EcoFlow RIVER 2 Pro Solar Generator (PV220W) – EcoFlow Europe EcoFlow RIVER 2 Pro Solar Generator (PV220W)
EcoFlow Europe
€948,00
30 Days Price Guarantee
Regular price €948,00
Sale price €948,00 Regular price €948,00
Days
Hours
Minutes
Seconds
🔥STREAM Series Earth Day Sale | 10–26 April
  • With 768Wh capacity and 220W solar input, the solar generator can produce up to 1.8kWh daily.
  • A 1600W output with X-Boost mode on to power up to 80% of high-wattage home appliances.
  • Charges from 0-100% with AC input in only 70 min with upgraded X-Stream tech.
  • An industry-leading 23% conversion rate with a unique two-in-one bifacial design to guarantee a fast solar charging speed: 0-100% in 4.3 hours (1 set).
  • LiFePO4 battery and IP68 dust and water resistance. It is safe and reliable for long-term use.
  • Lightweight, travel-friendly.
  • Smart remote control from anywhere with EcoFlow app.
  • 5-year warranty for RIVER 2 Pro and 12-month warranty for 220W Bifacial Portable Solar Panel.
Preorder now, shipment starts from September 19th, 2025.(220W Solar Panel)
€948,00
The most easy-to-use independent solar power system. Take it to camping or RV trips with it. Have stable, durable, and reliable energy on hand whenever you need. Join hands with us in this energy-sharing world and live green.
Small size. Big power.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential appliances smoothly for almost half a day. You'll always be ready. Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 143kg. That's like planting 8 trees in a year!*
**Total Energy Consumption is for reference only, please refer to your actual daily electrical consumption.
Fastest charging speeds ever.
Ever worried about running out of power or annoyed by a sluggish recharge? Our MPPT algorithm monitors the voltage and current in real-time to give you optimum solar generation under varying conditions with over 98% efficiency, fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
Just plug and play.
Getting blackout-ready is easier than ever with our solar generators' plug-and-play design. Once connected via Bluetooth or Wi-Fi, it can be managed on the EcoFlow app even from afar.
4 Ways to Charge
Charge anywhere.
AC Charging
Car Charging
USB-C Charging
4. Upload the Image
