Starting at €14 91/payment over 12 payments with 0% APR from Alma. Learn more
EcoFlow 110W Lightweight Portable Solar Panel
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel is0.7 kg lighter than previous model (a 17.5% weight reduction) for effortless transport and compact storage.
Capture More Energy with a Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 122W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels.
Generate Even More Energy
With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, making it ideal for most high-latitude areas.
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most sunshine at all times.
Durable and Water-Resistant
Built to weather the storm
With an IP68 water-resistance rating, our 110W Lightweight Portable Solar Panel maintains its high performance even when it's in contact with water. You can safely recharge by the sea or take it out on your boat.
* Only the solar panel is IP68 waterproof, not including the junction box.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solar generation.
monocrystalline silicon
Rated Power
STC 110W (±5W) / BNPI 122W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 3.3kg
Unfolded: 1944 x 413 x 26 mm
Folded: 544 x 413 x 36 mm
Connector Type
XT60I-F
5 years
Open Circuit Voltage
STC Voc 23.5V (Vmp 19.5V) / BNPI Voc 23.5V (Vmp 19.5V)
Short Circuit Current
STC Isc 6.1A (Imp 5.9A) / BNPI Isc 6.8A (Imp 6.5A)
Waterproof & Dustproof
