EcoFlow × Shelly Smart Plug
EcoFlow Europe
Starting at €2 90/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
Regular price €34.90
Sale price €34.90 Regular price €34.90
*Only compatible with EcoFlow STREAM Series Plug & Play Solar Plant
Pair with the EcoFlow STREAM Series Plug & Play Solar Plant
  • Optimised Energy Auto-Allocation
  • Real-time Energy Tracking
  • App Remote Control
  • Schedules and Timers
  • Wi-Fi & Bluetooth Enabled
  • Away Mode
Products
Häufig zusammen gekauft
€34.90
Smart Plug — Switch Your Load Smartly
Why you need it?
Plug-and-play for effortless setup | Real-time power monitoring for key appliances | Automatic switching based on surplus energy | Intelligent load control with the STREAM Series Plug & Play Solar Plant
When smart plugs are part of your balcony solar system, they monitor power usage of your appliances, which helps the microinverter auto-allocate the exact energy amount required for those appliances. Excess energy is stored in the battery, ensuring no energy goes to waste.
App Remote Control & Schedules and Timers
Once the system is connected to the internet, you can remotely control it via smartphone. You can turn on your desk lamp or start your fan before you get home, easily empowering an ultra-smart, ultra-comfortable life.
Additionally, you can set up scheduled tasks or timers so that your appliances can automatically turn on or off at the times you desire, even without an internet connection.
Track energy usage of your appliances live and over time so you can view comprehensive reports on the EcoFlow app and learn your consumption patterns. This gives you an edge in terms of improving your energy savings and adopting a carbon-neutral lifestyle.
Away Mode
Away Mode allows select appliances such as lamps to turn on intermittently and irregularly, simulating the presence of someone at home. This is suitable for use when you need to be away from your house for extended durations, ensuring an added layer of home security.
Smart Meter × Smart Plug: Zero Feed-in. All Solar, All Yours¹
More Benefits For You
Weight
Approximately 60 g
44 × 44 × 70 mm
Voltage
220-230 V
Alternating current
12 A
Frequency
50/60 Hz
Operating temperature
-20°C to 40°C (-5°F to 105°F)
Wi-Fi
Frequency range: 2401-2473 MHz
Maximum output power: ≤10 dBm
Bluetooth®
Frequency range: 2400-2483.5 MHz
Maximum output power: ≤4 dBm
1. After installing STREAM Series battery and compatible Smart Meter, users can connect appliances to wall outlets via compatible Smart Plugs, enabling remote on/off control and operation scheduling through the EcoFlow app—thereby minimizing solar energy waste.
Thanks for subscribing!
4. Upload the Image
