EcoFlow 28W Portable Solar Panel – EcoFlow Europe EcoFlow 28W Portable Solar Panel
EcoFlow Europe
€109,00
30 Days Price Guarantee
Regular price €109,00
Sale price €109,00 Regular price
Tax excluded.
Solar Charging On-the-Go – Keep phones, power banks, and cameras charged anywhere.
Ultra-Light & Compact – Just 600 g (1.3 lb), tablet-sized, perfect for backpacking.
Dual-Port Fast Charging – 50 min to 80% (3,400mAh battery).
25% High Efficiency – Built-in angle guide for maximum sunlight conversion.
IP68 Weather-Resistance Rating – Durable for any adventure.
Includes 4 Carabiners and 1-Year Warranty.
€109,00
Featured Summary
Solar Charging On the Move
Perfect for:
Walking & backpacking
Camping
Picnics
Camping
Camping
Picnics
Picnics
Ultra-Light and Compact
* Solar panels of a similar wattage.
Portable and Foldable Design
Travel-friendly and compact design, built to be your companion on every adventure.
Adventure-Ready Fast Charging
Quickly power up in the great outdoors.
* Official Testing Note:
On a clear day (34°C/93.2°F, UV ~8), an iPhone 15 charged from 20% to 80% in 50 minutes. Results may vary based on environment, usage, and battery condition.
28W Dual-Port Charging for Multiple Devices
Smartphone
RAPID Magnetic Power Bank
Smartphone
Smartphone
* Results may vary under actual usage conditions.
Up to 25% Conversion Efficiency with Solar Angle Guide
Enjoy up to 25% solar conversion efficiency with advanced N-Type TOPCon technology, capturing more solar energy than conventional panels.
The integrated angle guide helps you adjust for optimal sunlight, achieving 45% higher power delivery compared to standard panels without the guide.
Durable & IP68 Weather-Resistance Rating
What's In the Box?
EcoFlow 28W Portable Solar Panel Specs
Maximum Power (Pmax):
28W (±1W)
USB-C Output:
5V = 3A / 9V = 2.2A / 12V = 1.67A, 20W Max
USB-A Output:
5V = 3A / 9V = 2A / 12V = 1.5A, 18W Max
Weight:
Approx. 0.6 kg (1.3 lb)
Dimensions (Folded):
291 × 177 × 18.6 mm (11.46 × 6.97 × 0.73 in)
Dimensions (Unfolded):
291 × 664 × 2 mm (11.46 × 26.14 × 0.08 in)
1. How long is the EcoFlow 28W Portable Solar Panel warranty period?
The EcoFlow 28W Portable Solar Panel warranty period is 1 year.
2. What can affect the charging efficiency of solar panels?
The actual efficiency of the solar panel will vary depending on many external factors, such as local weather conditions, sunlight intensity, the level of shade, orientation of the battery, temperature, positioning, or the presence of dust and debris. For instance, if you live in a shaded area or an area that does not get much sunlight, you might not get a high output or might even get no output.
3. How do you clean the surface of the solar panel cells?
Firstly, use a soft-bristled brush to remove any debris from the surface. Wipe surface with a damp cloth to remove any residual debris. You should remove any bird excrement or other debris that may get stuck on the panel surface as soon as possible, to avoid any performance issues.
4. The output power for the two fast-charging ports is 18W and 20W, but the product description states 28W, how should I understand this discrepancy?
The solar panel can generate up to 28W of output power, supplying power to the junction box's internal circuit. However, lighting intensity and buck/boost line loss can make this number inconsistent, and so the USB-A and USB-C ports use 18W and 20W fast-charging specifications to supply the external power output more stably.
5. Are the solar panels compatible with third-party power stations?
The main use case scenario for this is to power devices such as mobile phones, camera, GPS devices, headlamps, and small-sized drones. It is not recommended to directly link to other power sources for charging.
6. What are the operating conditions of the white light? Does the light being on represent the power flowing out or flowing in?
When opening up the solar panel, the LED light is powered on, indicating that the power output is functional.
7. Can the solar panel be used on overcast days?
It can be used on overcast days. However, since the light output is generally lower on overcast days, the total output power might also be lower, reducing charging efficiency.
Disclaimer
1. This product does not have a built-in battery. To store power, please prepare an external mobile battery separately.
2. For maximum solar charging performance, adjust the angle and orientation of the solar panel to ensure direct sunlight exposure.
3. Avoid exposing smartphones or tablets to direct sunlight while charging, as high temperatures may cause damage.
4. This product does not include an integrated stand.
4. Upload the Image
