EcoFlow DELTA Pro Portable Power Station – EcoFlow Europe EcoFlow DELTA Pro Portable Power Station - DELTA Pro - EcoFlow Europe
EcoFlow Europe
€1.699,00
Regular price €1.699,00
Sale price €1.699,00 Regular price €2.199,00
Save up to €513
Tax excluded.
  • First portable home battery designed for home backup.
  • 3.6-25kWh expandable capacity.
  • 3600W-7200W AC output for 99% appliances.
  • Incredible 6500W MultiCharge, 2.7 hours AC charging.
  • Recharge your RV and EV anytime, anywhere.
  • Industry first: recharge at thousands of EV stations worldwide.
  • Long-lasting LFP battery supports up to 10 years.
EcoFlow DELTA Pro to Smart Generator Adapter (sold separately) is necessary when the DELTA Pro is connected to the Smart Generator and 800W Alternator Charger.
EcoFlow DELTA Pro Bag
€109,00
€109,00
€109,00
€1.699,00 €2.199,00 -€500,00
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Smart home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with uninterrupted power during blackouts, customizable smart energy around the clock for critical loads, and lower energy bills.
Prepare your home for power outages.
When a blackout hits, the Smart Home Panel immediately switches to your 10 integrated circuits and draws power from your DELTA Pro(s). You'll barely notice a loss of power as your chosen circuits stay powered with a mere 20ms switchover time.
Expand capacity and output.
The Smart Home Panel supports and fast charges up to two DELTA Pro(s) at a time, alongside their extra batteries + smart generator(s). That gives you a potential 7200W output and 25kWh of capacity at your control, enough to power pretty much anything in your home, delivering days of power during blackouts.
Smart energy management.
Control each of your integrated home circuits via the EcoFlow app and get a birds-eye view of your energy consumption habits. Dive into the settings to customize your power use. You can optimize for home backup, saving money, or custom options to schedule your energy use based on your needs. Once you're set, you can even control which power source your house uses, all from your phone.
Draw power from your DELTA Pro(s) to power your home during peak energy use hours, this lowers your bills and reduces pressure on the grid during peak hours. During off-peak hours, use low-cost/renewable energy to charge your DELTA Pro(s) back to full.
Reduce your reliance on the grid and prepare for blackouts. Opt for EcoFlow's range of portable solar panels to store energy at any time, or charge from your AC coupled rooftop solar panels while the grid is on-line. No sun? We're working on a wind turbine. No sun or wind? Charge via the grid. No sun, no wind, and a blackout hits? You're still good. Lean on the EcoFlow Smart Generator as a last resort to charge your batteries.
Travel without limits.
Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
EV backup charging solution.
Power that means business.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker capturing precious moments or just want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
1. DELTA Pro 2. AC Charging Cable 3. Car Charging Cable 4. DC5521 to DC5525 cable 5. Handle Cover 6. User Manual
*EcoFlow DELTA Pro to Smart Generator Adapter (sold separately) is necessary when the DELTA Pro is connected to the Smart Generator.
What's the max input DELTA Pro can achieve?
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
How many solar panels can I use at the same time?
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use solar connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
How do I update the firmware?
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
4500W
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2900W Max, 230V~12.5A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Customer Reviews
Based on 29 reviews
100%
(29)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
O
Olha K.
Z
Zoe R.
This has been the perfect power source for our off-grid set up, charges really fast and works really well. It's also really quiet and doesn't make a tonne of noise which is great as it's inside the house with us 24/7!
R
Radoslava K.
It’s freaking expensive machine wich I pay with my last money straight away after I learn Ecoflow pro is exist, It’s looking great is powerful and the app it’s really useful.
Trying to find a way to charge my Tesla in emergency situations “the ground is missing” and waiting for my solar charging cable to connect my EcoFlow Pro with my solar. It’s the best!!! Thanks.
A
Anonymous
the solar charging volts should be much higher also the extra battery for the pro should have solar charging to. When will the wind turbine be ready
P
Pavel B.
Simly the best.
F
Frédéric L.
Very efficient machine in everythingVery efficient machine in all circumstances
4. Upload the Image
Get An Accessory For An Extra €19.9 With
Your Order over €199.
EcoFlow × Shelly Smart Plug
€19.9
€19.9
EcoFlow RAPID Magnetic Power Bank
€19.9 €69,99
€19.9
EcoFlow Solar to XT60i Charging Cable
€19.9
EcoFlow Power Hat
EcoFlow Power Hat
€19.9
€19.9 €59,99
EcoFlow Portable Power Station Grounding Adapter
€19.9
