EcoFlow WAVE 3 Portable Air Conditioner | EcoFlow EU
EcoFlow Europe
Starting at €124 91/payment over 12 payments with 0% APR from Alma. Learn more
Pice Guarantee
Regular price €1,499.00
Sale price €1,499.00 Regular price €1,598.00
Save up to €150.00
Days
Hours
Minutes
Seconds
Up to 50% Off · The Biggest Sale of the Year! Buy Now>>
1. Exceptional cooling and heating: 6100 BTU cooling and 6800 BTU heating capacity for all-season comfort.
2. Wireless and portable: Enjoy up to 8 hours of wireless, on-the-go use.
3. Fast cooling: Drops temperatures fast—in just 15 minutes.
4. Hassle-free installation: Insulated Exhaust Duct fits diverse outdoor setups with ease.
5. Smart app control: One-tap operation from your phone.
6. Multiple charging options (WAVE 3 Add-On Battery*): Stay powered with multiple charge options for non-stop comfort.
7. 2-Year Warranty.
*The EcoFlow WAVE 3 Add-On Battery is sold separately.
EcoFlow Alternator Charger 600
€249
Charge while you drive
Stay powered up on the road
€1,499.00 €1,598.00 -€99.00
Why EcoFlow WAVE 3 Stands Out
Built for Every Scenario
Car
Camping
Tent
Camping
RV
Adventures
Outdoor Fun
Indoor Spaces
Semi-Trucks
Boating
Rapid cooling and heating
6100 BTU cooling power & 6800 BTU heating power
Drop 8°C/15℉ in just 15 minutes¹
with 6100 BTU power, setting an ideal environment for any scenario. Quickly warm up with 6800 BTU heating, raising the temperature by 9°C/17°F in just 15 minutes ², perfect for staying cosy during chilly outdoor activities like autumn camping.
8 Hours of Wireless Comfort
1024Wh LFP Add-On Battery*
The add-on battery offers up to 8 hours of uninterrupted use³—perfect for a full night of restful sleep. High-quality LFP cells ensure a lifespan of up to 10 years in daily use.
It's All on the App
Powered by EcoFlow OASIS
Easily manage everything from real-time battery status to water drain notifications, mode changes, and scheduled shutdowns—all from your phone, no matter where you are.
Intelligent Modes for Maximum Comfort
Automatic
Function
Pet
Care
Dehumidification
Function
Sleep Mode
Water Drain Alert
Automatically switches to heating when temperatures drop, keeping you cozy even on chilly mountain camping trips, ensuring a good night's sleep.
Set a temperature range of 35-45°C via the app to protect your pet from heatstroke indoors. Once the set temperature is exceeded, WAVE 3 automatically starts cooling and sends you an app notification.
Adjusts humidity to your desired level, so you can stay comfortable, even during rainy seasons.
Operates at just 44 dB, about the same as a quiet conversation, ensuring peaceful rest.
When the water tank nears full, the app sends a reminder to drain it, ensuring optimal performance.
Endless Cooling On the Go
Fast charging in just 75 min*
By combining AC charging and solar charging, the Add-On Battery can be fully charged in as fast as 75 minutes. With the EcoFlow Alternator Charger, you can charge while driving—1 hour of driving, and stay comfortable all night.
Solar Charging (400W)
EcoFlow Alternator Charger(400W/800W)
AC Charging (700W)
Car Power Outlet (100W)
Fully charged in 3 hours. Charging port: XT60 on the Add-On Battery.
Charge while driving. In 102 minutes, you're ready to go. Charging port: Both WAVE 3 and Add-On Battery (not recommended to use WAVE 3 directly due to unstable power).
Fully charged in 2 hours. Charging port: XT150 on WAVE 3 and Add-On Battery.
Emergency charging in 10 hours. Charging port: XT60 on the Add-On Battery.
See What's New
What's in the Box - EcoFlow WAVE 3
EcoFlow WAVE 3
EcoFlow WAVE 3
Exhaust Duct Adapter Covers (A, B, C)
Drain Pipe
Drain Pipe
Winder
Winder
Duct Size Template
Duct Size Template
Safety Instructions, Quick Start Guide, Warranty Card
What's in the Box - EcoFlow WAVE 3 Add-On Battery*
Add-On Battery Cable
Car Charging Cable
Car Charging Cable
The automatic drainage function is activated when the condensate level in the bottom water reservoir reaches the pump sensor detection point.
Based on testing, automatic drainage is typically triggered when the accumulated condensate volume is approximately 300–400 mL. The actual trigger volume may vary slightly due to factors such as the unit's placement angle and ambient humidity.
To ensure proper operation of the automatic drainage function, please keep the air conditioner positioned as level as possible. Excessive tilting may cause uneven water distribution within the reservoir, leading to inaccurate water level detection and compromised drainage performance. In severe cases, condensate may even overflow from the edges of the reservoir.
After the air conditioner is switched off, residual condensate may still be present in the bottom water reservoir, which is the primary cause of minor water spillage during handling.
- After automatic or manual drainage, approximately 50–100 mL of residual condensate remains in the reservoir—this is normal.
- If the automatic drainage threshold was not reached before shutdown and manual drainage was not performed, the condensate generated during operation will continue to accumulate in the reservoir, potentially leaving 100–400 mL of water.
During transport, if the unit is tilted at a significant angle, residual condensate in the reservoir may flow out from the front, rear, or side edges of the tray.
For long-distance transportation or storage, we recommend first draining residual water in a safe environment by opening the drain plug. Gently lift the front of the unit to direct the accumulated water toward the drain outlet and allow it to flow out, thereby emptying as much water as possible before proceeding with long-distance transport or storage. During handling, please keep the air conditioner as level as possible and avoid excessive tilting to minimise any inconvenience caused by water leakage.
