Starting at €108 25/payment over 12 payments with 0% APR from Alma. Learn more
Always Ready. More Power.
Industry-First 2kWh Solar Battery with Max 3000W Output (DELTA 3 Max Plus)
25% More Power [3]: 3000W Output, 2kWh Capacity
A New Era of Power Performance
Next-level energy for next-level peace of mind.
All Your Essentials. All at Once.
DELTA 3 Max Plus delivers a powerful 3000W output—enough to run your microwave, kettle, fridge, and blender all at once without a flicker. Lunchtime? Go full throttle. No unplugging, no interruptions—just seamless power. [4]
Pick Your Priority Outputs, Extend What Matters Most
Smart Remote Switching | Reduce waste to increase runtime for essentials
DELTA 3 Max Plus introduces Smart Output Priority Tech. This convenient new feature lets you choose which circuits stay powered via the app. Prioritize what matters—like your fridge, Wi-Fi—and extend runtime when it counts most, even when you're away.
Smart Power Reserve | Set your desired battery threshold (%) to automatically shed non-essential loads during outages
With app-based presets, DELTA 3 Max Plus automatically follows your priority settings during outages—shutting off lights while keeping your fridge running. Wake up to fresh food and plenty of power left—just like nothing happened.
Automotive-grade full-tab LFP cells
Automotive-grade Full-Tab LFP Cells: Next-Level Battery Reliability
DELTA 3 Max Plus is equipped with automotive-grade full-tab LFP cells. The full-tab design reduces resistance, enhances efficiency and safety, and provides higher capacity with less heat, resulting in a longer battery lifespan.
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [7] our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Ultra-versatile 5 charging options, 47-minute fast charge [1]
A New Level of Fast
Remote charging control for added peace of mind.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, solar forecasts, real-time electricity rates, and financial savings.
Cut Costs, Not Comfort
Charge During Low-Cost Periods to Save Big
DELTA 3 Max Plus intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day.
2–10kWh expandable capacity
Easily Scales Up—From Hours to Days
Compact, Portable, Lighter than Ever - Works Anywhere
Lightweight and easy to carry, DELTA 3 Max fits into any setting from home to the great outdoors. Weighing just 20.3 kg, it's 13% lighter for effortless portability while still packing serious power.
Comparison
Color
DELTA 3 Max - Black and Gray
DELTA 3 Max Plus - Silver
2048Wh
DELTA 3 Max - Approx. 20.3 kg
DELTA 3 Max Plus - Approx. 22.1 kg
DELTA 3 Max - 494 × 239 × 305 mm
DELTA 3 Max Plus - 494 × 242 × 305 mm
Total Output Ports
DELTA 3 Max - 9
DELTA 3 Max Plus - 10
Number of AC Outlets
4
Output Priority
DELTA 3 Max - NO
DELTA 3 Max Plus - YES
Max AC Output
DELTA 3 Max - 2400W
DELTA 3 Max Plus - 3000W
Surge Output
DELTA 3 Max - 4800W
DELTA 3 Max Plus - 6000W
Max Output by X-Boost
DELTA 3 Max - 3200W
DELTA 3 Max Plus - 3900W
X-Fusion
DELTA 3 Max - NO
USB-A
1 × 18W Max
USB-C
DELTA 3 Max - 1 × 100W Max(HID); 2 × 30W Max(Total 30W)
DELTA 3 Max Plus - 1 × 140W Max(HID); 2 × 45W Max(Total 45W)
12V DC Output
DELTA 3 Max - 126W Max; Car Power Output × 1:12.6V⎓10A
DELTA 3 Max Plus - 378W Max; Car Power Output × 1:12.6V⎓10A; Anderson Output × 1:12.6V⎓30A
AC Charging
2300W (68 min)
DELTA 3 Max - 500W
DELTA 3 Max Plus - 1000W
Generator Charging
2400W Max
Alternator Charging
DELTA 3 Max - 500W Max (Through XT60 Port)
DELTA 3 Max Plus - 1000W Max (Through 4+8 Port)
Car Charging
12V/24V⎓8A
Number of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 1 (expandable to 2)
Type of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 4+8
Compatible Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - DELTA 2 Max/DELTA 3 Max Plus/DELTA Pro 3/DELTA 3 Extra Battery
Max Capacity with Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - Up to 10kWh
UPS
DELTA 3 Max - 10ms
DELTA 3 Max Plus - 10ms + HID
Wi-Fi
YES
Bluetooth
YES
App
YES
3+2 years (Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration)
Noise
600W ≤ 25dB
Operating Altitude
≤3000m
Discharge Temperature
-10 to 45°C
Charge Temperature
0-45℃
Storage Temperature
-10 to 45°C
1. 0-80% in 47 minutes was measured in optimal conditions using X-Stream AC charging.
2. Based on proper product usage, DELTA 3 Max Plus is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. Compared with EcoFlow DELTA 2 Max.
4. The conclusion that multiple appliances can be powered simultaneously is based on internal testing. Actual performance may vary in real-world use.
5. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
6. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
7. Compared with the previous usage of EF #C33 Battery Cell.
8. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
9. Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
11. Feature requires preset activation via the EcoFlow App.
12. EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
13. Compared with car cigarette port charging.
14. Certain features in the EcoFlow app will be available soon. Please refer to the EcoFlow app for details on feature availability.
15. Multiple appliances' backup time based on ideal conditions; actual results may vary.
16. Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
17. Require connecting 1 × DELTA 3 Max Plus + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
