New EcoFlow DELTA 2 Portable Power Station - EcoFlow Europe
EcoFlow Europe
Starting at €49 91/payment over 12 payments with 0% APR from Alma. Learn more
Hot
30 Days Price Guarantee
Hot
Regular price €599.00
Sale price €599.00 Regular price €599.00
Save up to €100.00
Tax excluded.
Days
Hours
Minutes
Seconds
Autumn Sale × EcoCredits Week: Earn Up to 2.5× EcoCredits!
Learn More>>
  • 1-3kWh Expandable capacity
  • Huge AC output
  • 7x Faster AC charging
  • Or go green without sacrificing speed
  • Built to last 6x longer
  • Control from anywhere
  • 5-Year warranty
€599.00
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you’ve got access to free energy anywhere.
Built to last 6x longer.
Finally… tech that’s made to last. Get years of regular use until hitting 80% of its original capacity. That’s down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Safety first
DELTA 2's built-in battery management system regulates vitals to keep it safe, secure, and built to stand the test of time.
Ready for emergencies.
Control from anywhere.
1.DELTA 2 2.AC charging cable 3.User manual 4.App quick start guide 5.Warranty card
* The solar to XT60i charging cable is not included in 175W Rigid Solar Panel bundle.
Click here to get a solar to XT60i charging cable.
1024 Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
* Source:
Amazon.de/fr/uk Best Seller of Outdoor Generators Category dated September 16-19, 2022
Best Seller of Garden Category on Amazon.de dated September 16, 2022
Thanks for subscribing!
4. Upload the Image
