EcoFlow DELTA Pro Smart Extra Battery – EcoFlow Europe EcoFlow DELTA Pro Smart Extra Battery - 0% VAT (Only Germany) DELTA Pro Extra Battery + PowerStream Microinverter 800W - EcoFlow Europe
EcoFlow Europe
€1.689,00
Regular price €1.689,00
Sale price €1.689,00 Regular price €2.189,00
Save up to €500
Tax excluded.
0% VAT on PowerStream Microinverter and DELTA Pro Extra Battery, only for orders with a delivery address in Germany.
  • Level up with the EcoFlow PowerStream Balcony Solar SystemPair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
  • Expand capacity up to 10.6kWh with 2 extra batteries
  • Long-lasting LFP battery
*Note: This product is exclusively for the EcoFlow DELTA Pro portable power station.
Stay Tuned!
€1.689,00 €2.189,00 -€500,00
Make it a triple.
Double or triple the capacity of your DELTA Pro to 7.2kWh or 10.8kWh. That’ll give you days of power for your essential appliances.
Charge anytime, anywhere.
DELTA Pro’s Smart Extra Battery benefits from all the charging methods DELTA Pro has, including 6500W MultiCharge. That means you can charge anytime, anywhere as long as your extra battery is connected to DELTA Pro. Once connected, they’ll charge/discharge in unison, keeping the battery percent level across both units.
Ready for any emergency.
When the going gets tough and you’re out of charge options, get a 1800W DC fast charge with EcoFlow Smart Generator (sold separately). Just plug the generator directly into your extra battery via the port on the back. This works even when disconnected from your DELTA Pro.
Stay informed.
The Smart Extra Battery sports a bright LCD screen on the front of the unit giving you all the info you need. Output, input, remaining charge and time remaining. It’s all there. Need on the go info? The EcoFlow app can tell you all that & a whole lot more.
1.DELTA Pro Smart Extra Battery 2.DELTA Pro Extra Battery Cable 3.Handle Cover 4.User Manual
For each DELTA Pro unit, you can link an extra two batteries, bringing you up to 10.8kWh of capacity.
DELTA Pro’s Smart Extra Battery can be monitored from the EcoFlow app, allowing you to monitor & control your batteries from afar.
Yes, you can when using the Smart Generator as part of your ecosystem. For other charging methods, you should connect your Smart Extra Battery to the DELTA Pro unit first.
The charge speed varies depending on your chosen charge method. But in short, it charges fast. The fastest way to charge is by utilizing MultiCharge to reach a 6500W charge speed. With that, you can charge both your DELTA Pro and the extra battery in <2 hours. And via a standard AC wall outlet, you can expect a full charge in 2.7 hours assuming your DELTA Pro unit is fully charged.
Model Name
3600Wh
Battery Cycle Life
Dimension
25 x 11.2 x 16.4 in / 63.5 x 28.5 x 41.6 cm
Weight
Approx. 84lbs / 38kg
Customer Reviews
Based on 2 reviews
100%
(2)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
L
Loretta B.
The best
G
German B.
You service in good level.
