EcoFlow 400W Lightweight Portable Solar Panel - EcoFlow EU
EcoFlow Europe
Starting at €46/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
EcoFlow 400W Lightweight Portable Solar Panel (Refurbished)
Regular price €552.00
Sale price €552.00 Regular price €649.00
Save up to €186.00
Tax excluded.
· Lightweight and compact for portability
· Up to 25% conversion efficiency rate with a bifacial design
· 3-angle (30°/45°/60°) adjustable stand and integrated solar angle guide
· IP68 rating protects against water and dust
· Built-in XT60 cable for easy storage and connection to power stations
* This lightweight portable solar panel is not recommended for certain scenarios, such as hanging long-term outdoors or on vehicles.
€552.00 €649.00 -€97.00
Capture More Energy with a Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 445W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel is 5.8 kg lighter than previous models for effortless transport and compact storage.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable to 30°, 45°, and 60°, making it ideal for most high-latitude areas. Adjustable stand with 30°, 45°, and 60° positions
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most sunshine at all times.
Durable and Water-Resistant
Built to Weather the Storm
With an IP68 water-resistance rating, our 400W Lightweight Portable Solar Panel maintains its high performance even when it's in contact with water. You can safely recharge by the sea or take it out on your boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solar generation.
EcoFlow Solar Panel Comparison
Original vs. Lightweight
EcoFlow Lightweight Portable Solar Panels (NEW)
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Up to 25%
Weight
Stand Type
3-Angle Adjustable Support Stand 30°/45°/60°
Separate Kickstand Case
Additional Feature
No Solar Angle Guide
Built-in XT60 Cable
Separate XT60 Cable
5 Years
1 Year
Rated Power
400W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 10.2 kg
Unfolded: 2509 x 967 x 26 mm
Folded: 659 x 967 x 36 mm
Connector Type
XT60
5 years
Open Circuit Voltage
39.3V (Vpm 34.5V)
Short Circuit Current
12.2A (Ipm 11.7A)
Waterproof & Dustproof
Thanks for subscribing!
4. Upload the Image
