EcoFlow DELTA Max + Smart Generator – EcoFlow Europe EcoFlow DELTA Max + Smart Generator - 1600 - EcoFlow Europe
EcoFlow Europe
€3.398,00
Write a review
Regular price €3.398,00
Sale price €3.398,00 Regular price €3.398,00
-€0
Home emergency power: DELTA Max expands up to 6kWh with smart extra batteries, keeping your home powered on in any emergency.
Rapid dual charging: Charge up from 0-80% in 1 hour. Or get up to 3600W speeds by combining AC charging and the EcoFlow Smart Generator.
Power multiple devices: Looking for something to power heavy-duty devices like your fridge and dryer? With X-Boost, DELTA Max handles devices up to 3000W with ease.
Smart Generator: Connecting DELTA Pro/DELTA Max to Smart Generator to charge up during extended blackouts.
DELTA Max version
€3.398,00
When disasters strike, such as extended blackouts and severe storms, everyone needs a last-standing power supply to stay safe. The EcoFlow Smart Generator serves as an emergency option that integrates with your DELTA Pro or DELTA Max.
Emergency Backup
App control
More efficient
LCD display
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Built for any emergency.
Compared to a traditional gas generator, the EcoFlow Smart Generator offers better fuel efficiency and less energy loss when you charge DELTA Pro or DELTA Max. It achieves this by directly charging your portable power station through a simple and efficient DC charging process.
Charge and power devices at the same time.
In emergencies, sometimes things don’t go to plan. Not only does the EcoFlow Smart Generator give you last-standing emergency power, it also features an AC output to power other devices while recharging your unit with an extra battery.
Control and monitor your DELTA Max and Smart Generator with the EcoFlow app. Dive into the settings to customize your power use or control DELTA Max remotely.
What's in the bundle - DELTA Max
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
What's in the bundle - Smart Generator
1.Smart Generator 2.Extra Battery Connection Cable 3.Oil Funnel 4.Screwdriver 5.Spark Plug Socket 6.Breaker Bar 7.Double-Ended Spanner 8.User Manual and Warranty Card
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use solar connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
The EcoFlow Smart Generator is smarter than traditional generators. It works with the EcoFlow app so that you can control & monitor from afar. It features an LCD screen for when you’re nearby & you can even pre-define an auto-start when your power station depletes to a certain level.
The Smart Generator charges your power station directly with DC, unlike other generators. This leads to an approx. 10% increased efficiency, saving you time and money.
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC)
21 Hours (12V Car Charger)
1.8 Hours (Smart Generator)
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC)
16.8 Hours (12V Car Charger)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Specs of Generator
Dimension
59.7*29.6*47.5cm / 23.5*11.7*18.7 in
Weight
29.3 kg / 64.6 lbs
Type
Inverter generator
Frequency
50Hz
Rated Power
1800W (1900W peak)
DC Output Voltage
42-58.8V
DC Current
32A Max
Specs of Engine
Model
R80-i
Type
Single cylinder, four-stroke, forced-air cooling, overhead value
Displacement
79.7cc
Fuel type
Unleaded fuel
Fuel Tank Capacity
4 L / 1.06 gal.
Engine Oil Capacity
0.38 L / 0.1 gal.
Noise Level (at a 7m distance)
56~67dB (full load)
Continuous Working Time
3.5 hrs (full load)
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Up to €900 Off Plus Free Gifts During the Autumn Sale
Sign up for emails to get updates on Autumn Sale deals and unlock a surprise.
Discover EcoFlow Autumn Sale
Thank you for signing up!
Autumn Sale updates and surprises will be on their way to you soon.
