Starting at €33,25/payment over 12 payments with 0% APR from Alma. Learn more
Power Up with a 60% Boost
More Power, Zero Hassle
The EcoFlow Single Axis Solar Tracker enables every apartment and home balcony to achieve energy independence using minimal space. By automatically tracking the angle of direct sunlight from 10 to 85 degrees on a single axis, it helps maximize the use of renewable energy.
* In mid-to-high latitudes (30°–60° latitude), a single shaft provides significant power generation gain compared to a vertical, optimally fixed installation. Under ideal conditions:
- The single-axis tracking offers an increased gain of at least 20% over the local best installation, regardless of the southeast-southwest azimuth range.
- Single-axis tracking gains range from at least 60% to 146% over vertical installation, regardless of the southeast-southwest azimuth range.
A better energy-saving solution
Chase the Sun with Most of the Rigid Solar Panels on the Market
With an expandable frame, the tracker works seamlessly with most rigid solar panels on the market, ensuring high-efficiency power generation. The tracker is compatible with rigid solar panels in a dimensional range of 1000–2500 mm (39.4–98.4 in) in length, 600–1200 mm (23.6-47.2 in) in width, and 30–40 mm (1.2–1.6 in) in height.
Maximized efficiency
Dynamic Power Solutions Providing More Possibilities
On-grid power solution: When combined with a micro-inverter, it becomes the most convenient on-grid energy-saving solution for your home.
Off-grid power solution: When combined with a portable power station, it provides the strongest and most stable power generation companion for your off-grid adventures.
Smart controls
Control Easily Via the App or Manual Operation
It automatically switches on and operates throughout the day, switching off when the sun sets or is out of sight. You can easily monitor the solar tracker's operation status through the EcoFlow App. In particular circumstances, you can manually adjust the angle of the tracker. It's highly efficient, intelligent, and safe to use.
Optimized performance and security
Durable and Safe Design for Long-Lasting Performance
Our tracker is made of highly corrosion-resistant galvanized steel with exceptional waterproofing, offering reliable and durable outdoor installation in any weather condition. Choosing the EcoFlow balcony solar system is a long-term investment in home energy independence.
* The control box is not waterproof during heavy rainstorms.
11 kg(24 lb)
1340 × 223 × 88 mm
Wind Resistance
LEVEL 6
Adjustable Angle
10°-85°
Waterproof rating
Max Supported Solar Panel
25 kg(55lb), 1000-2500 × 600-1200 × 30-40 mm (39.4-98.4 × 23.6-47.2 × 1.2-1.6 in)
App Support
iOS, Android
Internal Battery Capacity
NCM, 36Wh,500 cycles to 80%+ capacity
