EcoFlow DELTA Pro Solar Generator (Rigid PV400W*2) – EcoFlow Europe EcoFlow DELTA Pro Solar Generator (Rigid PV400W*2) - 2 / With Extra Battery - EcoFlow Europe
EcoFlow Europe
€3.877,00
30 Days Price Guarantee
🔋New Release: DELTA 3 Max Series Available Now!
Regular price €3.877,00
Sale price €3.877,00 Regular price €4.397,00
Save up to €540
Secure your power supply with an EcoFlow DELTA Pro solar generator. Plug in 400W Rigid Solar Panels and get up to 1600W input to charge from anywhere in as fast as 1.5 hours.
The Portable & Expandable Home Battery - DELTA Pro supports a 3.6kWh capacity that can be expanded to 25kWh. The kicker? You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Rapid Dual Charging - X-Stream tech means that DELTA Pro charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 2.8 hours with 4 x 400W rigid solar panels.
Note: The Solar Panel Mounting Feets are not included.
Fast Charging - With a high conversion efficiency rate of up to 23%, the 400W panel charges your LFP batteries faster than similar-sized solar panels.
Weatherproof & Durable - The rigid panel balances design with robust materials allowing the panel to weather any storm while offering the same excellent performance and aesthetics for years.
Off & On-grid Solution - This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible - The 400W solar panel includes a 300mm charging cable that gives you plenty of space, maximizing solar input. With an all-inclusive solar connector, the 400W rigid panel works with other 3rd party solar systems and power stations.
Number of 400W Rigid Solar Panel
Option of Extra Battery
Stay Tuned!
EcoFlow Rigid Solar Panel Mounting Feet
€15,00
€15,00
€15,00
€15,00
€3.877,00 €4.397,00 -€520,00
4. Upload the Image
