EcoFlow 100W Rigid Solar Panel (2 pieces)
EcoFlow Europe
Starting at €14 91/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
Regular price €179.00
Sale price €179.00 Regular price €179.00
Save up to €46.50
Days
Hours
Minutes
Seconds
Up to 50% off · Vote to unlock exclusive perks Learn More>>
• Fast and Easy Installation
• Up to a 5-year warranty
€179.00
Use Highly Efficient Monocrystalline Cells
Charge Faster with High Solar Conversion
Our 100W rigid solar panel has an excellent conversion rating of 23%, allowing you to charge even faster. Combine as part of your Power Kits setup or EcoFlow portable power station, and the integrated MPPT algorithm optimizes your solar input.
Pre-Drilled Slots on Solar Panel for Secure Mounting
Ready to Install on Your Surfaces
With pre-cut holes on the panel, the 100W rigid panel is ready to mount on your van or off-grid build. Pair with the 100W Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
IP68* Waterproof Rating
Aguanta todo tipo de clima
Our 100W rigid solar panel is designed for outdoor weather. With an IP68* waterproof rating, the panel can withstand dirt, low-pressure water jets, extreme winds of up to 130 mph, and even heavy snowfalls.
Coated with Highly Protective Lamination and Tempered Glass
Durable Structure Design for Long-Lasting Performance
Built with a robust anti-corrosive aluminum frame, our 100W rigid solar panel is designed for maintaining solar collection outdoors for years. Its monocrystalline cells are coated with highly protective lamination and tempered glass to enhance performance and offer long-lasting durability.
Solar Cable for Universal Compatibility
Connect with Your Power Systems at Ease
Using an all-inclusive solar connector, our 100W rigid solar panel can be readily connected with any of your existing third-party solar systems. You can charge up 48v power systems and portable power stations with one or multiple panels.
1. 2×100W Rigid Solar Panel   2. 2×Mounting feet   3. User Manual and Warranty Card
The solar to XT60i charging cable is not included in this bundle. Click here to get a solar to XT60i charging cable.
Solar Panel Weight
Approx. 6.2 kg(13.7 lbs)
98*58.6*3 cm(38.6*23.1*1.2 in)
Rated Power
100 W(+/-5W)
Open Circuit Voltage
20.3 V
Short Circuit Current
6.3 A
Maximum Operating Voltage
17.1 V
Maximum Operating Current
5.9 A
-0.39%/°C
-0.33%/°C
0.06%/°C
Maximum System Voltage
600 VDC(UL)
Maximum Fuse Current
15 A
4. Upload the Image
