Powerful Yet Simple: DELTA Pro 3 | EcoFlow Europe Powerful Yet Simple: DELTA Pro 3 | EcoFlow Europe - 0% VAT (Only DE) DELTA Pro 3 + PowerStream Microinverter 800W (with battery cable) - EcoFlow Europe
EcoFlow Europe
€2.881,00
Regular price €2.881,00
Sale price €2.881,00 Regular price €3.440,00
Save up to €1.041
Tax excluded.
  • Powerful and Versatile - 4000W single-unit output to power almost all of your home appliances.
  • Expandable Capacity - 4–12kWh, tailored to your energy needs.
  • Quiet Operation - With a volume as low as 30 dB (under 2000W).
  • Easy to Use - Plug-and-play design for hassle-free setup.
  • Fast Charging - Charges 80% in just one hour.
  • Multiple Charging Methods - Supports combo charging methods for maximum flexibility.
Note: The Solar Panel Mounting Feets are not included.
DELTA Pro 3 Accessories >>
EcoFlow DELTA Pro 3 Solar Home Battery System
€3.428,00 €3.440,00
4-8kWh capacity | 3400W Solar Input | 4800W Output
EcoFlow 400W Rigid Solar Panel (2 pieces)
€335,00 €599,00
23% Conversion Rate
€335,00 €599,00
23% Conversion Rate
EcoFlow Solar Extension Cable
€41,18 €49,00
Commonly used
solar connector
Length: 3m
EcoFlow Super Flat Cable
€15,97 €19,00
Length: 0.5 m Thickness: 1.5 mm
EcoFlow Rigid Solar Panel Mounting Feet
€15,00
EcoFlow PowerStream Microinverter 600W/800W
€99,00 €141,00
Up to 800W Solar Input
Grid-Tied Hybrid Inverter
€335,00 €599,00
23% Conversion Rate
€335,00 €599,00
23% Conversion Rate
€335,00 €599,00
23% Conversion Rate
€335,00 €599,00
23% Conversion Rate
€41,18 €49,00
Commonly used
solar connector
Length: 3m
€15,97 €19,00
€15,00
€41,18 €49,00
Commonly used
solar connector
Length: 3m
€15,97 €19,00
€15,00
€335,00 €599,00
23% Conversion Rate
€2.881,00 €3.440,00 -€559,00
Energise Every Moment That Needs Electricity
For Home Use
For RV Use
For Off-grid Use
For On-site DIY Projects
For Outdoor Adventures
Keep Your Home Running Smoothly
Ensures Essential Appliances
Keep Working
Expandable Capacity
up to 12kWh
A Comprehensive
10 ms UPS
A single source to power almost all of your essential home appliances. Power high-demand appliances—from 3 ton* central AC to 1 HP water pump—with robust 4000W output.
Keep your kitchen buzzing and essential systems like garage doors running, all powered simultaneously and reliably by EcoFlow.
*Tested under controlled laboratory conditions with central AC soft starter.
Easily run multiple appliances at the same time.Connect in parallel to expand power up to 12,000W, supporting multiple high-power appliances simultaneously.
No constant unplugging or switching required.
Safeguard your data. It ensures swift 10 ms switch-overs, protecting your NAS systems, servers, and entertainment devices from power disruptions and keeping your technology safe and continuously powered.
Silent as a Whisper
Quiet Comfort for Your Home and Neighbours
It's whisper-quiet with X-Quiet technology, ensuring a peaceful hum*, promising you a night of peaceful sleep even if you keep it beside your bed.
It's so silent that you'll hardly notice it's there.
*As low as 30 dB
Charge Fast, Everywhere
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0-80% in just one hour.
With multi-charge combinations, enjoy up to 7000W of super-fast charging.
6 unique methods to meet your charging needs anywhere, anytime
Two Ways to Flexibly Connect EcoFlow DELTA Pro 3 to Your Home
EcoFlow DELTA Pro 3, PowerStream Microinverter and solar panels create a solar home battery system for grid-connected use. With the industry-leading SolarDualCharge* and DualPower** features, the system can achieve true power independence.
