EcoFlow DELTA 3 Series Portable Power Station - EcoFlow Europe EcoFlow DELTA 3 Series Portable Power Station - EcoFlow Europe - EcoFlow Europe
EcoFlow Europe
€899,00
EcoFlow 2025 Members' Festival 🎉
Regular price €899,00
Sale price €899,00 Regular price €899,00
Save up to €188
Tax excluded.
  • Expandable 1-5 kWh capacity with DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, DELTA 2 Extra Battery, or DELTA 2 Max Extra Battery.
  • 1800W AC output, with 2400W (3600W surge) using X-Boost technology.
  • 5 fast recharging methods: AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multi-charging.
  • 5-year warranty.
Modell
Accessories
€899,00
AC
Solar
Car Charge
Multi-Charging
Generator
1500W AC Input, Full Charge in 56 Minutes[1]
Solar Input with 1000 MPPT, Full Charge in 70 Minutes[2]
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime. DELTA 3 with a 500W MPPT recharges in 2 hours.
On-the-Go with 800W Car Charge, Full Charge in 1.3 Hours[3]
Multi-Charging (AC + Solar), Full Charge in 56 Minutes with 1500W Input[4]
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritising solar to save money.
Hybrid Power with Generator, Full Charge in 56 Minutes with 1500W AC Input[5]
With 1500W input, it takes 56 minutes to fully charge. The EcoFlow Smart Generator 3000 (Dual Fuel) automatically replenishes power at night, ensuring constant backup without manual intervention (coming soon).
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2400W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home usage, RV, and outdoor usage, this solar battery ensures you're never left in the dark.
Powerful output,  imperceptible operation.
Powerful output,
Powerful output,  <br>imperceptible operation.
Powerful output,
Powerful output,
Powerful output,<br>  imperceptible operation.
RV
Home Use
Outdoors
Professional work
11 Outputs
Compact and lightweight
30 dB ultra-quiet operation
Completely imperceptible under 600W, blending with natural ambient noise (30 dB).
Whether you're in a tent or at home, it won't disrupt sleep.
Peace of mind for backup power, convenient for daily use
Ensure reliable backup for specialized equipment with a 10 ms UPS.[6]
LFP Battery
IP65 Battery Pack
BMS
Third-gen LiFePO4 (LFP) cells offer fast charging without sacrificing longevity. With 4000 cycles to 80% capacity[7], enjoy up to 10 years of reliable use, 25% above the industry standard.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5x the Power
Same power, more compact. Achieve 2kWh capacity with EcoFlow DELTA 3 Extra Battery (1kWh), making it 1/3 smaller and lighter than the DELTA 2 power pack.
When combined with the EcoFlow Ecosystem, it can be equipped with DELTA Pro 3 Extra Battery, allowing for a maximum expansion to 5kWh, which extends the backup power duration by 5 times.
Comparison of DELTA 3 Series and DELTA 2
DELTA 3
DELTA 3 PLUS
Specs - DELTA 3 & DELTA 3 Plus
Colour/ID
DELTA 3 - Silver & Grey
DELTA 3 Plus - Silver
1024Wh
≤12.5 kg
398×200×284 mm
D3 EB Dimensions
398×200×198 mm
App
Supported (TOU/Storm warning)
Extra Battery
Expandable capacity to 5kWh
DELTA 2 MAX/DELTA 2/DELTA Pro3/DELTA 3 Extra Battery Supported
Total Output Ports
11
AC × 4
4 × 1800W (Surge 3600W)
2400W
USB-A × 2 (Fast charging)
DELTA 3 - 2 × 18W Max
DELTA 3 Plus - 2 × 36W Max
USB-A × 2
USB-C × 2
DELTA 3 - 2 × 100W Max
DELTA 3 Plus - 2 × 140W Max
Car Power × 1
12.6V, 10A, 126W Max
DC5521 × 2
2 × 12.6V, 3A Max
AC
1500W (56 Min)
Solar
DELTA 3 - DC input 11V-60V1 × 500W Max (130 Min)
DELTA 3 Plus - DC input 11V-60V2 × 500W Max (70 Min)
Smart Generator
1500W (56 Min)
Car
800W (1.3 Hr)
AC+PV
1500W (56 Min)
Chemistry
DELTA 3 - 4000 Cycles to 80% Capacity
DELTA 3 Plus - 4000 Cycles to 80%
Waterproof level of battery pack
IP65
UPS
DELTA 3 - <10 ms
DELTA 3 Plus - <10 ms HID
Volume
600W <30 dB/1200W <40 dB
5 Years
Footnote:
[1-8] All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios
Customer Reviews
Based on 2 reviews
100%
(2)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
O
Oliver E.
Works like a charm
Really happy with my Delta 3. Perfect build quality, super nice with the upgrade to the display and the app view (compared to the older interface). Finally some more serious power input and output. Consider upgrading with additional batteries for more juice. Only thing I wish I knew before is, that its not the best use case to support low power devices on AC as you loose about 15 Watts or so due to the conversion.
M
Mark
The Superhero of Power Stations!
Ever wish you could laugh in the face of power outages? Want to flex on your friends during a camping trip by charging everything while they struggle with dead phones? Enter the EcoFlow DELTA 3 Series Portable Power Station, the Chuck Norris of battery packs.
Why Is This Thing So Cool?
Power for DAYS (Literally!) – With a base capacity of 1kWh (that’s a lot of zeroes), this bad boy can expand up to 5kWh. That means it can keep your fridge running, your TV on, and your coffee machine brewing – all while you pretend to be roughing it in the wilderness.
Charges Faster Than Your Coffee Cools Down – Thanks to some wizardry called X-Stream technology, this thing goes from 0-80% charge in just 1.6 hours. That’s faster than your morning motivation disappears!
It Eats High-Powered Appliances for Breakfast – Hair dryers? Microwaves? EV chargers? The DELTA 3 laughs at them all. With X-Boost tech, it handles up to 2600W without breaking a sweat. Your electric kettle and blender can finally live in harmony.
Multiple Ways to Charge – Plug it into the wall, hook up solar panels, charge from your car, or—if you're feeling fancy—an EV station. Because who doesn’t want their power station to be as versatile as a Swiss Army knife?
Lasts a Freakishly Long Time – This power beast has a 10-year lifespan, thanks to its LiFePO4 battery. Your phone won’t even last a fraction of that time.
The Good, The Bad, and The Funny
✅ Ultra Quiet – Runs at just 30dB when using 600W or less. That’s quieter than your cat plotting world domination at 3 AM.
✅ Perfect for Any Scenario – Blackouts? Camping? The zombie apocalypse? The DELTA 3 has your back.
❌ A Bit Heavy – It’s got power, but it’s not winning any marathons. Lifting this thing is your new workout plan.
❌ Pricey, But Worth It – Let’s just say it’s an investment. But hey, how much is never being powerless again worth to you?
Final Verdict
The EcoFlow DELTA 3 Series is like having a mini power plant in your home (without the explosions). If you love tech, hate blackouts, or just want the ultimate flex at your next outdoor trip, this is the power station for you.
Would recommend 10/10 – now excuse me while I plug in everything I own just because I can.
