EcoFlow 200W Flexible Solar Panel (2 pieces) – EcoFlow Europe EcoFlow 200W Flexible Solar Panel (2 pieces) - 0% VAT - EcoFlow Europe
EcoFlow Europe
€251,00
Regular price €251,00
Sale price €251,00 Regular price €299,00
Save up to €48
Tax excluded.
This Product is only available for the customers, who will fix and operate the PV system on/near/on the balcony of the aforementioned buildings.
· 4.5 kg ultra-light solar panel, bends up to 213 degrees, perfect for most balconies.
· Built to last, with an IP67 waterproof rating, unfazed by storms.
· 23% solar conversion efficiency, maximising solar energy harness.
· Simplified installation with pre-cut eyelets.
· Effortlessly connect to your power systems with universal compatibility.
VAT
€251,00 €299,00 -€48,00
Creative your balcony power station with EcoFlow PowerStream
Learn More
Power your balcony solar system
Fixed balcony installation with EcoFlow PowerStream
With EcoFlow PowerStream and an EcoFlow Portable Power Station, make a cost-efficient, sustainable home energy solution and power your home at all times.
Light and flexible
Only 4.5 kg and Bends to Fit Curved Edges
Exceptionally light and 70% lighter than traditional solar panels, making it convenient to move or mount. Easily flexes up to 213 degrees and is able to fit the unique shape of your balcony without affecting solar input.
Durable and waterproof, steadfast through any weather
Coated with Advanced Glass Fiber with an IP67 Waterproof Rating
With a protective ETFE film, the panel's solar cells can withstand many environments, while protecting the panel and enhancing performance. Use it year-round on your balcony without worry.
Charge faster with a high solar conversion
Made from Highly Efficient Monocrystalline Cells
Excellent efficiency rating of up to 23%. Charge faster with a more compact panel.
Choose Your Way to Install at Ease.
Use the Pre-cut Eyelets to Fit Our Panels as You Wish
With pre-cut eyelets, the flexible solar panel can be hung with hooks or can be securely attached to a surface using an adhesive. Stable installation on your balcony.
200W Flexible Solar Panel × 2
Solar Parallel Connection Cable × 2
Metal Zip Tie × 8
Metal Zip Tie × 8
Self-Fastening Strap × 4
Safety Instructions
Safety Instructions
4.5kg
1083 x 1104 x 2.5 mm
Cell Type
Monocrystalline Silicon
Efficiency
23%
Waterproof & Dustproof
IP67
Rated Power
200W(TOL±5%)
Open Circuit Voltage
49.2V(TOL+/-5%)
Short Circuit Current
5.1A(TOL+/-5%)
-0.45%/C
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
Certification
CE, FCC, TUV, RoHS, REACH
12 Months
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
