Starting at €75 58/payment over 12 payments with 0% APR from Alma. Learn more
Take Capacity to the Max
With an expandable design, triple the capacity from 2kWh to 6kWh.
Power your essentials like your fridge for up to 42 hours¹
¹Data based on 6kWh capacity running a 120W referigerator.
2048Wh
Input Port
51.2V, 2000W Max
Output Port
51.2V, 3200W Max
Battery
LFP chemistry, 3000 cycles to >80% capacity
Dimension
464 × 235 × 283 mm (18 × 9 × 11 in.)
Weight
19kg(42lbs)
What’s in the box
EcoFlow DELTA 2 Max Smart Extra Battery, Extra Battery Cable, User Manual, Warranty Card
Compatible with
DELTA 2 / DELTA Max 2000/ DELTA 2 Max
