFlow AI Assistant: No Math. Just Savings.⁸
Your AI Assistant simplifies energy management by doing the hard work for you—analyzing data, spotting inefficiencies, and giving clear, actionable recommendations. No calculations, no guesswork—just smart, easy decisions.
Protecting Your Privacy, Always.
EcoFlow protects your data using top-level security measures certified by global standards including TRUSTe, NIST, ISO, and more.
Safety You Can Trust
Long-Lasting Power with LFP Technology
Equipped with advanced LFP battery cells, STREAM delivers up to 6,000 deep cycles with 70% capacity retention — lasting up to 3× longer than traditional batteries. That means up to 15 years of reliable use, backed by a 10-year warranty.
Silent Operation — as Low as 30 dB
Experience whisper-quiet performance with noise levels as low as 30 dB.The advanced self-cooling design dissipates heat efficiently — no disruptive fan noise, just silent, reliable power.
Ready For Any Weather
How to Install
EcoFlow STREAM Pro
EcoFlow STREAM Max
1.92kWh
1.92kWh
1.92kWh
1.92kWh
1.92kWh
1.92kWh
4
3
2
4
3
2
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
2000W (500W × 4)
1500W (500W × 3)
1000W (500W × 2)
1050W
1050W
1050W
1050W
1050W
1050W
Yes
Yes
No
Yes
Yes
No
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
2300W (10A)
23.1kg
22.8kg
22.0kg
23.1kg
22.8kg
22.0kg
284mm x 255mm x 458mm
What's in the box - STREAM Ultra
STREAM Ultra × 800W
STREAM Ultra × 800W
STREAM Solar Panel Extension Cable (2.95m) × 8
STREAM AC Cable (1.5m) × 1
PV Wrench × 1
PV Wrench × 1
Mounting Bracket × 1
Locking Bracket × 1
Locking Bracket × 1
Safety Instructions × 1
Installation Guide × 1
Warranty Card × 1
Warranty Card × 1
What's in the box - STREAM Pro
STREAM Pro × 800W
STREAM Pro × 800W
STREAM Solar Panel Extension Cable (2.95m) × 6
PV Wrench × 1
PV Wrench × 1
Locking Bracket × 1
Locking Bracket × 1
Warranty Card × 1
Warranty Card × 1
What's in the box - STREAM Max
STREAM Max × 800W
STREAM Max × 800W
STREAM Solar Panel Extension Cable (2.95m) × 4
PV Wrench × 1
PV Wrench × 1
Locking Bracket × 1
Locking Bracket × 1
Warranty Card × 1
Warranty Card × 1
Specs - STREAM Ultra
1.92kWh
6000 cycles
AC Charging Input
1050W
1200W
MPPT
4
PV Input Power
2000W (500W × 4)
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
23.1kg
Acoustic Noise
<30 dB
10-Year
Specs - STREAM Pro
1.92kWh
6000 cycles
AC Charging Input
1050W
1200W
MPPT
3
PV Input Power
1500W (500W × 3)
AC Output-Grid Tied
800W
AC Charging Input
10A
2300W (10A)
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
22.8kg
Acoustic Noise
<30 dB
10-Year
Specs - STREAM Max
1.92kWh
6000 cycles
AC Charging Input
1050W
1200W
MPPT
2
PV Input Power
1000W(500W*2)
AC Output-Grid Tied
800W
AC Charging Input
10A
2300W (10A)
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
22.0kg
Acoustic Noise
<30 dB
10-Year
The system can be self-installed and maintained. However, in the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
How does the system continue to supply power during a blackout?
For safety and compliance reasons, the STREAM system will automatically detect a grid anomaly and stop feeding current into the grid during a power outage. You can then plug in your appliances directly into the AC outlets to use internal battery or solar power.
Each MPPT of the STREAM Ultra/Pro has a maximum power of 500W. Can I connect solar panels with more than 500W to each port?
Yes, as long as the solar panel meets the conditions of operating voltage (15-60V) and operating current (≤14A). This can optimize solar utilization during low sunlight conditions.
1. EcoFlow STREAM Ultra delivers 2,218kWh of solar energy annually, achieving 71.3% coverage of Germany's average household consumption (3,113kWh/year) through 24/7 solar power supply. Based on the electricity rate of €0.40/kWh, this system provides annual savings of €887. Actual savings may vary depending on usage behavior and regional energy pricing.
Source:https://pvwatts.nrel.gov/pvwatts.php
2. The installation time is based on test results from the EcoFlow Lab. Actual installation time may vary depending on system configuration and real-world conditions.
3. The maximum capacity is 6 units, expandable up to 11.52kWh with the EcoFlow STREAM Ultra or EcoFlow STREAM AC Pro.
4. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
5. The calculation is an estimate based on 10 kWh/day electricity consumption in Munich, Germany (representing Central Europe), using STREAM series products (6kWh batteries and 2800W PV). It is simulated by AI, factoring in fluctuations in electricity prices and usage for a closer reflection of real-world conditions. Actual results may vary depending on local conditions.
6. The EcoFlow app integrates weather data from Solcast, running over 100 million data operations per hour to deliver forecasts with up to 94% accuracy and horizons of up to three days. (https://solcast.com/)
7. After installing STREAM Series battery and compatible Smart Meter, users can connect appliances to wall outlets via compatible Smart Plugs, enabling remote on/off control and operation scheduling through the EcoFlow app—thereby minimizing solar energy waste.
8. Actual EcoFlow app functionality may vary; the screens shown are for illustrative purposes only.
Thanks for subscribing!
4. Upload the Image
