EcoFlow STREAM AC Pro/AC – EcoFlow Europe EcoFlow STREAM AC Pro/AC
EcoFlow Europe
€1.999,00
Pice Guarantee
🎄 Christmas Sale | Up to 60% Off
Regular price €1.999,00
Sale price €1.999,00 Regular price €1.998,00
Save up to €1.049
• Save up to €416 on your electricity bills
• Effortless DIY installation—no professionals required
• Compatible with EcoFlow STREAM series
• AI‑driven experience via the EcoFlow app for intelligent monitoring and control
• 100% compatible with all microinverters
Stay Tuned!
EcoFlow STREAM Ultra/Pro/Max
€779,00 €1.299,00
EcoFlow STREAM DIY Front Case
€79,00
DIY Front Case for STREAM Solar Battery
EcoFlow Smart Meter
€129,00
Whole-Home Intelligent Power Monitoring
EcoFlow STREAM Parallel Cable (0.55m)
€24,90
€779,00 €1.299,00
€79,00
EcoFlow Smart Meter
€129,00
€24,90
€779,00 €1.299,00
€79,00
EcoFlow Smart Meter
€129,00
€24,90
€1.999,00
*STREAM AC only supports 800W bidirectional inversion
Perfect Solution For Extended Storage, Drive Bills To 0
Powered by AC-coupling technology, EcoFlow STREAM AC Pro integrates with any microinverter or connects directly to wall sockets, efficiently storing solar power and delivering uninterrupted energy throughout your home¹.
Works With All Microinverters
If you have installed a microinverter in your home and need more storage, there is no need to worry about compatibility with EcoFlow STREAM AC Pro. It connects to all microinverters via wall sockets with an AC-coupled solution. Just plug into your existing system for maximum power generation and lower power bills.
2300W AC Output
Run two appliances independently via dual AC outlets, with 1,200W output per battery and auto-boost up to 2,300W. Pair with another STREAM AC Pro or STREAM Ultra for full 2300W AC output, while the built-in battery ensures off-grid use and backup during outages.
One Step Closer To 0 Bills
Build Your Home Solar Plant With EcoFlow STREAM AC Pro
Big or Small, Power It All
Go “Bills to 0” with 3 smart setups. From lights and routers to fridges and kettles, the EcoFlow STREAM Series powers appliance up to 2,300W — all powered by the sun.
2300W
2000W
1200W
Parallel Mode Up to 2,300W Solar Coverage
  • Device Setup: 1 × STREAM Ultra + 1 × STREAM Ultra or STREAM AC Pro
  • Connect two units with a parallel cable to power high-wattage appliances like ovens and dishwashers — all powered by solar.
  • Output:1,200W (main) + 1,100W (secondary) = 2,300W total output
Distributed ModeUp to 2,000W Solar Coverage
  • No cable required — simply plug each unit into separate wall sockets. Solar powers up to 2,000W, with support for up to 2,300W total output when needed.
  • Output: 1,200W (main) + 800W (secondary) + 300W (grid) = 2,300W total output
Single Unit Mode Up to 1,200W Solar Coverage
  • Device Setup:1 × STREAM Ultra
  • One unit powers your everyday essentials — ideal for running TVs, cookers, fans, and more with ease.
  • Output:1,200W from a single battery
Power Goes Where Appliances Live
Appliances are spread across your home. Your batteries should be too.That’s how you reach Bills to 0.
Longer Runtime with Scalable Capacity and Solar Input
EcoFlow STREAM AC Pro supports flexible DIY solar storage expansion from 1.92kWh to 11.52kWh³ with up to 6 connected units. Easily pair two units to double your capacity or integrate with EcoFlow DELTA Series batteries for even greater storage.
Power That Flows Where It’s Needed
The AI-powered system monitors all connected devices in real time, ensuring each unit receives enough solar energy to run your appliances. If the EcoFlow STREAM AC Pro in your kitchen runs low, AI-driven load balancing automatically redirects energy from nearby units—keeping your fridge running on solar without interruption.
More Savings, Fewer Calculations—Through Software⁴
Boost Your Savings with the TOU Model and Solar Forecasting⁵
Time‑of‑Use (TOU)  Dynamic Electricity Pricing
Charge when prices are low, supply when prices are high.
AI-TOU model offers you the optimal bill-saving strategy every 60 minutes, based on the analysis of tariff data from Nord Pool, Epex Spot, Rabot Energy, Octopus, and more.
High Accuracy Solar Forecasts, Maximize Your Savings All Year Round⁶
Powered by Solcast's world-leading solar and weather forecasting, processing over 100 million forecasts per hour—including geolocation, satellite imagery, historical data, and TMYs (Typical Meteorological Years) —to deliver real-time insights and savings.
Smart Meter × Smart Plug: Zero Feed-in. All Solar, All Yours⁷
EcoFlow works with leading smart energy brands like Shelly, Tibber, and more, managing your home's power with the Smart Meter, Smart Plugs, and the EcoFlow app. Automatically run appliances like your sprinkler, e-bike, or ventilation using surplus solar. Let every ray of sunshine stay yours.
