RAPID Pro Charger: 140W, 4 ports & GaN technology | EcoFlow EU
EcoFlow Europe
Starting at €4 24/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
EcoFlow RAPID Pro Charger (140W, 4 Ports, GaN)
Regular price €50.99
Sale price €50.99 Regular price €79.99
Save up to €29.00
Days
Hours
Minutes
Seconds
Up to 50% off · Vote to unlock exclusive perks Learn More>>
  • 4-in-1 Charger, Charge Four Devices at Once: Power up your laptop, phone, and earbuds simultaneously with one multi-port fast charger.
  • Fast, Cool, & Safe Charging: Advanced temperature control technology reduces power output to prevent overheating. Real-time monitoring protects both your charger and devices. For added peace of mind, in the rare event of a fire, built-in flame-retardant tech extinguishes flames within 10 seconds—no dripping or reigniting.
  • Built to Last: The AC plug endures over 5,000 plug-and-unplug cycles without causing wear and tear—sturdy and reliable for the long haul.
  • Compact & Travel-Ready: Lightweight and space-saving design makes it easy to pack and carry. Protective build keeps the plug safe from being damaged. Dimensions: 67 × 63 × 31 mm
€50.99 €79.99 -€29.00
Portable with GaN Technology
4-in-1 Fast Multi-Port Charger
Advanced Stability
Superior Safety
This charger's compact design ensures it seamlessly fits into your setup without taking up space or interfering with other devices. Boasting a size that's about 36% smaller than an Apple 140W USB-C Power Adapter.
When charging multiple devices simultaneously, it intelligently adjusts the power output based on the charging needs of each device, ensuring efficient, stable, and safe charging.
When plugged into the wall, its anti-gravity design allows a lifting weight of up to 0.6 kg / 1.32 lb without falling out and 10 uses per day without warping. The AC outlet is highly durable and can withstand 5,000 plug-unplug cycles without wear.²
Power Your Life, Anytime, Anywhere
Remote Work
Office
Travel
Remote Work
Remote Work
Office
Office
Office
Office
Travel
Travel
Charge 4 Devices at Once
Compatible with 99% of everyday electronic devices.
One-Port Charging
Two-Port Charging
Three-Port Charging
Four-Port Charging
Specs - EcoFlow RAPID Pro Charger (140W, 4 Ports, GaN)
67 ± 0.3 × 63 ± 0.3 × 31 ± 0.3 mm
220 g
Appearance
Silver
Total Output Ports
3C1A, 140W Total
USB-A Output/ USB-C Output
Type-C1/C2 Output: 5V==3A, 9V==3A, 12V==3A,15V==3A, 20V==5A, 28V==5A, 140W
Type-C3 Output: 5V==3A, 9V==3A,12V==2.5A, 30W
USB-A Output: 5V==3A, 9V==3A, 12V==2.5A, 30W
Type-C1+Type-C2 Output: 70W+70W
Type-C3+USB-A Output: 18W
Type-C1/Type-C2+Type-C3 Output: 100W+30W
Type-C1+Type-C2+Type-C3 Output: 65W+45W+30W
Type-C1+Type-C2+USB-A Output: 65W+45W+18W
Type-C1/Type-C2+USB-A Output: 100W+30W
Type-C1/Type-C2+ (Type-C3+USB-A) Output: 100W+18W
Type-C1+Type-C2+ (Type-C3+USB-A) Output: 65W+45W+18W
Total Output: 140W Max
Drop-resistant
1 m
Fireproof
Housing V0 Fireproof
2 Years
Charge Temperature
0℃–25℃
Is it normal for the charger to get hot?
It is normal for the device surface to heat up under high power transmission. The device has multiple built-in protection mechanisms and can be used with confidence.
What devices are compatible?
This charger is compatible with laptops, smartphones, tablets, headphones, smartwatches, gaming consoles, and other devices equipped with USB-C or USB-A ports, such as MacBook Pro/Air, iPhone, iPad, Dell XPS, and Samsung Galaxy.
PPS/PD3.1/PD3.0/QC3.0/QC2.0/FCP/SCP/APPLE2.4A/BC1.2
What is the size of the adapter? How portable is it? Can it be carried in a carry-on bag on a plane?
The 100W model measures 55.5 × 40.6 × 46.6 mm, and the 140W model measures 67 × 63 × 31 mm.Both models feature foldable plug designs for easy portability, making them suitable for daily commuting or business travel.
Is there a data cable in the package? if not, which cable do you recommend?
This product package does not include a data cable. To fully utilize the high-power output capabilities of this charger (up to 100W / 140W), it is recommended to use a high-power USB-C to USB-C cable that supports the USB-C PD3.1 protocol and features an E-Marker chip. It is advised to choose cables rated for 5A current and 20V voltage (such as those labeled 100W or 240W) to ensure a safe and fast charging experience.
How many times can the plug be folded? Is it easy to loosen or break?
This product is constructed with high-strength metal materials and a reinforced hinge design. The plug prongs have undergone multiple folding tests, demonstrating excellent durability. Under normal usage, frequent folding will not cause looseness or breakage, ensuring a stable connection and portability over the long term. To extend the product’s lifespan, it is recommended to avoid excessive force or angled operations when folding or unfolding.
Why can not some devices be charged at the maximun rated power?
This product can automatically detect the type of charging device and match the appropriate charging protocol. It adjusts the output voltage and current accordingly to ensure safe and reliable charging, reducing charging time. If the protocol is not compatible, the actual output will be lower than the maximum.
4. Upload the Image
