EcoFlow DELTA 2 Max Solar Generator (PV160W) – EcoFlow Europe EcoFlow DELTA 2 Max Solar Generator (PV160W)
EcoFlow Europe
€1.697,00
Pice Guarantee
Regular price €1.697,00
Sale price €1.697,00 Regular price €1.797,00
Save up to €100
Expandable capacity: 2-6kWh expandable capacity to fit your energy
storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its
original capacity. That's down to its LFP battery chemistry giving you
3000 cycles.
Huge AC output: With X-Boost mode, get up to 3100W output power to
run 99% of home appliances. Power 13 devices at once, including 4 AC
outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual
AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
Capture more energy: 99% MPPT efficiency maximises solar generation
during the daytime.
High conversion efficiency rating: guarantees a faster solar charging speed. 0-100% in 5.3 hours (3 sets) and 8 hours (2 sets).
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty: 5 years for DELTA 2 Max, 24 months for 160W Solar Panel.
€1.697,00 €1.797,00 -€100,00
10-Year LFP Battery,
Built To Last 6× Longer.
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, DELTA 2 Max has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day.
LFP Battery Chemistry
That's 6x Longer Than Other Power Stations With A Similar Capacity And Output.
Advanced BMS Protection
Protective Layers Inside And Out
Robust Design
Upgraded Tech, Lighter
Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
Up to 1000W Solar Input
Solar Charging Times
1000W Approx. 2.3 hours
880W Approx. 2.6 hours
800W Approx. 2.8 hours
Capture More Energy
Expandable up to 6kWh
Triple the power.
Take Control Of Your Power.
Take control of your power.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Experience peace of mind during power cuts
With our all-new AC Always On Mode, the AC power button stays on, even during a power cut or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings. Prioritise solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready
Comprehensive warranties
With one of the most comprehensive warranties in the industry, we go the extra mile to give you peace of mind with 5 years for DELTA 2 Max and 24 months for 160W Solar Panel.
What's in the bundle - DELTA 2 Max
1. DELTA 2 Max 2. AC Charging Cable 3. User manual & warranty card
What's in the bundle - 160W Solar Panel
1. 160W Solar Panel 2. 160W Solar Panel Bag 3. Solar to XT60 Charging Cable 4. 160W Solar Panel User Manual
4. Upload the Image
