EcoFlow STREAM Series Plug & Play Solar Plant – EcoFlow Europe EcoFlow STREAM Series Plug & Play Solar Plant
EcoFlow Europe
Starting at €99,08/payment over 12 payments with 0% APR from Alma. Learn more
Pice Guarantee
Prime Day ⚡
Regular price €1.189,00
Sale price €1.189,00 Regular price €2.057,00
Save up to €1.000
- Saves you up to 1109€ on electricity bills
- Easy DIY installation—no professionals needed
- Compatible with EcoFlow STREAM Pro/AC Pro
- AI-powered experience with the EcoFlow app for smart monitoring and control
- Work seamlessly with 99% of solar panels in the market
Receive a FREE Smart Meter with your EcoFlow STREAM Series purchase
Stay Tuned!
€1.189 €2.057 -€868
A Path to Zero: Empower Your Home with Solar Energy
Seeking true energy freedom? Lead the way to 0 electricity bills.
All-in-One Hybrid System, Smart Power Core To Drive Bills To 0.
Already have panels or a microinverter and want bigger savings?
STREAM Ultra
STREAM AC Pro
Stop wasting money on oversized setups
Most home appliances use over 800W — and that keeps you tied to the grid.
EcoFlow Redefines Balcony Solar Systems Breaking Limits — Through Hardware
Big or Small, Power It All
Go “Bills to 0” with 3 smart setups. From lights and routers to fridges and kettles, the EcoFlow STREAM Series powers appliance up to 2,300W — all powered by the sun.
2300W
2000W
1200W
Parallel Mode Up to 2,300W Solar Coverage
  • Device Setup: 1 × STREAM Ultra + 1 × STREAM Ultra or STREAM AC Pro
  • Connect two units with a parallel cable to power high-wattage appliances like ovens and dishwashers — all powered by solar.
  • Output:1,200W (main) + 1,100W (secondary) = 2,300W total output
Distributed Mode Up to 2,000W Solar Coverage
  • No cable required — simply plug each unit into separate wall sockets. Solar powers up to 2,000W, with support for up to 2,300W total output when needed.
  • Output: 1,200W (main) + 800W (secondary) + 300W (grid) = 2,300W total output
Single Unit Mode Up to 1,200W Solar Coverage
  • Device Setup:1 × STREAM Ultra
  • One unit powers your everyday essentials — ideal for running TVs, cookers, fans, and more with ease.
  • Output:1,200W from a single battery
Power Goes Where Appliances Live
Appliances are spread across your home. Your batteries should be too.That’s how you reach Bills to 0.
Longer Runtime with Scalable Capacity and Solar Input
EcoFlow STREAM Ultra offers flexible DIY solar storage & PV input expansion — solar storage expansion from 1.92kWh up to 11.52kWh⁴ , and PV input expansion from 2kW(4 MPPT) to 12kW (24 MPPT), with up to 6 connected units. Easily pair two units to double your capacity or integrate with EcoFlow DELTA Series batteries for even greater storage.
Power That Flows Where It’s Needed
The AI-powered system monitors all connected devices in real time, ensuring each unit receives enough solar energy to run your appliances. If the EcoFlow STREAM AC Pro in your kitchen runs low, AI-driven load balancing automatically redirects energy from nearby units—keeping your fridge running on solar without interruption.
More Savings, Less Calculation — Through Smart Software
Breaking Limits — Through Hardware【For formatting comparison only. hardware & software】
AI-TOU (Dynamic Electricity Tariff) — Every Cent Counts
Know Tomorrow's Sun, Always One Step Ahead
AI-TOU
Sunlight Forecasts
  • The app cross-references hourly electricity rates with your usage patterns and weather forecasts to optimise your savings. It automatically charges your battery during low-rate periods and switches to stored power when rates peak—helping you save up to 50% annually⁵. Manual tariff settings are also supported for full control.
  • By analysing hyper-local sunlight forecasts and your appliance usage patterns, the app creates a forward-looking power plan—showing you which appliances to use and when. With forecast accuracy up to 94%, your home adapts to tomorrow's sky, helping you proactively reduce grid reliance and maximise solar efficiency⁶.
