EcoFlow 450W Rigid Solar Panel | EcoFlow EU – EcoFlow Europe EcoFlow 450W Rigid Solar Panel | EcoFlow EU - 450W*2 Rigid Solar Panel / / / Incl. VAT - EcoFlow Europe
EcoFlow Europe
EcoFlow 450W Rigid Solar Panel (2 pieces)
€599,00
Summer Sale 🍉
Regular price €599,00
Sale price €599,00 Regular price €599,00
Save up to €100
Tax excluded.
  • Fast and Easy Installation
  • Up to a 12-year warranty
* The solar to XT60i charging cable is not included in this bundle. Click here to get a solar to XT60i charging cable.
Solar Panel
VAT
EcoFlow Rigid Solar Panel Mounting Feet
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€15,00
€599,00
Easily connect multiple panels with your existing 48V power system using a universal connector.
Ideal for both off-grid and on-grid homeowners looking to store and utilize the power of solar energy to run their homes.
High Solar Energy Conversion
Made from highly efficient monocrystalline cells, the 450W rigid solar panel has an excellent efficiency rating of up to 23%, allowing you to charge faster than using similar-sized panels. Combine this panel as part of your existing PV system or Power Kits setup, and allow the integrated MPPT algorithm to optimize your solar input.
Waterproof & Durable
With an IP68* waterproof rating and a robust anti-corrosive aluminum frame, the panel can withstand a wind speed of up to 130 mph* and a significant snow load of up to 113 lb* and capture solar energy for years to come.
*Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 in 3.3 ft of water for 72 hours.
*Well-mounted solar panels can withstand a dynamic 2400 pa wind pressure load (130 mph wind speed) and a static 5400 pa snow load (113 lb per sq foot of snow).
Off-grid & On-grid Solution
This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible
EcoFlow solar panels use an all-inclusive solar connector, so you can even use them with your existing 48V power system. The 450W solar panel includes a 1 ft charging cable that gives you plenty of space to mount multiple panels, maximizing solar input.
1. 2 × 450W Rigid Solar Panel
2. User Manual and Warranty CardThe solar to XT60i charging cable is not included in this bundle.
Short Circuit Current
13.1A
Open Circuit Voltage
41.4V
Dimension (inch)
75.1×44.6×1.18
Dimension (cm)
190.8×113.4×3.0
Connector Type
Solar Connector
Efficiency
Up to 23%
Cell Type
Monocrystalline
Rated Power
450W
Net weight (lbs)
49.4 lb
Net Weight (kg)
22.4kg
Customer Reviews
Based on 1 review
100%
(1)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
A
Arlin S.
very good
works excellent
