Starting at €6 58/payment over 12 payments with 0% APR from Alma. Learn more
Ideal solar power source for RIVER 3
and RIVER 2 Series
With its compact design and lightweight, a 45W Portable Solar Panel is the ideal companion for RIVER Series power stations, providing a simple and convenient charging experience.
Designed for Type-C charging
Charge your gadgets directly
45W Portable Solar Panel (Type-C) includes a Type-C output port to direct charge devices like phones, laptops, and air pumps. Experience the utmost convenience with our 45W Portable Solar Panel (Type-C).
Up to 25% conversion rate
Charge faster with an even smaller panel.
With the introduction of TOPCon solar technology, a first in the mini portable solar panel industry, we've set a new standard for conversion efficiency, achieving 25%. This enables faster charging in a more compact form. Fully charge RIVER 3 in 6.3 hours during peak sunlight hours, and power your electronics and essential camping appliances for a longer adventure.
More benefits of adopting TOPCon
EcoFlow 45W Solar Panel with TOPCon vs traditional solar panel with PERC material
Extremely compact
Easily fit into any compact space
With its folding four-panel structure, the portable solar panel significantly reduces in size when folded, allowing it to easily fit into compact spaces such as backpacks, SUVs, or minivans.
IP68 Waterproof, built to last
Always be ready for unexpected weather
Featuring robust PCB fiberglass and a durable ETFE coating, our panels are designed to withstand challenging weather conditions. Whether it's a sudden impact, being pulled by the wind, or even exposure to salty ocean spray and water droplets, they remain undamaged and strong, serving as your reliable outdoor companion.*
Designed for hanging
Charging on the go
In addition to being laid flat on the ground or tilted using a stand, the 45W portable solar panel can be hung using the four pre-cut eyelets and hooks included. Whether hung on your car or backpack, save time by charging while you're heading to your next destination.
Product details
Rated Power
45W (±3W)
Open Circuit Voltage
25.6V
Short Circuit Current
2.06A
Optimal Operating Voltage
21.9V
Optimal Operating Current
2.0A
Efficiency
Up to 25%
Weight (Solar Panel)
1.4 kg
Unfolded Dimensions
980x309x25 mm
Folded Dimensions
222x309x45 mm
Cell Type
TOPCon monocrystalline silicon
Connector Type
Photovoltaic connectors (adapted to MC4 connectors)
Rated Power
45W (±5W)
25.6V
2.06A
Max Power Voltage (Vmp)
22V
Max Power Current (Imp)
1.98A
DC5521 Output
45W (±5W)22V/1.98A
Type-C Output
15W Max (5V/3A)
21.9V
2.0A
Efficiency
Up to 25%
1.4 kg
Unfolded Dimensions
980x309x25 mm
Folded Dimensions
222x309x45 mm
Cell Type
Connector Type
DC5521/Type-C
*To maintain optimal performance, avoid prolonged exposure to humid conditions. Keep the junction box and wire connectors away from liquids. Handle the solar panel with care —do not frequently knock, squeeze, or bend it. It is advisable to keep the product in an upright position during transportation and storage.
