Starting at €7,49/payment over 12 payments with 0% APR from Alma. Learn more
You May Also Like
Multi-Functional Fast Charging for Everyday Convenience
Specs - EcoFlow RAPID Power Bank (25,000mAh, 170W)
Total Cell Capacity
25000mAh
Battery Capacity
14500mAh (5V/3A discharge)
157 × 53.8 × 48.8 mm, dimensional tolerance ± 0.5 mm
565 g (approx.)
Appearance
Black, silver grey
Ternary Lithium
300 cycles to 80% capacity
Total Output Ports
1 Type-C1 port: 140W
1 Type-C2 port: 140W
1 USB-A port: 33W
Total 170W
Built-In Cable Output
1 USB-A port: 33W
Input
140W
USB-C Recharge
Multi-port input is not supported, the maximum power of a single port input can reach 140W.
Type C1 port: 140W input
Type C2 port: 140W input
USB-A Recharge
APP
Not compatible
Screen
TFT
Drop-resistant
1 m
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
20℃–30℃ (68℉–86℉)
Discharge Temperature
0℃–45℃ (32℉–113℉)
Storage Temperature
–10℃–45℃ (14℉–113℉)
Wich devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
BC1.2/Apple2.4A/QC3.0/FCP/SCP/AFC/UFCS/PD3.0/PPS
How to keep the power bank charging and discharging quickly?
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Can the RAPID Pro power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 25000mAh (90Wh), meets this requirement and can be carried on board without concern.
Why is there a difference rated capacity and nominal capacity?
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
