Starting at €54,08/payment over 12 payments with 0% APR from Alma. Learn more
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 1 hour. And it gets even better. If you're looking for an even faster way to charge up DELTA Max, you can combine AC with the Smart Generator, AC with solar, or the Smart Generator with solar.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
AC Charging
Smart Generator
Car Charging
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
How many solar panels can I use at the same time withDELTA Max?
It depends on the total voltage and watts of solar panels youchoose. As long as the solar panels use MC4 connector and itsvoltage and current are under 11-100V, 13A max range.
What's the max input for DELTA Max?
How does the Emergency Power Supply (EPS) work?
What's the water-resistance rating for this product?
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