No, it cannot be completely emptied. After either automatic or manual drainage, a small amount of residual condensate—approximately 50–100 mL—will remain in the reservoir.
The main reasons are as follows:
1. Reservoir geometry limitations: The reservoir has a relatively shallow slope and incorporates internal baffle structures, which prevent all condensate from converging toward the pump suction inlet. As a result, some water may remain around the perimeter of the reservoir.
2. Pump suction positioning: The pump suction inlet is not located at the lowest point of the reservoir. The lowest point, where the drain plug is situated, will still retain some condensate that cannot be evacuated by the pump.
Therefore, it is normal for a small quantity of residual water to remain in the reservoir after automatic or manual drainage. When disconnecting the drain hose, please prepare a towel or container to catch any residual water that may spill out, so as to avoid wetting the surrounding area.
When the air conditioner enters a full-water state, the bottom water reservoir can hold approximately 1100 mL of condensate.
1.Car charger (XT60 port)
2.Solar panel (XT60 port)
3.EcoFlow Alternator Charger (XT60/XT150)
LFP (Lithium Iron Phosphate) – safer and longer-lasting.
Retains ≥80% capacity after 4,000 charge cycles.
Yes! IP65 rating – protects against dust and water splashes.
Car charger (12V/96W): ~16.2 hrs
Car charger (24V/192W): ~7.3 hrs
Solar (ideal conditions): ~3.6 hrs
Actual time may vary based on usage.
Yes!
USB-A: Up to 18W
USB-C: Up to 140W
1.Shore power outlet
2.EcoFlow WAVE 2/3 Add-on Battery (XT150 port)
3.EcoFlow portable power stations (XT150 port)
1.Check power connection:
Plug it into a shore power outlet first. If it starts, the battery was fully drained.
2.Low battery discharging limit:
If the battery is below the discharging limit, plug it in to charge.
Optional: Set the discharging limit to 0% in settings. This gives you 1 extra minute of runtime before shutdown.
3.Future improvement:
A firmware update will soon improve low-battery handling for smoother operation.
Still stuck? Contact support for help! 😊
1.Hold the Drainage Button for 3 seconds to start auto-draining.
After draining, remove the tube and tilt the device backward slightly to remove leftover water.
1.Drain all water before moving (use the drainage button).
2.Never tilt or flip the device – it may break internal parts.
3.Check battery connections if attached.
4.Turn off the device before moving.
5.Total weight ≈55 lbs (25 kg) – Don’t move it alone!
1.Keep the WAVE 3 away from dust or debris to prevent strange noises.
2.Avoid direct sunlight – it reduces cooling efficiency.
3.Place the WAVE 3 flat on the ground to avoid water leakage.
1.Always keep WAVE 3 connected to power during updates. Unstable power may cause failures or damage.
2.If an update fails due to power issues:
Reconnect to power and retry.
Contact support if the problem persists.
1.Check the packaging for damage. Open the box and verify all components are included.
2.Plug the device into a shore power outlet, turn it on, connect it to Wi-Fi via the EcoFlow app, and update the firmware.
⚠️ Keep WAVE 3 plugged in during updates to avoid failures!
Specs - EcoFlow WAVE 3
Approximately 15.6 kg (34.4 lb)
519×297×336 mm
(20.4×11.7×13.2 in)
Cooling Capacity
1800W (6100BTU)
Heating Capacity
2000W (6800BTU)
Temperature Setting Range
16-30℃ (60.8-86℉)
Refrigerant/Amount
R290/112 g (R290/0.25 lb)
Air Volume
330m³/h
Rated Cooling Power (AC/DC)
690W/640W
645W/606W
Cooling Efficiency (AC/DC)
2.6/2.8
Heating Efficiency (AC/DC)
3.1/3.3
AC Input
100-240V~50/60 Hz,
820W Max
Add-on Battery Input
700W Max
Operating Temperature
5-50℃ (41-122℉)
IP Rating
IPX4
Noise Level
44-58 dB
Remote Control
App (Wi-Fi(2.4G, 5G), Bluetooth)
Run Time with EcoFlow Add-On Battery
2-8 hr
Specs - EcoFlow WAVE 3 Add-On Battery
Approximately 9.7 kg (21.4 lb )
516×281×111 mm
(20.3×11.1×4.4 in)
Battery Capacity
1024Wh 51.2V 20Ah
80%+ capacity after 4000 cycles
Maximum Input Power
1000W Max
Automobile Auxiliary Power Outlet Charging Input
12V/24V,8A Max, 200W Max
Solar Input
11-60V,13A Max, 400W Max
Maximum Output Power
858W Max
5/9/12V, 2.4/2/1.5A, 18W Max
5/9/12/15V⎓3A Max;
20V/28V⎓5A Max, 140W Max
Charge Temperature
0-45℃ (32-113℉)
Discharge Temperature
-10-50℃ (14-122℉)
IP Rating
IP65
WAVE 3 Compatibility
WAVE 3 Add-On Battery Compatibility
Set Up EcoFlow WAVE 3 in Minutes
Disclaimers:
[1] Tested in a 10 cubic meter space at 60°F/15℃. Performance may vary with room size and temperature.
[2] Tested in a 10 cubic meter space at 60°F/15℃. Results may differ depending on conditions.
[3] 8 hours of wireless use in Eco Mode under optimal conditions. Battery life may vary based on usage and environment.
Starting at €66 58/payment over 12 payments with 0% APR from Alma. Learn more
4. Upload the Image