*Simultaneous solar input from both PowerStream Microinverter (800W input) and EcoFlow DELTA Pro 3 (2600W input)
**Power your home simultaneously through PowerStream Microinverter (800W output) and EcoFlow DELTA Pro 3 (4000W output)
Learn more about the system
Manual Transfer Switch
The Manual Transfer Switch* allows you to seamlessly switch between a utility power source and a portable power station at any time. At night, by fully transitioning to the EcoFlow DELTA Pro 3 with the Manual Transfer Switch, you can utilise the solar energy stored during the day to go off-grid and reduce your electricity costs.
*The setup requires a licensed electrician or a qualified professional.
*Instruction Leaflet
State-of-the-art LFP Tech
BMS powered by
ground-breaking X-Guard
Revolutionising Durable Construction
5 Years Warranty,
Zero Worries
Crafted with automotive-grade LFP cells, the EcoFlow DELTA Pro 3 features the industry's first IP65-rated battery pack, ensuring resilience against impacts, water, dust, and fire risks. With 4000 cycles to 80%, that's power every day for 11 years*.
Experience dependable performance in any weather, ensuring peace of mind in every situation.
*Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 25℃ conditions
Trust the Battery Management System powered by X-Guard to monitor your battery's 40 safety indicators 24/7, providing warnings and active protection around the clock. Manage it all through the app for smart, secure energy.
Our pioneering Cell-to-Chassis (CTC) integration fortifies the EcoFlow DELTA Pro 3. This design, combined with a UL-certified 5VA grade fireproof shell, redefines industry standards for resilience and protection.
Outlasting and outperforming, we offer a 5-year warranty across the board, surpassing traditional gas generators and aligning with the elite in portable power. Experience streamlined support from our customer service, ensuring swift solutions and minimal downtime. It's our commitment to quality, redefined.
Effortless All-in-One Command with the EcoFlow App
What's in the box - EcoFlow DELTA Pro 3
EcoFlow AC Charging Cable
Grip Protector
Grip Protector
Quick Start Guide
Quick Start Guide
Safety Guide
Safety Guide
Warranty Card
Warranty Card
What's in the box - EcoFlow DELTA Pro 3 Smart Extra Battery
EcoFlow Extra Battery Flat Link Cable (0.85 m)
Quick Start Guide
Quick Start Guide
Safety Guide
Safety Guide
Warranty Card
Warranty Card
Specs - EcoFlow DELTA Pro 3
4096Wh
5 outlets, 4000W max. (Surge 8000W)
USB-A Fast Charge
USB-A×2, 5V 2.4A 9V 2A 12V 1.5A 18W max
12V DC Output
12.6V/30A 378W total
DC5521 × 1, 5A max.
Anderson Port × 1, 30A max.
Solar Charging Input
2600W, 2 ports:
HPV: 30-150V/15A, 1600W max.
LPV: 11-60V/20A, 1000W max.
Connection
Wi-Fi 2.4GHz/Bluetooth/CAN
693×341×410 mm
4000W, 6000W (X-Boost)
Supports up to two DELTA Pro 3 Smart Extra Batteries / DELTA Pro Smart Extra Batteries
6000W
USB-C × 2, 5/9/12/15/20V 5A 100W max.
AC Charging Input
200-240V~12.5A,50/60HZ
2900W max.
Car Charging Input
12V 8A max.
48V 20A max.
4000 cycles to 80% capacity
51.5 kg (113.54 lb)
Specs - EcoFlow DELTA Pro 3 Smart Extra Battery
4096Wh
Output Port
40V-58.4V=100A Max
Weight
33 kg
Compatible with
EcoFlow DELTA Pro 3
Discharge Temperature
-10°C ~ 45°C
Storage Temperature
-10°C ~ 45°C
Input Port
40V-58.4V=80A Max
Dimension
694mm×295mm×215mm
What’s in the box
1. EcoFlow Delta Pro 3 Smart Extra Battery
2. Quick Start Guide
3. Safety Guide
4. Warranty Card
5. EcoFlow Extra Battery Cable
Dispaly
LED Array
Charge Temperature
0°C ~ 45°C
DELTA Pro vs. DELTA Pro 3
Compared to the DELTA Pro, the DELTA Pro 3 is much quieter, has more capacity, higher charging efficiency, greater portability, and a space-saving Extra Battery design.