24/7 AI Energy Assistant - Ask Anything, Anytime
The app turns complex energy data into clear, actionable advice. Get a full energy overview and personalised report with just one tap. Control your devices with natural commands and receive instant support whenever you need it.
Seamless Smart Home Integration
Effortlessly connect to third-party smart meters and digital energy platforms for real-time monitoring and control of your home's energy usage — all through the EcoFlow app.
One-Step Portal for Total Control
Safety You Can Trust
Long-Lasting Power with LFP Technology
Equipped with advanced LFP battery cells, STREAM delivers up to 6,000 deep cycles with 70% capacity retention — lasting up to 3× longer than traditional batteries. That means up to 15 years of reliable use, backed by a 10-year warranty.
Silent Operation — as Low as 30 dB
Experience whisper-quiet performance with noise levels as low as 30 dB.The advanced self-cooling design dissipates heat efficiently — no disruptive fan noise, just silent, reliable power.
Ready For Any Weather
The system can be self-installed and maintained. However, in the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
How does the system continue to supply power during a blackout?
For safety and compliance reasons, the STREAM system will automatically detect a grid anomaly and stop feeding current into the grid during a power outage. You can then plug in your appliances directly into the AC outlets to use internal battery or solar power.
Each MPPT of the STREAM Ultra/Pro has a maximum power of 500W. Can I connect solar panels with more than 500W to each port?
Yes, as long as the solar panel meets the conditions of operating voltage (15-60V) and operating current (≤14A). This can optimize solar utilization during low sunlight conditions.
Specs - STREAM Ultra
1.92kWh
6000 cycles to 70% capacity
AC Charging Input
1050W
1200W
MPPT
4
PV Input Power
2000W (500W × 4)
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
23.1kg
284mm x 255mm x 458mm
Acoustic Noise
<30 dB
10-Year
Specs - STREAM Pro
1.92kWh
AC Charging Input
1050W
1200W
MPPT
3
PV Input Power
1500W (500W × 3)
AC Output-Grid Tied
800W
AC Charging Input
10A
2300W (10A)
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
23.1kg
Acoustic Noise
<30 dB
10-Year
Specs - STREAM AC Pro
1.92kWh
AC Charging Input
1050W
1200W
AC Output-Grid Tied
800W
AC Charging Input
10A
2300W (10A)
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
23.1kg
Acoustic Noise
<30 dB
10-Year
1. EcoFlow STREAM AC Pro collects 1,041kWh of solar energy annually. With Germany's average household consumption of 3,113kWh/year, this system covers 33.4% of total energy needs through continuous day-night solar supply. The electricity rate of €0.40/kWh translates to an annual savings of €412. Savings may vary based on consumption patterns and energy price fluctuations.
source:https://pvwatts.nrel.gov/pvwatts.php
2. EcoFlow STREAM Ultra delivers 2,218kWh of solar energy annually, achieving 71.3% coverage of Germany's average household consumption (3,113kWh/year) through 24/7 solar power supply. Based on the electricity rate of €0.40/kWh, this system provides annual savings of €1,109. Actual savings may vary depending on usage behaviour and regional energy pricing.
3. With 100% solar capture and utilization, the EcoFlow STREAM Series System generates around 5,542kWh annually - covering Germany's average household consumption (3,113kWh/year). The electricity rate of €0.40/kWh results in an annual savings of €4,748. Actual savings may vary depending on usage behaviour, regional energy pricing and different bundles.source:https://pvwatts.nrel.gov/pvwatts.php
4. The maximum capacity is 6 units, expandable up to 11.52kWh with the EcoFlow STREAM Ultra or EcoFlow STREAM AC Pro.
5. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
6. When enabling the premium plan in the EcoFlow APP, field test data shows that AI-TOU mode can increase annual electricity cost savings by approximately £51 (5% improvement) compared to manual TOU settings. Calculation based on 3,113kWh annual household consumption with £0.33/kWh electricity rate. Actual performance may vary depending on real-world conditions.
7. The accuracy of weather and power generation forecasts may vary due to real-time weather conditions and equipment status changes. In EcoFlow field test data, solar generation forecasting accuracy during midday hours (approximately 11:00-14:00) reaches 94%. Product performance may vary based on real-world usage.
4. Upload the Image
