EcoFlow DELTA 3 Series Solar Generator (PV220W) - EcoFlow Europe EcoFlow DELTA 3 Series Solar Generator (PV220W) - EcoFlow Europe
EcoFlow Europe
€1.547,00
30 Days Price Guarantee
Regular price €1.547,00
Sale price €1.547,00 Regular price €1.697,00
Save up to €150
  • Expandable capacity: 1-5kWh expandable capacity to fit your energy storage needs. Ideal for home use, RVing, outdoors or even everyday use.
  • Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 4000+ cycles.
  • Huge AC output: With X-Boost mode get up to 2400W output power to run 99% of home appliances.
  • Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
  • Up to 23% conversion with a unique bifacial design to guarantee a fast solar charging speed
  • Comprehensive warranties: DELTA 3 Plus includes a 5-year warranty and 24 months for the 220W Bifacial Portable Solar Panel.
Model
Accessories
€1.547,00 €1.697,00 -€150,00
EcoFlow 220W Bifacial Portable Solar Panel
Capture More Energy with a Dual-Sided Design
With a 220W primary side and a 175W side on the back for ambient light, you can capture up to 25% more solar energy and charge your DELTA 3 Plus/DELTA 3 even faster.
Generate Even More Energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 23%.
Allows more energy intake in less time charging for DELTA 3 Plus/DELTA 3.
Capture More Solar with an Adjustable Angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
DELTA 3
DELTA 3 Plus
Specs - DELTA 3 / DELTA 3 Plus
Colour/ID
DELTA 3 - Silver / Grey
DELTA 3 Plus - Silver
1024Wh
≤12.5 kg
398×200×284 mm
D3 EB Dimensions
398×200×198 mm
App
Supported (TOU/Storm warning)
Extra Battery
Expandable capacity to 5kWh
DELTA 2 Max/DELTA 2/DELTA Pro 3/DELTA 3 Extra Battery Supported
Total Output Ports
11
AC × 4
4 × 1800W (Surge 3600W)
2400W
USB-A × 2 (Fast charging)
DELTA 3 - 2 × 18W Max
DELTA 3 Plus - 2 × 36W Max
USB-A × 2
USB-C × 2
DELTA 3 - 2 × 100W Max
DELTA 3 Plus - 2 × 140W Max
Car Power × 1
12.6V, 10A, 126W Max
DC5521 × 2
2 × 12.6V, 3A Max
AC
1500W (56 Min)
Solar
DELTA 3 - DC input 11V-60V1 × 500W Max (130 Min)
DELTA 3 Plus - DC input 11V-60V2 × 500W Max (70 Min)
Smart Generator
1500W (56 Min)
Car
800W (1.3 Hr)
AC+PV
1500W (56 Min)
Chemistry
DELTA 3 - 4000 Cycles to 80% Capacity
DELTA 3 Plus - 4000 Cycles to 80%
Waterproof level of battery pack
IP65
UPS
DELTA 3 - <10 ms
DELTA 3 Plus - <10 ms HID
Volume
600W <30 dB/1200W <40 dB
5 Years
Specs - 220W Bifacial Portable Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline Silicon
Efficiency
22-23%
24 months
82*183*2.5cm (32.3*72.0*1.0 in)
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
Front Side: 13A (Imp 12.0A)
Rear Side: 8.8A (Imp 8.4A)
Weight (Solar Panel)
Approx. 9.5kg
4. Upload the Image