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.
High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Can EcoFlow DELTA Pro 3 be used with an EV charger?
Yes, it supports Level 1/2 EV chargers. You will need to purchase a dedicated EcoFlow adapter, the EV X-Stream Adapter (DELTA Pro Ultra).
Typyically, the grid charging port on the US model only supports AC 120V 2000W charging (Level 1). However, by using the AC POWER IN/OUT port along with the EV X-Stream Adapter (DELTA Pro Ultra), you can connect a 240V EV charger, increasing the charging rate to 4000W (Level 2).
If connected to solar panels, will EcoFlow DELTA Pro 3 automatically turn on while turned off?
Yes, however, there are specific requirements for the light conditions.
In weak lighting environments, it might not trigger the device to power on.
EcoFlow Smart Generator (Dual Fuel)
EcoFlow DELTA Pro to Smart Generator Adapter
EcoFlow PowerInsight Home Energy Manager
EcoFlow WAVE 2
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro Series)
EcoFlow DELTA Pro Remote Control
How long is the cycle life of EcoFlow DELTA Pro 3?
4000 cycles. After 4000 cycles at a rate of 0.5C/0.5C at 25°C, the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°C
Charging temperature range: 0℃-45℃
Discharge temperature range: –10℃-45℃
Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.
However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device.
Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs.
When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, it is supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
What is a Manual Transfer Switch?
A Manual Transfer Switch allows you to safely connect a portable power station to your home's electrical system at any time.
Can I install a Manual Transfer Switch myself?
Installation should be done by a licensed electrician or a qualified professional.
How do I test the Manual Transfer Switch to make sure it is working properly?
You should consult with a licensed electrician to perform a load test to ensure it is working properly and all circuits are properly connected.
EcoFlow DELTA Pro 3 Compatiblity*
*Please note that EcoFlow DELTA Pro 3 is not compatible with EcoFlow DELTA Pro.
EcoFlow DELTA Pro 3 Solar Home Battery System Preheat Campaign Terms & Conditions
The EcoFlow DELTA Pro 3 Solar Home Battery System Preheat Campaign runs from 12 August 2024, 9 AM (CET) to 6 September 2024, 9 AM (CET). EcoFlow reserves the right to shorten or extend the campaign period at its sole discretion without prior notice.
Eligibility
The campaign is open to all European citizens aged 18 years and above as of 9 AM (CET) on 12 August 2024.
Campaign Details
1. By providing your email address and subscribing, you agree to the Email Marketing Terms & Conditions, subscribe to EcoFlow marketing emails, and consent to receive updates from EcoFlow.
2. The first 200 orders of EcoFlow DELTA Pro 3 and its bundles placed between 9 AM on 6 September and 9 AM on 6 October will receive a complimentary EcoFlow Single Axis Solar Tracker. Each order is limited to one EcoFlow Single Axis Solar Tracker.
3. The above-mentioned first 200 orders are counted within the following 5 official EcoFlow websites: eu.ecoflow.com, de.ecoflow.com, fr.ecoflow.com, it.ecoflow.com, es.ecoflow.com. A total of 200 gifts will be given away across the 5 websites. The start of the count is based on the website's announcement of the EcoFlow DELTA Pro 3 launch time. The eligible orders are sorted in the chronological order of payment.
