Portable RV & EV Power with EcoFlow DELTA Pro – EcoFlow Europe Portable RV & EV Power with EcoFlow DELTA Pro
EcoFlow Europe
Secure Payments
Multi-channel Support
Pice Guarantee
Regular price €1.798,00
Sale price €1.798,00 Regular price €2.298,00
Save up to €800
· Travel without limits. - Stay powered for up to a week, powering your RV essentials even when boondocking.
· No noise, no fumes, maintenance-free - Experience a clean and silent power source with no noise or fumes.
· Fast charging anytime, anywhere - Fully recharge in 2 hours with MultiCharge.
· Extend EV Range - Go the extra mile even when caught short.
· Charge up at EV stations worldwide - Fully recharged in 1.7 hours(3400W) with industry’s first EV stations charging.
Note:
1. RV power solution: The shore power cable and 230V 16A adapter required to connect the RV power cable to DELTA Pro are not included.
2. EV Backup Charging Solution: Level-2 mobile EV charger not included.
RV&EV Power Solution
What's in the kit
RV Power Solution
Traveller Kit: DELTA Pro + Grounding Adapter
Overlander Kit: DELTA Pro + DELTA Pro Extra Battery + Grounding Adapter
DELTA Pro + Grounding Adapter + EV X-Stream Adapter
EcoFlow Portable Power Station Grounding Adapter
€99,00
EcoFlow EV X-Stream Adapter (DELTA Pro)
€99,00
€99,00
€99,00
€99,00
€99,00
€1 798 €2 298 -€500
Secure Payments
The terms “DELTA” and “RIVER” as mentioned on this
page refer to products exclusively manufactured by ECOFLOW INC.
Escape the grid, embrace the wild without worrying about how much power you've used. With a whopping 3.6-7.2kWh of expandable power, experience the ultimate freedom of off-grid living while powering all of your RV essentials with a clean and quiet energy source. Plus, use DELTA Pro as a mobile EV charger when you're on the road. DELTA Pro is the ultimate, portable power solution for RV road trips and outdoor adventures.
A true adventurer always seeking the next thrill. Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
Traveller Kit : 3.6kWh
Starlink Wi-Fi (50W): 72h
Fridge (20W) : 180h
Light (25W): 144h
Laptop (60W) : 60h
Air Conditioner (1200W) : 3h
*The data above is for reference only. Actual run times depends on the individual's RV electricity needs and may vary.
Overlander Kit : 7.2kWh
Starlink Wi-Fi (50W): 144h
Fridge(100W) : 72h
Light (25W): 288h
Laptop (60W) :120h
Coffee Maker(1000W): 7.2h
Air Conditioner (1200W) : 6h
Bid farewell to noisy, fume-filled gas generators and relish peaceful, green, maintenance-free power wherever your RV adventures take you. Charge your RV essentials, or plug into a shore power outlet to directly power your RV's electrical system.
Whether you're on the road, at a campsite, or in your backyard, you're never left without power. Topup using MultiCharge in the time it takes to watch a movie. Fully recharge in only 1.7 hours at an EV charging station (3400W), 1.9 hours with dual AC + solar charging (3000W), 2.7 hours from an AC outlet (1800W), and 3.5 hours using solar (1600W).
Relieve EV range anxiety.
*Miles per kWh for a TESLA MODEL Y: 3.3-3.8 mi/kWh, DELTA Pro (3.6kWh) can extend the range of a MODEL Y approximately 13.68 miles.
4. Upload the Image
