EcoFlow Alternator Charger Plus 1000 – 10x Faster Charging | EcoFlow Europe
EcoFlow Europe
Starting at €176 41/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
Regular price €2,117.00
Sale price €2,117.00 Regular price €2,617.00
Save up to €500.00
Days
Hours
Minutes
Seconds
Learn More>>
- 10× Faster Charging – Power up 1kWh in just 1 hour*, so your battery is full by the time you arrive.
- Charge While Driving – Skip the hassle of hauling your power station back home for AC charging.
- 3 Charging Modes – Includes reverse charging via power station & solar panel to prevent car battery drain.
- 8 Layers of Safety – 5 battery protections + 3 alternator protections for complete peace of mind.
-. Smart Control – Manage charging modes anytime via the EcoFlow app or your car’s infotainment system.
- Plug-and-Play Installation – Auto-starts with ignition, no complicated setup required.
* Tested using a 12V car charging system at 25 ℃ ambient temperature. Actual performance may vary by vehicle and environment.
** The Alternator Charger Plus 1000 includes one XT150 output cable in the box. Solar input cable is not included. Please refer to the compatibility chart at the bottom of the page to check if you’ll need an additional cable for your power station.
€499 €599
€799 €1,099
EcoFlow WAVE 2 Exhaust ducts
€59
EcoFlow WAVE Series Stabilizing Strap Kit
€49
€2,117.00 €2,617.00 -€500.00
Faster – Top Up 1kWh in Just 1 Hour*
Charge as you drive – 10× faster than a traditional car cigarette lighter. Power up 1kWh in only 1 hour and arrive with a fully charged portable power station.
Alternator + Solar Flexible Dual Charging
The Alternator Charger Plus 1000 offers more flexible and economical recharging options—so you can charge even while parked.By connecting solar directly to the alternator charger port, you free up the XT60 port on your portable power station. This allows you to use both the alternator charger and solar panels at the same time.
Cloudy or Low-Sunlight Days
Turn off solar charging in the app to draw up to 1000W from the alternator alone.
Sunny Days
Turn on solar charging in the app to combine 700W from the alternator + up to 300W from solar, reaching a maximum of 1000W input.
Charge While You Drive, Power Anywhere
Car Camping
RV Living
Vehicle Conversions
Disaster Evacuation
For power stations of 2kWh and above, the Alternator Charger frees you from heavy lifting. Charge your high-capacity unit to full while driving—no more hauling it back home for AC charging. Just leave it in your car and let the alternator do the work.
Perfect for RV and pickup conversions with high-power appliances. Enable dual-unit charging with two Alternator Charger Plus 1000s to fully charge DELTA Pro 3 in just 2.7 hours*—45% faster than a single unit.
Skip traditional hardwired 12V batteries and DC-to-DC chargers. With a power station + alternator charger setup, you get ultimate flexibility: power onboard systems while driving, then take your power outdoors for lighting, cooking, or tools.
When emergencies hit, restore your power station to full during the evacuation drive—even if it’s been sitting unused and partially discharged.
*Tested using a 12V car charging system at 25 ℃ ambient temperature. Actual results may vary by vehicle and environment.
Reverse Charging for Car Battery Protection
With 3 charging modes, the Alternator Charger Plus 1000 supports reverse charging* to the starter battery via the power station or solar panels. This helps maintain vehicle battery health and prevents draining.
*Requires an output cable with communication function (XT150 or 4+8 supported; XT60 not supported). The Alternator Charger Plus 1000 includes one XT150 output cable in the box.
[Charging Mode] – up to 1000W
[Reverse Charging Mode] – up to 1000W
[Battery Maintenance Mode] – up to 100W
Use when battery voltage is healthy. Charges the power station while driving.
Use when multiple 12V loads are connected to the vehicle battery. Provides supplemental power from the power station through the alternator charger to keep the starter battery from draining.
- Pure Solar Charging Mode – up to 300WUse without a power station connected. Supplies power directly from solar panels to the starter battery.
- Emergency Charging Mode – approx. 15AUse when the vehicle battery is depleted and the engine won’t start. Functions as an alternative to a jump starter by slowly restoring the battery to normal voltage.
Note: 12V battery minimum starting voltage: 5.5V; 24V battery minimum starting voltage: 10V
Use when starter battery voltage is low. Works as a battery maintainer, delivering steady current to extend starter battery lifespan.
Fully Utilize 3 Charging Modes Across Scenarios
Car Camping
RV Living
Overlanding & Van Conversions
Safer – Enhanced Alternator & Starter Battery Protection
The Alternator Charger harnesses surplus alternator power without disrupting normal vehicle operation or adding extra load while driving.
Note: A vehicle alternator typically delivers ~50% more power than required for basic onboard systems during normal driving. The Alternator Charger safely utilizes this surplus. Combined with intelligent starter battery voltage detection, it automatically adapts output based on alternator model, driving conditions, and in-car power usage—always staying within safe operating limits.
Five Layers of Protection with Advanced Quality Standards
Designed for outdoor and off-road conditions, the Alternator Charger features an IP4X dust protection rating to guard against particles commonly found in vehicle cabins and engine bays. The fanless natural cooling design ensures a sealed structure that resists dust buildup, reducing the risk of short circuits and supporting long-term, reliable performance in harsh environments.
Simpler – Smart Control via App or Infotainment
An industry first: supports car infotainment connectivity, compatible with Apple CarPlay and Android Auto interfaces*.
Monitor real-time starter battery voltage, portable power station SOC, and remaining charging time directly on your vehicle’s infotainment screen. Adjust charging modes on the go to manage power station status—everything at your fingertips.
*Apple CarPlay and Android Auto are trademarks of Apple Inc. and Google LLC. Compatibility may vary by vehicle model and system version.
Plug-and-Play Design for Easy Installation
Braided Input Cable – Easy Routing
Direct Plug-In Terminals – Quick Transfers
Ignition Start – Automatic Power-On
A braided-sleeve input cable reduces friction for smoother firewall passage during installation. Its abrasion-resistant design prevents sheath damage and meets automotive industry standards for long-term durability.
No screws, no tools. The charger’s direct plug-in terminals make it easy to connect or disconnect your portable power station—perfect for owners who use multiple vehicles.
Once the ignition cable is connected, the alternator charger powers on automatically with the engine. No need to press a button or activate it in the app each time.
Universal Compatibility with Vehicle Batteries & Power Stations
Compatible with Power Stations
Works with 24V/48V portable power stations, including the EcoFlow RIVER & DELTA series as well as most third-party models*.
* DELTA Pro Ultra is not included. Requires the correct output cables or adapters based on the power station’s port type. Actual charging power is limited by the maximum input capacity of the connected power station.
What's in the Box
What's in the Box
What's in the Box
Specifications
Model
EF-AC-001
Approx. 1.7 kg
Dimensions (W × D × H)
276×187×38 mm
Wi-Fi
Supported
Bluetooth
Supported
Charging Mode
Input: 12V/24V⎓(11V-31V⎓), 75A Max
Output: 24V⎓/40V-60V⎓, 20A Max, 1000W Max
Input:40V-60V⎓, 3A Max
Output: 13.8V/27.6V⎓, 100W Max
Input: 40V-60V⎓, 20A Max
Output: 13.8V/27.6V⎓, 75A Max
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage protection
Undervoltage protection
Operating Temperature
–10℃ to 45℃ (14℉ to 113℉)
Storage Temperature
–30℃ to 70℃ (–22℉ to 158℉)
Operating Humidity
≤95%
Storage Humidity
≤95%
Thanks for subscribing!
4. Upload the Image