EcoFlow AI Assistant: No Math. Just Savings.⁸
Your AI Assistant simplifies energy management by doing the hard work for you—analyzing data, spotting inefficiencies, and giving clear, actionable recommendations. No calculations, no guesswork—just smart, easy decisions.
Protecting Your Privacy, Always.
EcoFlow protects your data using top-level security measures certified by global standards including TRUSTe, NIST, ISO, and more.
Safety You Can Trust
Long-Lasting Power with LFP Technology
Equipped with advanced LFP battery cells, STREAM delivers up to 6,000 deep cycles with 70% capacity retention — lasting up to 3× longer than traditional batteries. That means up to 15 years of reliable use, backed by a 10-year warranty.
Silent Operation — as Low as 30 dB
Reliable Winter PerformanceEquipped with self-heating technology, the system operates smoothly even at -20°C.IP65 Water and Dust ResistanceWith an IP65 water-resistant rating, the energy storage unit resists rain and dust — ideal for outdoor use in all seasons.
Ready For Any Weather
How to Install
Discover the Differences in Rear Ports
EcoFlow STREAM AC
1.92kWh
1.92kWh
1.92kWh
1.92kWh
1050W
800W
1050W
800W
1200W
800W
1200W
800W
Yes
No
Yes
No
2300W (10A)
2300W (10A)
21.5kg
21.2kg
21.5kg
21.2kg
255mm × 254mm × 458mm
What's in the box - STREAM AC Pro
STREAM AC Pro × 800W
STREAM AC Cable (1.5m) × 1
Mounting Bracket × 1
Locking Bracket × 1
Locking Bracket × 1
Safety Instructions × 1
Installation Guide × 1
Warranty Card × 1
Warranty Card × 1
STREAM AC × 800W
STREAM AC × 800W
Locking Bracket × 1
Locking Bracket × 1
Warranty Card × 1
Warranty Card × 1
Specs - STREAM AC Pro
1.92kWh
6000 cycles
AC Charging Input
1050W
1200W
AC Output-Grid Tied
800W
AC Charging Input
10A
Max Device Power Supported
2300W (10A)
Operating Temperature
-20~55°C
Battery Self-Heating
Connection
Wi-Fi/Bluetooth
Ingress Protection Rating
IP65
21.5kg
Acoustic Noise
<30 dB
10-Year
Specs - STREAM AC
1.92kWh
6000 cycles
AC Charging Input
800W
800W
AC Output-Grid Tied
800W
-20~55°C
Connection
Wi-Fi/Bluetooth
IP65
21.2kg
Acoustic Noise
<30 dB
10-Year
The system can be self-installed and maintained. However, in the UK, local regulations require the EcoFlow STREAM DIY Cable to be wired into the distribution board, which must be done by a certified installer or electrician.
How does the system continue to supply power during a blackout?
For safety and compliance reasons, the STREAM system will automatically detect a grid anomaly and stop feeding current into the grid during a power outage. You can then plug in your appliances directly into the AC outlets to use internal battery or solar power.
Each MPPT of the STREAM Ultra/Pro has a maximum power of 500W. Can I connect solar panels with more than 500W to each port?
Yes, as long as the solar panel meets the conditions of operating voltage (15-60V) and operating current (≤14A). This can optimize solar utilization during low sunlight conditions.
1. EcoFlow STREAM AC Pro harvests 1,041 kWh of solar energy annually. Based on Germany’s average household consumption of 3,113 kWh per year, the system provides 33.4% of total energy needs through continuous day-to-night solar supply. At an electricity rate of €0.33/kWh, this equates to estimated annual savings of € 416. Actual savings may vary depending on consumption habits and energy price fluctuations.
source:https://pvwatts.nrel.gov/pvwatts.php
2. Installation time is based on internal test results from the EcoFlow Lab. Real-world installation duration may vary depending on system configuration and application environment.
3. The maximum capacity is 6 units, expandable up to 11.52kWh with the EcoFlow STREAM AC Pro or EcoFlow STREAM Ultra.
4. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
5. The calculation is an estimate based on 10 kWh/day electricity consumption in Munich, Germany (representing Central Europe), using STREAM series products (6kWh batteries and 2800W PV). It is simulated by AI, factoring in fluctuations in electricity prices and usage for a closer reflection of real-world conditions. Actual results may vary depending on local conditions.
6. The EcoFlow app integrates weather data from Solcast, running over 100 million data operations per hour to deliver forecasts with up to 94% accuracy and horizons of up to three days. (https://solcast.com/)
7. After installing STREAM Series battery and compatible Smart Meter, users can connect appliances to wall outlets via compatible Smart Plugs, enabling remote on/off control and operation scheduling through the EcoFlow app—thereby minimizing solar energy waste.
8. Actual EcoFlow app functionality may vary; the screens shown are for illustrative purposes only.
4. Upload the Image
