EcoFlow DELTA 3 Max Series Solar Generator (PV220W) | EcoFlow EU – EcoFlow Europe
EcoFlow Europe
Starting at €166 41/payment over 12 payments with 0% APR from Alma. Learn more
30 Days Price Guarantee
Regular price €1,997.00
Sale price €1,997.00 Regular price €2,097.00
Save up to €200.00
Days
Hours
Minutes
Seconds
Autumn Sale Is Coming | Sep 7–13 | Find the Hidden ⚡
Learn More>>
- Industry-leading 3000W AC output, 6000W surge output
- Industry-First Full-Tab LFP Cells, exclusive smart BMS with 24/7 protection
- Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
- Up to 23% conversion with a unique bifacial design to guarantee a fast solar charging speed
Model
Accessories
Accessories
€1,997.00 €2,097.00 -€100.00
Capture More Energy with a Dual-Sided Design
With a 220W primary side and a 175W side on the back for ambient light, you can capture up to 28% more solar energy and charge your DELTA 3 Max/DELTA 3 Max Plus even faster.
Generate Even More Energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%.Allows more energy intake in less time charging for DELTA 3 Max/DELTA 3 Max Plus.
Capture More Solar with an Adjustable Angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees,
in seconds to get the most sunshine at all times.
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
DELTA 3 Max
DELTA 3 Max Plus
Specs - DELTA 3 Max & DELTA 3 Max Plus
Color
DELTA 3 Max - Black and Gray
DELTA 3 Max Plus - Silver
2048Wh
DELTA 3 Max - Approx. 20.3 kg
DELTA 3 Max Plus - Approx. 22.1 kg
DELTA 3 Max - 494 × 239 × 305 mm
DELTA 3 Max Plus - 494 × 242 × 305 mm
Total Output Ports
DELTA 3 Max - 9
DELTA 3 Max Plus - 10
Number of AC Outlets
4
Output Priority
DELTA 3 Max - NO
DELTA 3 Max Plus - YES
Max AC Output
DELTA 3 Max - 2400W
DELTA 3 Max Plus - 3000W
Surge Output
DELTA 3 Max - 4800W
DELTA 3 Max Plus - 6000W
Max Output by X-Boost
DELTA 3 Max - 3200W
DELTA 3 Max Plus - 3900W
X-Fusion
DELTA 3 Max - NO
USB-A
1 × 18W Max
USB-C
DELTA 3 Max - 1 × 100W Max(HID); 2 × 30W Max(Total 30W)
DELTA 3 Max Plus - 1 × 140W Max(HID); 2 × 45W Max(Total 45W)
12V DC Output
DELTA 3 Max - 126W Max; Car Power Output × 1:12.6V⎓10A
DELTA 3 Max Plus - 378W Max; Car Power Output × 1:12.6V⎓10A; Anderson Output × 1:12.6V⎓30A
AC Charging
2300W (68 min)
DELTA 3 Max - 500W
DELTA 3 Max Plus - 1000W
Generator Charging
2400W Max
Alternator Charging
DELTA 3 Max - 500W Max (Through XT60 Port)
DELTA 3 Max Plus - 1000W Max (Through 4+8 Port)
Car Charging
12V/24V⎓8A
Number of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 1 (expandable to 2)
Type of Extra Battery Ports
DELTA 3 Max - NO
DELTA 3 Max Plus - 4+8
Compatible Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - DELTA 2 Max/DELTA 3 Max Plus/DELTA Pro 3/DELTA 3 Extra Battery
Max Capacity with Extra Battery
DELTA 3 Max - NO
DELTA 3 Max Plus - Up to 10kWh
UPS
DELTA 3 Max - 10ms
DELTA 3 Max Plus - 10ms + HID
Wi-Fi
YES
Bluetooth
YES
App
YES
3+2 years
Noise
600W ≤ 25dB
Operating Altitude
≤3000m
Discharge Temperature
-10 to 45°C
Charge Temperature
0-45℃
Storage Temperature
-10 to 45°C
Specs - 220W Bifacial Portable Solar Panel
Rated Power
220W (±5W) Front/175W Rear
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 7.0kg
Unfolded: 615 x 2155 x 25 mm
Folded: 615 x 590 x 32 mm
Connector Type
Photovoltaic connectors
24 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A) Front Side/ 9.9A (Imp 9.5A) Rear Side
Waterproof & Dustproof
Thanks for subscribing!
4. Upload the Image
