EcoFlow RIVER 3 Portable Power Station | EcoFlow EU – EcoFlow Europe EcoFlow RIVER 3 Portable Power Station | EcoFlow EU - RIVER 3 + 110W Solar Panel - EcoFlow Europe
EcoFlow Europe
€519,00
Regular price €519,00
Sale price €519,00 Regular price €528,00
Save up to €9
  • 245Wh capacity, 300W rated output, X-Boost up to 600W
  • Up to 2x runtime for light-wattage appliances
  • 30% more compact than the industry average
  • <20/10 ms UPS for uninterruptible backup
  • <30 dB whisper quiet for 24/7 use
  • 1-hr fast charging, without battery damage
  • IP54 waterproof-rated battery pack
  • Charge up to 5 appliances at the same time
Power Station
EcoFlow RIVER Series Bag
€69,00
€69,00
€69,00
€69,00
€519,00 €528,00 -€9,00
An ideal starter battery that is compact yet delivers powerful performance
Compact design with powerful performance
Easily extend your outdoor stays and handle power outages with GaN
With groundbreaking X-GaNPower, RIVER 3 taps into superior energy efficiency to extend the operating time of low-wattage devices witha compact design and quieter running volume.
30% more compact for on-the-go use
RIVER 3 minimises heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, or a bag for easy storage and portability.
Up to 2x light and network runtime
RIVER 3 revolutionises energy efficiency, delivering double runtime for appliances under 100W, extending use at home and in the great outdoors.¹
< 30 dB whisper quiet for 24/7 backup
With X-GaNPower’s enhanced heat dissipation, RIVER 3 operates on a library-like quiet level, with a volume of less than 30 dB at a distance of 0.5 m.² You'll have peace day and night guaranteed, even when it's running nonstop.
AC charging
Solar charging
Car charging
Generator charging
RIVER 3 fast-charges in 1 hour with X-Stream, without causing battery damage due to vehicle-grade cells and trickle charge technology.
Power up RIVER 3 in as fast as 2.6 hours with 110W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C), which folds to the size of a laptop and charges electronics directly.
Charge RIVER 3 using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge RIVER 3 in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Extremely durable for worry-free outdoor use
With IP54 battery protection, water damage is minimised.³ Its robust fire-retardant shell survives rough conditions. Even after a 1 m fall, RIVER 3 won't get damaged.
RIVER 3 has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 protects against various current, voltage, temperature, and circuit risks.
Power up to 600W appliances
Your reliable companion in the wild or during an outage
RIVER 3 keeps 90% of your must-have appliances running smoothly with 300W of power. With X-Boost technology, it can power 600W heating devices without breaking a sweat.
<20 ms UPS solution for uninterrupted daily living
When a power outage occurs, your AC outlet will switch to the RIVER 3 supply in a barely noticeable 20 ms. It keeps vital home appliances running, maintaining food storage, security, and communication. Experience a seamless, automatic switchover for continuous peace of mind
Upgraded smart control
Convenient, intelligent, customized power control
Product Details
245Wh
255 x 212 x 113 mm
3.55 kg
UPS
<20 ms
Noise
<30 dB
1 outlets, 300W total (Surge 600W, X-Boost 600W)
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15⎓3A max, 20V⎓5A Max,100W max per port
Car Output
AC Input
200~240V, 3A, 50/60Hz, 305W, 0-100% in 60 min
Solar Input
11~30V, 8A, 110W, 0-100% in as fast as 2.6 hr
Car Input
11~30V, 8A, 100W, 0-100% in 2.8 hr
Generator Input
200~240V, 3A, 50/60Hz, 300W, 0-100% in 60 min
Optimal Operating Temperature
20℃-30℃ (68°F-86°F)
Charge Temperature
0℃-45℃ (32°F-113°F)
Discharge Temperature
-10℃-45℃ (14°F-113°F)
Storage Temperature
20℃-30℃ (68°F-86°F)
Footnote:
The RIVER 3 Series revolutionizes energy efficiency, delivering up to double runtime for light-wattage appliances, extending use at home and in the great outdoors. Data was tested in a controlled laboratory environment and actual user experience may vary.
1. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router.
3. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Customer Reviews
Based on 6 reviews
100%
(6)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
M
Manos C.
Love it
Small super quiet and easy to carry
S
Seamus G.W.
works well, and is nice and quiet
Got this with the solar panel. Handy for running lights and fans in my shed, like a little micro off-grid system
K
Kaloyan I.
Almost perfect portable power station for camping/RV
This is one of most compact and light power stations in this class. It's also very very quiet and it packs a punch (I've tried it with 200W LED light /Nanlite FS-300B) and it works like a charm, even at maximum power (326W constant drain)! The 100W USB-C is also very usable for powering laptops like MacBooks ect. My only complaints are that the Type-C port os only one (I wish there were 2 of them) and there's no wireless charging pad on the top (the space is enough for charging at least one phone there...The workaround(s) for having more than USB-C ports is to use car cigarette charger with fast charging ports or just use a wall charger plugged into the AC port (not ideal since there's more power consumption from the inverter). Overall, very good and nicely designed power station! Recommended!
N
Nikolay S.
An exceptional product
River3 UPS is an exceptional product. It's built quality and features are superb. It is super quiet and it turned out it can run a lot of my kitchen stuff (even the mixer rated at 800w) and other gadgets. It's AC is very important. Although it has only one type-c port, I've managed to extend them to 3 ports via the car charger socket, which is also rated at 100w.
I would wish to see in the river4 model at least two type-c ports built in on top of the rest.
M
Miro
EcoFlow RIVER 3 UPS: A Month In, Still Impressed
I've had the EcoFlow RIVER 3 UPS for a month now, and it's still rocking my world. This little powerhouse is built tough but doesn't hog space. Setup was a breeze, and the app is surprisingly easy to use. After a month of use, I'm still patting myself on the back for this purchase. If you're after a reliable, compact UPS that doesn't complicate your life, this one's a solid bet!
M
Mark
The Pocket-Sized Power Beast!
You ever look at a power outage and say, “Not today, darkness!”? Or go camping and wish you could bring your entire house with you? Well, say hello to the EcoFlow RIVER 3 Portable Power Station, the little battery pack with a big attitude.
Why Is This Thing So Awesome?
Power That Packs a Punch – Don’t let the size fool you—this thing can power 99% of your devices. Laptops? Easy. Mini-fridges? No problem. Hair straightener so you can look fabulous in the woods? Absolutely.
Faster Charging Than Your Phone (Seriously!) – With X-Stream fast charging, this beast goes from 0 to 80% in about an hour. That’s faster than you can make a decent cup of coffee.
So Many Ways to Charge – Plug it into the wall, charge it with solar panels (because you’re environmentally responsible, right?), or even juice it up from your car while you definitely don’t get lost on your road trip.
Compact, But Mighty – Unlike its bigger cousin, the DELTA 3, this little guy is actually portable. As in, you can carry it without needing a gym membership.
Pros & Cons – The Truth Hurts (Or Helps!)
✅ Super Portable – Take it anywhere! Camping, road trips, your weird uncle’s house with unreliable power…
✅ Silent Operator – It’s quieter than a ninja sneaking out of a bad date.
✅ Works in Almost Any Situation – Power outages? Beach parties? Charging your drone while looking cool in front of strangers? Done.
❌ Not For Power-Hungry Appliances – If you’re trying to run a full-size fridge, you might wanna call its big brother, the DELTA 3.
❌ Addictive Power Use – You’ll start plugging things in just because you can. “Can it charge my scooter? Let’s find out!”
Final Verdict
The EcoFlow RIVER 3 is the ultimate sidekick for adventurers, emergency preppers, and anyone who hates being powerless (literally and metaphorically). It’s small, fast, and versatile—kind of like a techy Swiss Army knife, but way cooler.
Would recommend 11/10—now if you’ll excuse me, I’m gonna go charge my phone, laptop, speaker, and… Scooter? 🔋⚡
