EcoFlow DELTA 3 Classic (1024Wh) Portable Power Station | EcoFlow EU – EcoFlow Europe
EcoFlow Europe
Starting at €49,91/payment over 12 payments with 0% APR from Alma. Learn more
Regular price €599,00
Sale price €599,00 Regular price €599,00
Save up to €50
- 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2400W such as portable fridges, camping kettles, laptops, and power tools.
- 3 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging.
- Lightweight, Compact, Portable: Fits seamlessly into outdoor, mobile, and professional setups.
- 10ms Fast Emergency Power Switching: Maintain continuous operation of critical outdoor and mobile equipment during power transitions.
- 30dB Whisper-Quiet Operation: Ultra-low noise ≤30dB at 600W.
- Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
- OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
- Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
€599
EcoFlow’s Best-Value 1 kWh Portable Power Station
Smart choice for your outdoor adventures and work
1800W Output, 3600W Surge
Power Essentials Without Compromise
EcoFlow DELTA 3 Classic delivers a steady 1800W pure sine wave output with grid-level stability—built to handle demanding outdoor and professional equipment with confidence. [2] With X-Boost™ mode, it supports devices up to 2400W without tripping or slowing down—giving you seamless power for the moments that matter.
Camping
Outdoor Filming
Outdoor Work
Camping
Camping
Outdoor Filming
Outdoor Filming
Outdoor Work
Outdoor Work
X-Stream: Ready in Just 45 Mins
DELTA 3 Classic (1024Wh) charges from 0–80% in just 45 minutes with AC charging. It keeps you powered faster, smarter, and with greater peace of mind—whether outdoors or on the move. X-Stream enables ultra-fast charging without compromising battery life. It intelligently adjusts voltage and power to ensure safe, high-speed recharging. With X-Stream, you’re ready in just 45 minutes. [3]
3 Ways to Charge—Anytime, Anywhere
AC Charging
Car Charging
Fully charged in 2.5 hours with 500W solar input. Clean, renewable energy—wherever the sun shines.
Charge to 80% in 1.8 hours or 100% in 2.5 hours using the EcoFlow 500W Alternator Charger. [5]
Compact, Portable — Works Anywhere You Go
Lightweight and easy to carry, DELTA 3 Classic fits seamlessly into outdoor, mobile, and professional setups.
Take it with you for camping, field work, filming, or any situation where reliable portable power is essential.
Fast Emergency Power Switching. No Interruptions.
When the power source changes, DELTA 3 Classic responds in as fast as 10 milliseconds—helping maintain continuous operation for critical outdoor and professional equipment. Designed to reduce interruptions during power transitions, it supports stable performance for sensitive devices in mobile and field environments.
10-Year Lifespan, Built to Last
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.[1]
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Explore EcoFlow 1kWh Power Stations
DELTA 3 Classic
Best Value for Outdoor Adventures
€599,00
€599,00
DELTA 3
Versatile Power for Home & Outdoor
€749,00
€899,00
DELTA 3 Plus
High-Performance Power for Home & Outdoor
€849,00
€999,00
1024Wh
1024Wh
1024Wh
Dimension
398mm × 200mm × 283mm
Approx. 397.6 × 202 × 283.6mm
Weight
12.1kg±0.3kg
Approx. 12.5kg
Approx. 12.5kg
1800W
1800W
1800W
USB Ports
USB-A: 1 × 18W Max
USB-A: 2 × 18W Max
USB-C: 2 × 100W Max
USB-A: 2 × 36W Max
USB-C: 2 × 140W Max
12V DC Output Port
NO
YES (Car Power Output
and DC5521)
and DC5521)
Outlets
5
13
13
AC Input (Charge Only)
1400W
1500W
1500W
Maximum PV Input Power(W)
500W
500W
1000W
Storm Guard Mode
YES
YES
YES
Expandable Battery
NO
YES. 1-5kWh
YES. 1-5kWh
What's in the Box
What's in the Box
What's in the Box
DELTA 3 Classic
Color
Gray
1024 Wh
12.1kg+0.3kg
398*200*283mm
Total Output Ports
5
Number of AC Outlets
3
Max Output
1800W
Surge Output
3600W
Max Output by X-Boost
2400W
Output Voltage
230V
UPS
10ms
USB-A-Fast
1*12W
USB-C
1*100W +1*30W
12V DC Output
NO
AC Charging
1400W (60 mins)
500W Max
Generator charging
1400W
Number of Extra Battery Ports
NO
Wi-Fi
YES
Bluetooth
YES
App
YES
3+2 years (Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration)
Noise
600W < 30dB
1200W < 40dB
Operating Altitude
3000m
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C-45°C
Storage Temperature
-10°C to 45°C
1. Based on proper product usage, DELTA 3 Classic is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
2. Single-appliance runtime based on ideal conditions; actual results may vary.
3. All Charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow 500W Alternator Charger is sold separately.
6. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
7. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
8. Compared with the previous usage of EF #C33 Battery Cell.
9. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
10. Noise levels measured at 0.5m under 25°C ambient: <30dB (600W) for charging/discharging.
11. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
EcoFlow DELTA 3 Classic Promotion Terms & Conditions
The EcoFlow DELTA 3 Classic Launch Promotion runs from 16 March 2026, 9 AM (CET) to 15 April 2026, 9 AM (CET) (hereinafter referred to as the "Promotion Period"). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The promotion is open to all European residents aged 18 years old and above as of 15 April 2026, 9 AM (CET)
Get 50% Off Solar Panel and 500W Alternator Charger
1. Customers who place a DELTA 3 Classic order during the Promotion Period will have a chance to add one EcoFlow 160W Solar Panel or 500W Alternator Charger at 50% off discount in the same bundle.
2. Full-priced items cannot be cancelled or returned separately. You must cancel and return the discounted products at the same time. If you need to keep the accessories, you will be charged at the original price.
General
(1) If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
(2) To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion. Fraudulent activities includ but not limited to automated entries, multiple registrations under different accounts, or fraudulent behaviour.
(3) Participants in the sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
(4) During the Campaign Period, all orders must comply with EcoFlow's purchase agreement and return policy.
(5) The sale promotion is not applicable to wholesale or distributor orders.
(6) Any unauthorized or fraudulent behaviour will result in disqualification of participants.
(7) Participants must comply with all applicable laws and regulations.
(8) EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
(9) All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
(10) EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
(11) EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with, or arising from acts or omissions, or any way related to this campaign.
(12) EcoFlow shall not be liable for indirect or consequential losses arising from participation, except in cases of willful misconduct, gross negligence, or where liability cannot be excluded by law.
(13) EcoFlow reserves the right to cancel any order in case of pricing errors or fraudulent use.
(14) EcoFlow reserves the right to withdraw any benefits or discounts obtained.
(15) Employees of EcoFlow, its affiliates, and their family members are not eligible to participate.
Thanks for subscribing!
4. Upload the Image
