EcoFlow DELTA Max Solar Generator (Rigid PV100W) – EcoFlow Europe EcoFlow DELTA Max Solar Generator (Rigid PV100W) - EcoFlow Europe
EcoFlow Europe
🔥Black Friday Sale
Regular price €19,99
Sale price €19,99 Regular price €19,99
Save up to €360
Secure your power supply with an EcoFlow DELTA Max solar generator bundle at home. Plug in 100W Rigid Solar Panels and get up to 800W input to charge from anywhere in as fast as 3 hours.
 The Portable & Expandable Home Battery - DELTA Max expands up to 6kWh with Smart Extra Batteries, keeping your home powered on in any emergency.
 Rapid Dual Charging - X-Stream tech means that DELTA Max charges 7times faster than the competition. That’s 0–80% in just 65 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 3 hours with 8 x 100W rigid solar panels.
 Fast Charging - Using cutting-edge cell technology, the 100W rigid solar panel has a high conversion efficiency rating of up to 23%, charging your Power Kits batteries in record time.
 Installation-ready - Pre-drilled slots around the panel's edge make it convenient to mount securely on your van’s roof.
 Weatherproof & Durable - The rigid panel balances design with robust materials allowing the panel to weather any storm while still offering the same excellent performance and aesthetics for years.
 Universally compatible - With an all-inclusive solar connector, the 100W rigid panel works with other 3rd party solar systems and power stations.
Model
Number of Solar Panel
Option of Extra Battery
Stay Tuned!
Expandable Capacity
Dual Charging
Power multiple devices
800W max Solar Input
Expandable home backup power.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 8x 100W rigid solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
What's in the box - Without Extra Battery
1. DELTA Max 2. AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User Manual and Warranty card 6. 100W Rigid Solar Panel* 8. Solar to XT60 Charging Cable 9. Support Brackets
*The number of Solar Panels depends on the bundle you order.
*An additional Solar Parallel Cable will be provided with the bundle of 6 solar panels.
What's in the box - With Extra Battery
1. DELTA Max 2. AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User Manual and Warranty card 6. 6×100W Rigid Solar Panel 8. Solar to XT60 Charging Cable 9. Support Brackets 10. DELTA Max Smart Extra Battery
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistant, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