4. Of these first 200 orders for the DELTA Pro 3 and its bundle mentioned above, if the purchaser has subscribed to marketing emails about the EcoFlow DELTA Pro 3 on this preheat event page https://eu.ecoflow.com/pages/delta-pro-3-portable-power-station-preheat from 9 AM on 12 August to 5:59 AM on 6th September and remains as subscriber when the order is placed, the purchaser will be eligible to the exclusive benefits for subscribers: a free EcoFlow Single Axis Solar Tracker and a two-year extended warranty for the purchased EcoFlow DELTA Pro 3. Each email address is eligible to receive the benefit of the two-year extended warranty on only one purchased EcoFlow DELTA Pro 3. The email address used by the purchaser to place the order must be the same as the email address used to subscribe to the EcoFlow DELTA Pro 3 marketing emails during the preheat period and must remain subscribed at the time of payment and within 24 hours of payment. If the purchaser unsubscribes at the time of payment and within 24 hours of payment, they cannot receive the confirmation email for the extended warranty benefits.
5. Once 200 qualifying orders have been placed, the special offer for the first 200 purchases will automatically end without further notice on the website.
6. If the order is eligible for the EcoFlow Single Axis Solar Tracker, the gift will be automatically added to the order within 24 hours of payment. The purchaser can check the order update email after 24 hours of payment, or register for an EcoFlow account and then log in to https://account.ecoflow.com/login?return_to=eu.ecoflow.com/ to confirm that the gift has been added to the eligible order.
7. Each email address is eligible to receive the benefit of the two-year extended warranty on only one purchased EcoFlow DELTA Pro 3. If the order is qualified for a 2-year extended warranty on the purchased EcoFlow DELTA Pro 3, the customer will receive a confirmation email within 24 hours of placing the order, issuing the 2-year extended warranty benefit for one EcoFlow DELTA Pro 3 in the order. If this email is not received, please check the spam folder. If still not received, please contact our customer service team at support.eu@ecoflow.com to verify order eligibility and issuance of the extended warranty. The purchaser can check the order update email after 24 hours of payment, or register for an EcoFlow account and then log in to https://account.ecoflow.com/login?return_to=eu.ecoflow.com/ to confirm that the 2-year extended warranty has been added to the eligible order. The 2-year extended warranty shown on the order page is a virtual product that will not be issued physically. Please protect your warranty information such as SN code, proof of purchase (invoice), and extended warranty issuance email from being leaked. EcoFlow is not responsible for any financial loss due to leakage of warranty information caused by customers.
8. If a refund is issued for the original order, the gift (EcoFlow Single Axis Solar Tracker) must be returned, and the two-year extended warranty for the EcoFlow DELTA Pro 3 (available exclusively to subscribers during the preheat campaign) will be invalidated. No separate notice of invalidation will be provided.
General:
1. If you encounter any problems during the promotion, please contact support.eu@ecoflow.com for assistance.
2. To the extent permitted by applicable law, we may decide to modify these rules or cancel the promotion at any time. If there is any fraud or abuse related to the promotion, we reserve the right to exclude any customer from the promotion.
3. Participants in the Sale agree to be bound by the terms and conditions set forth herein and understand that EcoFlow's decisions are final and binding. No correspondence or appeals will be entertained. EcoFlow reserves the right to make the final and ultimate interpretation of this campaign.
4. All orders must comply with EcoFlow's purchase agreement and return policy during the sale promotion.
5. The sale promotion does not apply to wholesale or distributor orders.
6. Any unauthorized or fraudulent behaviour will result in the disqualification of participants.
7. Participants must comply with all applicable laws and regulations.
8. EcoFlow reserves the right to stop, cancel, or change the promotion at any time during the promotion. Any changes will be announced on the EcoFlow official website.
9. All prizes in this promotion are limited in quantity and are available on a first-come, first-served basis. Any matters not covered herein will be handled according to EcoFlow's final interpretation.
10. EcoFlow will assume no responsibility for late entries, which may occur for any reason, including but not limited to network transmission failure.
11. EcoFlow will not be responsible for any direct or indirect losses or damages incurred by any party, including the participants, in connection with or arising from acts or omissions or any way related to this campaign.
12. Participants agree to release and discharge EcoFlow from any liabilities and claims, including breach of contract, tort, negligence, or any other cause of action at law or equity, arising out of or in any way connected to this campaign or the participant's entry into the campaign.
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
