EcoFlow RAPID Pro Desktop Charger: 320W & 5 Ports | EU – EcoFlow Europe
EcoFlow Europe
Starting at €13,33/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
EcoFlow RAPID Pro Desktop Charger (320W, 5 Ports, GaN)
Regular price €159,99
Sale price €159,99 Regular price €159,99
Days
Hours
Minutes
Seconds
Summer Ecocredits Week: Up to 2,5× EcoCredits for PLUS Members! Join Now>>
  • 140W (Max) Single Port Power
  • 6-in-1 Smart, Multi-Device, Ultra-Powerful Desktop Charger
  • Customise Your Power with In-App Power Management
  • Advanced Protection with 10 Million Daily Temperature Tests
  • Powerful and Compact Design with GaN Technology
  • 320W (Max) Output for Ultra-Fast Charging
  • Compatible with EcoFlow RAPID Pro X (27,650mAh) Power Bank, EcoFlow RAPID Pro (27,650mAh) Power Bank, and EcoFlow RAPID Pro (20,000mAh) Power Bank only
€159,99
EcoFlow RAPID Pro Charging System
GaN Technology
6-in-1 Compact Design
Superior Safety
Smart Display
In-app Power Management & Customisation
Power Management
Screen
* Feature coming soon
Boost your work efficiency and maintain a tidy work space
Entertainment
Office Work
Entertainment
Entertainment
Office Work
Office Work
Power Distribution Modes
Compatible with 99% of everyday electronic devices.
Single-Port Charging
Multi-Port Charging
Smart Power Mode*
Customised Power Mode*
Turn on Smart Power Mode in the app. When multiple devices charge simultaneously, each port automatically detects and distributes power according to the appliance's demand without exceeding its maximum power and within the 320W total power limit.
Manually adjust the output power of each port in the app according to your device's power usage and personal charging needs.
Specs - EcoFlow RAPID Pro Desktop Charger (320W, 5 Ports, GaN)
121 × 111.8 × 50 mm
885 g
Appearance
Silver
Total Output Ports
4 × USB-C, 1 × USB-A, Pogo Pin 320W
30W
C1/C2: 140W
C3: 65W
C4: 30W
APP
Compatible
Screen
LCD
Drop-resistant
76 cm
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
20℃–30℃ (68℉–86℉)
Is it normal fo the device to heat up?
Is it normal for the device surface to heat up under high power transmission. The device has multiple built-in protection mechanisms, the device can be used with confidence, users are abvised not touch it directly.
what devices are compatible?
This charger is compatible with laptops, phones, tablets, earphones, smartwatches, gaming consoles, and other devices with USB-C or USB-A ports, such as MacBook Pro/Air, iPhone, iPad, Dell XPS, and Samsung Galaxy.
What is PogoPin contact charging? Is it safe?
PogoPin is a magnetic contact charging method commonly used in modular connections, supporting high-efficiency, safe, and stable charging connections.
Why are the power, voltage, and current readings on the charger screen different from those in the app?
The power, voltage, current, and other information displayed in the app are reported to the cloud by the charger at specified intervals, which may cause data discrepancies due to timing differences.
Can I use it after unpacking?
Yes, the product supports plug-and-play functionality. However, since the product features are continuously updated and improved, it is recommended to connect to the app and upgrade to the latest firmware for a better user experience.
Why can not my charger reach 140 W output on a single port?
Wheter the appropriate interface is selected( only C1 and C2 support 140 W Max), whether the protocol matches, whether the current device temperature is too high, and whether the device battery is almost full.
How do I connect the charger to the Ecoflow app via WI-FI / Bluetooh?
On the charger screen, select "Settings" >"Wi-Fi & BLE" and press the to turn on the switch. On the phone used to log in to the app, make sure Bluetooth is enabled. Then add the charger tothe app in the APP and follow the in-app instructions to complete the setup.
Thanks for subscribing!
4. Upload the Image
