EcoFlow Single Axis Solar Tracker – EcoFlow Europe
EcoFlow Europe
Starting at €39,91/payment over 12 payments with 0% APR from Alma. Learn more
Pice Guarantee
Regular price €479,00
Sale price €479,00 Regular price €579,00
Save up to €100
Tax excluded.
Days
Hours
Minutes
Seconds
End-of-Season Sale × Ecocredits Week:
Up to 64% Off Everything! Join Now>>
*Only compatible with EcoFlow 400W Rigid Solar Panel (2 pieces)
A single-axis tracking system is a tracking system for solar panels where the pivot of the photovoltaic support structure is installed parallel to the surface and rotates along the north-south direction around a vertical axis, allowing the solar panels to track the maximum one-dimensional angle of incidence of sunlight in a direction perpendicular to the sun.
  • 60% more efficient
  • 10°-85° automatic adjustable angle
  • Smart sensors (light and rain)
  • Plug-and-play
  • Highly waterproof and wind-resistant
  • App remote control
  • 3-year warranty
€479 €579 -€100
Power Up with a 60% Boost
More Power, Zero Hassle
The EcoFlow Single Axis Solar Tracker enables every apartment and home balcony to achieve energy independence using minimal space. By automatically tracking the angle of direct sunlight from 10 to 85 degrees on a single axis, it helps maximize the use of renewable energy.
* In mid-to-high latitudes (30°–60° latitude), a single shaft provides significant power generation gain compared to a vertical, optimally fixed installation. Under ideal conditions:
- The single-axis tracking offers an increased gain of at least 20% over the local best installation, regardless of the southeast-southwest azimuth range.
- Single-axis tracking gains range from at least 60% to 146% over vertical installation, regardless of the southeast-southwest azimuth range.
The most hassle-free user experience
Advanced Sensors for Sunlight and Weather
We have developed a new rain-light sensor that can sensitively capture changes in the natural environment and weather, ensuring optimal energy production and safe use of solar panels.
Sunny
Rainy
Windy
The solar tracker automatically adjusts its angle to ensure maximum energy production when there is significant sunlight variation. It also adapts to nearby trees or buildings casting shadows, optimizing energy production.
* Equipped with a rain-light sensor, this solar tracker features automatic adjustment functions, including sun-tracking mode (>50000 lux every 30 minutes), sun-searching mode (>30000 lux), auto-sleep mode (≤30000 lux), and automatic shutdown during rain or typhoon warnings (typhoon level 6).
When encountering heavy rain, the solar tracker adjusts its angle for optimal energy production and self-protection.
The solar tracker automatically adjusts to 10 degrees when facing wind levels above 6, ensuring safe usage. It has a wind resistance capability of up to level 8. In cases of higher wind levels, it is recommended to temporarily remove and store the solar tracker appropriately.
A better energy-saving solution
Chase the Sun with Most of the Rigid Solar Panels on the Market
With an expandable frame, the tracker works seamlessly with most rigid solar panels on the market, ensuring high-efficiency power generation. The tracker is compatible with rigid solar panels in a dimensional range of 1000–2500 mm (39.4–98.4 in) in length, 600–1200 mm (23.6-47.2 in) in width, and 30–40 mm (1.2–1.6 in) in height.
Maximized efficiency
Dynamic Power Solutions Providing More Possibilities
On-grid power solution: When combined with a micro-inverter, it becomes the most convenient on-grid energy-saving solution for your home.
Off-grid power solution: When combined with a portable power station, it provides the strongest and most stable power generation companion for your off-grid adventures.
Smart controls
Control Easily Via the App or Manual Operation
It automatically switches on and operates throughout the day, switching off when the sun sets or is out of sight. You can easily monitor the solar tracker's operation status through the EcoFlow App. In particular circumstances, you can manually adjust the angle of the tracker. It's highly efficient, intelligent, and safe to use.
Optimized performance and security
Durable and Safe Design for Long-Lasting Performance
Our tracker is made of highly corrosion-resistant galvanized steel with exceptional waterproofing, offering reliable and durable outdoor installation in any weather condition. Choosing the EcoFlow balcony solar system is a long-term investment in home energy independence.
* The control box is not waterproof during heavy rainstorms.
DIY Installation
Step 1
Step 2
Step 3
Step 4
Step 5
5 rods from all sides combined into the final bracket shape in the figure
Install the control box and sensor box and adjust the angle
Install the solar panel
Install the hooks
Install on the balcony railing
*The balcony railing should be a grill railing with a top width of <80mm and a load capacity of ≥50kg.
11 kg(24 lb)
1340 × 223 × 88 mm
Wind Resistance
LEVEL 6
Adjustable Angle
10°-85°
Waterproof rating
Max Supported Solar Panel
25 kg(55lb), 1000-2500 × 600-1200 × 30-40 mm (39.4-98.4 × 23.6-47.2 × 1.2-1.6 in)
App Support
iOS, Android
Internal Battery Capacity
NCM, 36Wh,500 cycles to 80%+ capacity
Thanks for subscribing!
4. Upload the Image
