EcoFlow 400W Rigid Solar Panel (2 pieces) – EcoFlow Europe EcoFlow 400W Rigid Solar Panel (2 pieces)
EcoFlow Europe
Starting at €24,91/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
Summer Sale 🏖️
Regular price €299,00
Sale price €299,00 Regular price €379,00
Save up to €80
Tax excluded.
Days
Hours
Minutes
Seconds
Note: The Solar Panel Mounting Feets are not included.
- A 23% conversion rate to sunlight
- All-black design that fits any house style
- Built to last with an IP68 waterproof rating
- Fast and Easy Installation
- Up to a 10-year warranty
* The solar to XT60i charging cable is not included in this bundle. Click here to get a solar to XT60i charging cable.
Learn more about DELTA Max Bundle >>>
Learn more about DELTA Pro Bundle >>>
    VAT
    EcoFlow Rigid Solar Panel Mounting Feet
    €15,00
    €15,00
    €15,00
    €15,00
    €15,00
    €15,00
    €15,00
    €15,00
    €299 €379 -€80
    High Solar Energy Conversion
    Made from highly efficient monocrystalline cells, the 400W rigid solar panel has an excellent efficiency rating of 23%, allowing you to charge faster than using similar-sized panels. Combine this panel as part of your existing PV system or Power Kits setup, and allow the integrated MPPT algorithm to optimize your solar input.
    Waterproof & Durable
    The 400W rigid solar panel is designed for the outdoors. With an IP68* waterproof rating and a robust anti-corrosive aluminum frame, the panel can withstand a wind speed of up to 130mph* and a significant snow load of up to 113lb* and continue to capture solar energy for years to come.
    *Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.) *Well-mounted solar panels can withstand a dynamic 2400pa wind pressure load (130mph wind speed) and a static 5400pa snow load (113lb per sq foot of snow).
    Off-grid & On-grid Solution
    This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
    Universally Compatible
    EcoFlow solar panels use an all-inclusive solar connector, so you can even use them with your existing 48V power system. The 400W solar panel includes a 300mm charging cable that gives you plenty of space to mount multiple panels, maximizing solar input.
    1. 2×400W Rigid Solar Panel
    2. User Manual and Warranty Card
    Short Circuit Current
    13.79A
    Open Circuit Voltage
    37.10V
    Dimension (inch)
    67.8×44.6×1.38
    Dimension (cm)
    172.2×113.4×3.5
    Connector Type
    Solar Connector
    Efficiency
    23%
    Cell Type
    Monocrystalline
    Rated Power
    400W
    Net weight (lbs)
    48.1lbs
    Net Weight (kg)
    21.8kg
    4. Upload the Image
