EcoFlow Power Hat – EcoFlow Europe EcoFlow Power Hat
EcoFlow Europe
EcoFlow Power Hat
€99,00
30 Days Price Guarantee
EcoFlow Power Hat
Regular price €99,00
Sale price €99,00 Regular price €99,00
Power all your adventures.
· Solar charging on the go
· Captures solar energy from all angles without any blind spots.
· Dual USB-A & USB-C ports for charging two devices simultaneously.
· UPF 50+, sun and UV protection
· More power, less heat, for a cooler wearing experience
· IP65 waterproof and dustproof-rated, ideal for hiking, beach trips, fishing, and outdoor activities.
· Available in two sizes M: 58 cm/L: 61 cm (22.8/24 in) with an adjustable hook and loop fastener for the perfect fit.
€99,00
Adjustable M to XL Size
Featuring an adjustable hook-and-loop design inside the hat for a snug fit without obstructing vision.
360-degree coverageSolar charging on the go
Traditional solar panels require adjusting to ensure optimal sunlight exposure. EcoFlow Power Hat maintains the optimal angle at all times, eliminating the need for manual adjustments. It charges a mobile phone fully in as fast as 3 hours.
*Based on an average smartphone battery capacity of 4000mAh.
Dual ports for charging two devices at once
Charge two devices at the same time, such as neck fans, Bluetooth headphones, and mobile phones.
UPF50+, sun and UV protection
The EcoFlow Power Hat comes with a lab-tested UV penetration rate of 0%, achieving a sun protection factor of UPF50+. With sun and UV protection, it lets you face the sun without worrying about sunburn or overheating.
More Power, Less Heat
During the charging process, the hat's solar panels on the brim convert 24% of absorbed solar energy into electricity, with the energy converted into heat reduced to 66%. Compared to a standard black hat, it has a lower surface temperature, providing a cooler experience.
Foldable design, easy to carry
Lightweight and comfortable for extended wear. Easily folds and fits into a backpack for convenient storage, making it the ideal choice for hiking.
IP65 Waterproof and Dustproof-rated
Suitable for outdoor use
Works well in wet environments like by the sea or lake, and can be used in light rain. Resistant to sand and dust, splash-proof, and crack-resistant, making it durable and suitable for outdoor use without needing delicate handling.
Suitable for outdoor scenarios
Ideal for hiking, mountain climbing, fishing, beach outings, outdoor tasks, and more. Perfect for solar charging during an outdoor activity while also providing sun protection.
What's in the box?
Rated Power
STC12W(+/-1w)
Medium-Large: 56-58 cm / 22-22.8"
Large-X-Large: 59-61 cm / 23.2-24"
370 g
Output Ports
USB-A/USB-C
Output
5V 2.4A Max
Waterproof & Dustproof
IP65
Cell Type & Efficiency
Perc Monocrystalline Silicon, 23-24%
Open Circuit Voltage
7.8V
Maximum Operating Voltage
6V
Maximum Operating Current
2A
Short Circuit Current
2.2A
4. Upload the Image
