EcoFlow RIVER Max Portable Power Station – EcoFlow Europe EcoFlow RIVER Max Portable Power Station - International (Compatible with EU + other sockets) - EcoFlow Europe
EcoFlow Europe
€649,00
Regular price €649,00
Sale price €649,00 Regular price €649,00
Up to EcoCredits for cash deduction
This item is no longer for sale on EcoFlow official website. We recommend you to check out our RIVER 2 Series and other promotional items.
• POWER WHEREVER YOU GO
• RECHARGE FROM 0-80% WITHIN 1 HOUR
• POWER UP TO 10 DEVICES SIMULTANEOUSLY
• MODULAR DESIGN
• 3 x 600W AC OUTLETS AND 576Wh CAPACITY
Socket
€649,00
Hit the outdoors with RIVER Max and keep all your devices powered on at once. With a detachable extra battery, you have up to 576Wh of capacity that charges to full in a record-breaking 96 minutes flat.
X-Stream Fast Charging
Power Multiple Devices
Removable Battery
Capacity of 576Wh
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging portable power stations. RIVER Max charges from 0-80% in under an hour, or to full in 96 minutes flat.
Go lightweight
Remove the extra battery from the base of your unit to go lightweight. Trim down to a 288Wh capacity, reducing the weight by (5.5 lbs) 2.5 kg whenever you’re on the go.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you’ll need. Sporting a 576Wh capacity, you’ll have enough juice to charge your phone 42 times, charge your drone 6 times, or make 24 cups of coffee with a coffee maker. Just don’t drink them all at once.
More power to you
EcoFlow’s proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That’s enough to power a hairdryer, a vacuum cleaner, or even a lawnmower.
Title
Light 10W
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
Harness the power of the sun by linking up to two 110W solar panels. You’ll be fully charged in 3-6 hours.
Car Charging
Heading on a road trip? Charge to full in just 6.5 hours by plugging right into your car with the car adapter.
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. You can control RIVER Max using your phone. Just connect to the EcoFlow app to control from afar. Here’s how: Step 1: Make sure the EcoFlow App is connected to RIVER Max. Step 2: Make sure RIVER Max is on. Step 3: Make sure your device’s WiFi is turned on Step 4: Find your device in the app. Then, you can start controlling your RIVER Max remotely.
Yes. RIVER Max can power devices up to 1200W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1200W, however, it’s best to test before use. Some 600W-1200W appliances with strict voltage requirements may not function (eg. air compressors).
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER Max in 3-6 hours.
RIVER Max supports entry-level UPS functionality. Make sure to perform multiple tests to confirm compatibility before connecting devices such as data servers and workstations with RIVER.
Net Weight *
17lbs (7.7kg)
Dimensions *
11.4 x 7.3 x 9.3in (28.9 x 18.4 x 23.5cm)
Charge Temperature
32 to 113°F ± 5°F (0 to 45°C ± 3°C)
Discharge Temperature
-4 to 113°F ± 5°F (-20 to 45°C ± 3°C)
Color
Black
24 months
Charge Method
AC Wall Outlet, 12V Car Adapter, Solar Panel
Full Recharge Time
1.6 Hours (AC) 6.5 Hours (12V Car Adapter) 3-6 Hours (Using 2x110W Solar Panels in parallel with full sun) 4.8-9.6 Hours (Using 1x160W Solar Panel with full sun)
576Wh (28.8V)
Cell Chemistry
Lithium-ion
500 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
UL Standard CE FCC RoHS RCM
AC Charge Input Power
X-Stream Charge 500W max
AC Charge Input Voltage
220-240Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25V DC 12A Max
Car Charger
12V DC 8A Max
AC Output (x2)
600W (Surge 1200W) total, 230Vac (50Hz/60Hz)
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
Car Power Output (x1)
136W, 13.6V DC, 10A Max
DC5521 Output (x2)
13.6V DC, 3A Max, per port
Customer Reviews
Based on 78 reviews
88%
(69)
12%
(9)
0%
(0)
0%
(0)
0%
(0)
T
Theo T.
Quick delivery, and customer service is great.
M
Marc L.
Idéal pour conserver le frigo à compresseur en route à l'occasion de nos road-trips
w
william m.
Just love it
G
Gary H.
I bought the river max for a world bike tour to keep my electronics charge. I’m installing a solar panel on my bike trailer to keep the river max charged while cycling. It might be a little over the top for my needs but at least I know I have a great product with plenty of capacity.
I have had the river max for a couple of weeks and I have been using it at home testing out how long it takes to charge my electronics. I must say I am more than happy with the results.
S
Stephan M.
Everything’s went well, only the capacity is belo 576 kW, but still ok
E
Emmanuelle D.
Perfect
quick delivery.
very good material.
very satisfied with the product
I recommend
Ecocredits
EcoCredits Program
Become a member to earn EcoCredits and exclusive rewards every time you shop!
EcoCredits Appreciation Week
How to Earn EcoCredits
Register and Subscribe
1000 EcoCredits
Shop
1 EcoCredit for every €1 spent
Earn every time you order.
Refer a Friend
Up to 3000 EcoCredits
1000 EcoCredits
Profile
1000 EcoCredits
Get Rewards
Coupons
€5
100 EcoCredits
€10
200 EcoCredits
€25
500 EcoCredits
€50
1000 EcoCredits
€100
2000 EcoCredits
€200
4000 EcoCredits
Gift
EcoFlow Badge
1199 EcoCredits
EcoFlow Camping Mat
5499 EcoCredits
EcoFlow Camping Light
4599 EcoCredits
EcoFlow Smart Plug
5999 EcoCredits
EcoFlow Flatbed Trolley
7449 EcoCredits
EcoCredits Week
Highlights of the EcoCredit Appreciation Week event:
7 days member-only discounts
Success!
* I agree to EcoFlow's Privacy Policy and Terms of Service.
