Starting at €66 58/payment over 12 payments with 0% APR from Alma. Learn more
1500W AC Input, Full Charge in 56 Minutes[1]
Solar Input with 1000 MPPT, Full Charge in 70 Minutes[2]
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime. DELTA 3 with a 500W MPPT recharges in 2 hours.
On-the-Go with 800W Car Charge, Full Charge in 1.3 Hours[3]
Multi-Charging (AC + Solar), Full Charge in 56 Minutes with 1500W Input[4]
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritising solar to save money.
Hybrid Power with Generator, Full Charge in 56 Minutes with 1500W AC Input[5]
With 1500W input, it takes 56 minutes to fully charge. The EcoFlow Smart Generator 3000 (Dual Fuel) automatically replenishes power at night, ensuring constant backup without manual intervention (coming soon).
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2400W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home usage, RV, and outdoor usage, this solar battery ensures you're never left in the dark.
Powerful output,
imperceptible operation.
Powerful output,
Powerful output,
30 dB ultra-quiet operation
Completely imperceptible under 600W, blending with natural ambient noise (30 dB).
Whether you're in a tent or at home, it won't disrupt sleep.
Peace of mind for backup power, convenient for daily use
Ensure reliable backup for specialized equipment with a 10 ms UPS.[6]
Third-gen LiFePO4 (LFP) cells offer fast charging without sacrificing longevity. With 4000 cycles to 80% capacity[7], enjoy up to 10 years of reliable use, 25% above the industry standard.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Same power, more compact. Achieve 2kWh capacity with EcoFlow DELTA 3 Extra Battery (1kWh), making it 1/3 smaller and lighter than the DELTA 2 power pack.
When combined with the EcoFlow Ecosystem, it can be equipped with DELTA Pro 3 Extra Battery, allowing for a maximum expansion to 5kWh, which extends the backup power duration by 5 times.
Comparison of DELTA 3 Series and DELTA 2
Specs - DELTA 3 & DELTA 3 Plus
Colour/ID
DELTA 3 - Silver & Grey
DELTA 3 Plus - Silver
1024Wh
≤12.5 kg
398×200×284 mm
D3 EB Dimensions
398×200×198 mm
App
Supported (TOU/Storm warning)
Extra Battery
Expandable capacity to 5kWh
DELTA 2 MAX/DELTA 2/DELTA Pro3/DELTA 3 Extra Battery Supported
Total Output Ports
11
AC × 4
4 × 1800W (Surge 3600W)
2400W
USB-A × 2 (Fast charging)
DELTA 3 - 2 × 18W Max
DELTA 3 Plus - 2 × 36W Max
USB-A × 2
USB-C × 2
DELTA 3 - 2 × 100W Max
DELTA 3 Plus - 2 × 140W Max
Car Power × 1
12.6V, 10A, 126W Max
DC5521 × 2
2 × 12.6V, 3A Max
AC
1500W (56 Min)
Solar
DELTA 3 - DC input 11V-60V1 × 500W Max (130 Min)
DELTA 3 Plus - DC input 11V-60V2 × 500W Max (70 Min)
Smart Generator
1500W (56 Min)
Car
800W (1.3 Hr)
AC+PV
1500W (56 Min)
Chemistry
DELTA 3 - 4000 Cycles to 80% Capacity
DELTA 3 Plus - 4000 Cycles to 80%
Waterproof level of battery pack
IP65
UPS
DELTA 3 - <10 ms
DELTA 3 Plus - <10 ms HID
Volume
600W <30 dB/1200W <40 dB
5 Years
Footnote:
[1-8] All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios
Perfect solution for both home emergencies and outdoor adventures. Even when the grid goes down, it lets us enjoy fresh coffee and hot food using solar energy. Compact and very convenient!
The Setup
Solar Input: 670W total mixed setup (1x 450W Solar Bifacial + 1x 220W Portable Foldable Panel).
Main Usage: Home office (Laptop + Monitor via UPS mode) and high-draw appliances (Washing machine, 1500W heating elements).
Key Takeaways
Smart MPPT Management: The unit brilliantly handles mixed solar panels. Even with different voltages and types, it optimizes both inputs independently, reaching over 710W of real input during the day.
Heavy Lifting (1800W AC Output): Tested with a washing machine at 30°C. It handled the initial heating surge of 1.8 kW flawlessly using X-Boost. Once the water was heated, it settled at ~370W for the wash/spin cycle, allowing the solar panels to actually charge the battery while the machine was running.
Seamless UPS Mode: Zero flicker or lag on the monitor and laptop when switching or under heavy load. The 10ms switch-over time is solid for sensitive electronics.
Smart Automation: The "Solar Wake-up" feature is a game-changer. The unit shuts down at night to save power and automatically "wakes up" with the first rays of sun, starting the charge cycle without any manual intervention.
Pros & Cons
Pros:
Power-to-Weight Ratio: 1800W output in a very portable 12.5kg frame.
Advanced App: Real-time monitoring and granular control over X-Boost and charging speeds.
Quiet Efficiency: Fans are manageable, though I recommend external airflow if keeping it inside a wooden cabinet during high-load tasks.
Cons:
Idle Power Draw: Keeping the AC inverter on without load drains the battery slightly; it’s best to use the auto-timeout settings.
Expansion Needed: For heavy daily appliance use, the 1024Wh internal capacity is a bit tight, making the Extra Battery a must-have for true energy independence.
Final Verdict
The Delta 3 Plus is the perfect "brain" for a modular home solar system. It’s smart, handles surges like a champ, and the solar management is top-tier for its price range.
My next purchase will undoubtedly be an Extra Battery to ensure a larger energy reserve and even greater independence.
EcoFlow DELTA 3 Series Portable Power Station
We are very happy with the EcoFlow Delta 3. It charges fast, works quietly, and provides stable power for our essential home devices. The build quality feels solid, and everything works exactly as expected.
We mainly use it as a home backup solution, and it gives real peace of mind. Most importantly, my family is satisfied with it, which is the best indicator of quality. Definitely a great purchase.
ordered the delta3, alternator charger and solar panels, they are great. just you need to keep in mind, that in this config the 1kW is the max power to get, as the alternator charger connects to the external socket, so you can not upgrade the base model if using the alternator charger.
