New EcoFlow DELTA 2 Portable Power Station - EcoFlow Europe New EcoFlow DELTA 2 Portable Power Station - EcoFlow Europe - EcoFlow Europe
EcoFlow Europe
€999,00
Hot
Hot
🏆Member's Festival
Regular price €999,00
Sale price €999,00 Regular price €999,00
Save up to €283,47
Up to EcoCredits for cash deduction
Tax excluded.
0% VAT on PowerStream Microinverter and DELTA 2 Power Station, only for orders with a delivery address in Germany.
Best Seller of Outdoor Generators & Garden on Amazon *
  • Level up with the EcoFlow PowerStream Balcony Solar System
    Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
  • 1-3kWh Expandable capacity
  • Huge AC output
  • 7x Faster AC charging
  • Or go green without sacrificing speed
  • Built to last 6x longer
  • Control from anywhere
  • 5-Year warranty
€999,00
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Learn More
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you’ve got access to free energy anywhere.
Built to last 6x longer.
Finally… tech that’s made to last. Get years of regular use until hitting 80% of its original capacity. That’s down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Safety first
DELTA 2's built-in battery management system regulates vitals to keep it safe, secure, and built to stand the test of time.
Ready for emergencies.
Control from anywhere.
1.DELTA 2 2.AC charging cable 3.Car charging cable 4.DC5521 to DC5525 cable 5.User manual 6.App quick start guide 7.Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
1024 Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
* Source:
Amazon.de/fr/uk Best Seller of Outdoor Generators Category dated September 16-19, 2022
Best Seller of Garden Category on Amazon.de dated September 16, 2022
Customer Reviews
Based on 18 reviews
89%
(16)
11%
(2)
0%
(0)
0%
(0)
0%
(0)
J
José M.M.
Excellent
Very satisfied! Excellent performance so far
Y
Yosyp S.
H
Heiki M.
P
Paul T.
Great unit, this has already helped us out during a power outage and kept out fridge running a whole day. Perfect weight/power balance. No need for heavy messy petrol generator
V
Vasyl
I recently purchased the Delta 2 power station along with three 100W solar panels to create an alternative source of energy for my house. I utilize the station to generate solar energy during the sunny parts of the day and then use it in the evening.
One of the standout features of the Delta 2 is its accompanying application, which allows for easy configuration and automation of the charging and discharging processes. The application has received numerous updates in recent releases, adding to its versatility. However, I did encounter a few issues.
Firstly, I noticed that after extended periods of charging the station with solar panels, there would be a miscalculation in the capacity. For example, the capacity might erroneously drop from 1kW to 500W. To resolve this issue, it was necessary to discharge the station completely to 0 percent. Once the station automatically restarted, it could be charged with the cable to reach 100 percent, at which point the capacity would be restored to 1kW. This periodic issue required some manual intervention.
The second and final issue I encountered was a dropped Wi-Fi connection when the station turned on automatically upon connecting to the solar panels in the morning. Consequently, it was not possible to connect to the station via the mobile app. To rectify this problem, I had to disconnect the solar cable and manually restart the station to restore the connection. This issue was particularly critical for me, as I couldn't monitor and control the station using the mobile application.
In general, the Ecoflow Delta 2 power station is an amazing tool for providing your house with an alternative energy source, particularly solar energy, or serving as an energy backup during blackouts. Despite the mentioned issues, I would still recommend this product, hoping that the software updates in future releases will address these concerns.
C
Customer
Everything would be nice if he had the capacity allowed.Unfortunately, it is only about 800wh.I use it for over half a year to charge my many batteries.Electric bicycle, Makita 5 bat and others, also for watching TV, washing the car and other necessary things.
Ecocredits
EcoCredits Program
Become a member to earn EcoCredits and exclusive rewards every time you shop!
EcoCredits Appreciation Week
How to Earn EcoCredits
Register and Subscribe
1000 EcoCredits
Shop
1 EcoCredit for every €1 spent
Earn every time you order.
Refer a Friend
Up to 3000 EcoCredits
1000 EcoCredits
Profile
1000 EcoCredits
Get Rewards
Coupons
€5
100 EcoCredits
€10
200 EcoCredits
€25
500 EcoCredits
€50
1000 EcoCredits
€100
2000 EcoCredits
€200
4000 EcoCredits
Gift
EcoFlow Badge
1199 EcoCredits
EcoFlow Camping Mat
5499 EcoCredits
EcoFlow Camping Light
4599 EcoCredits
EcoFlow Smart Plug
5999 EcoCredits
EcoFlow Flatbed Trolley
7449 EcoCredits
EcoCredits Week
Highlights of the EcoCredit Appreciation Week event:
7 days member-only discounts
Success!
* I agree to EcoFlow's Privacy Policy and Terms of Service.
