EcoFlow DELTA 3 Series Solar Generator (PV400W) – EcoFlow Europe
EcoFlow Europe
Starting at €112,33/payment over 12 payments with 0% APR from Alma. Learn more
Pice Guarantee
Regular price €1.348,00
Sale price €1.348,00 Regular price €1.548,00
Save up to €250
  • Expandable capacity: 1-5kWh expandable capacity to fit your energy storage needs. Ideal for home use, RVing, outdoors or even everyday use.
  • Huge AC output: With X-Boost mode get up to 2400W output power to run 99% of home appliances.
  • PV input: DELTA 3 Plus with 1000W PV input and DELTA 3 with 500W PV input
  • Capture more energy: 99% MPPT efficiency to maximize solar generation anytime.
  • Smart energy management: Customized in-app energy management to prioritize solar or AC charging, view input/output power, battery levels, and more.
Model
Accessories
€1.348 €1.548 -€200
Our 400W portable solar panel offers high solar output, conversion efficiency, and a convenient folding design, making it ready to grab and go at any time. Pair two 400W portable solar panels with your DELTA 3 Plus, which supports up to 1000W solar input, to ensure you’re fully powered up, no matter where your adventures take you.
Charge Faster, Wherever You Go
A single solar panel with a unique folding design, our 400W solar panel combines powerful energy production with portability. To achieve a higher solar conversion efficiency of up to 23%, we use multi-busbar monocrystalline cells, giving you even more energy to recharge your portable power.
Built to Weather the Storm
Our 400W portable solar panel can keep collecting energy even during a downpour. With a protective ETFE film and a high IP68 resistance level, the solar cells can withstand environments from humid and wet to dry and dusty.
What's in the Box
What's in the Box
What's in the Box
DELTA 3
DELTA 3 Plus
Specs - DELTA 3 & DELTA 3 Plus
Colour/ID
DELTA 3 - Silver & Grey
DELTA 3 Plus - Silver
1024Wh
≤12.5 kg
398×200×284 mm
D3 EB Dimensions
398×200×198 mm 15.8 L
App
Y (TOU/Storm warning)
Extra Battery
Expandable capacity to 5.5kWh
DELTA 2 Max/DELTA 2/DELTA Pro 3/DELTA 3 Extra Battery Supported
Total Output Ports
11
AC × 4
4 × 1800W (Surge 3600W)
2400W
USB-A × 2 (Fast charging)
DELTA 3 - 2 × 18W Max
DELTA 3 Plus - 2 × 36W Max
USB-A × 2
USB-C × 2
DELTA 3 - 2 × 100W Max
DELTA 3 Plus - 2 × 140W Max
Car Power × 1
12.6V, 10A, 126W Max
DC5521 × 2
2 × 12.6V, 3A Max
AC
1500W (56 Min)
Solar
DELTA 3 - DC input 11V-60V 1 × 500W Max (130 Min)
DELTA 3 Plus - DC input 11V-60V 2 × 500W Max (70 Min)
Smart Generator charging
1500W (56 Min)
Car charging
800W (1.3 Hr with Alternator Charger)
AC+PV
1500W (56 Min)
Chemistry
DELTA 3 - 4000 Cycles to 80% Capacity
DELTA 3 Plus - 4000 Cycles to 80%
Waterproof level of battery pack
IP65
UPS
DELTA 3 - <10 ms
DELTA 3 Plus - <10 ms HID
Volume
600W <30 dB/1200W <40 dB
5 Years
Specs - 400W Portable Solar Panel
Rated Power
400 W
Cell Type
Monocrystalline silicon
Efficiency
22.60%
24 months
41.7*93.1*0.98 in (105.8*236.5*2.5cm)
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight (Solar Panel)
Approx. 16 kg
Weight (with Kickstand Case)
Approx. 19 kg
Thanks for subscribing!
4. Upload the Image
