EcoFlow DELTA Max Portable Power Station – EcoFlow Europe EcoFlow DELTA Max Portable Power Station - 0% VAT (Only DE) DELTA Max 2000 + PowerStream 800W - EcoFlow Europe
EcoFlow Europe
🌲Christmas Sales
Regular price
Sale price Regular price
Save up to €578
Tax excluded.
0% VAT on PowerStream Microinverter and DELTA Max Power Station, only for orders with a delivery address in Germany.
  • Level up with the EcoFlow PowerStream Balcony Solar System
    Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
  • 2-6kWh expandable capacity for home backup
  • Power heavy-duty devices with 2400W output
  • Charge 0-80% in just 65 minutes
  • Solar charge in as fast as 2.5 hours
  • Up to 3400W fast dual charging
  • Smart App control
Model
EcoFlow DELTA 2 Max / DELTA Max Cover
€89,00
€89,00
€89,00
€89,00
€89,00
€89,00
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 1 hour. And it gets even better. If you're looking for an even faster way to charge up DELTA Max, you can combine AC with the Smart Generator, AC with solar, or the Smart Generator with solar.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Works in Sync with EcoFlow PowerStream Balcony Solar System
Transform your power station into a grid-tied solar energy solution that combines solar panels, a power station, and a microinverter. Power your home and save on energy bills day and night.
Learn More
Multiple ways to charge.
AC Charging
Smart Generator
Car Charging
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
How many solar panels can I use at the same time withDELTA Max?
It depends on the total voltage and watts of solar panels youchoose. As long as the solar panels use MC4 connector and itsvoltage and current are under 11-100V, 13A max range.
What's the max input for DELTA Max?
How does the Emergency Power Supply (EPS) work?
What's the water-resistance rating for this product?
Specs of DELTA Max (2000)
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel, Smart Generator, Smart Extra Battery
Full Recharge Time
1.6 Hours (AC) 21 Hours (12V Car Charger) 5.6-11.2 Hours (Using 4x 110W Solar Panels) 4.2-8.4 Hours (Using 4x 160W Solar Panels) 3.2-6.3 Hours (Using 2x 400W Solar Panels)
2016Wh
Cell Chemistry
NCM
Cycle life
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
CE WEEE CTP RCM KC
AC Charge Input (Power)
X-Stream charge (2000W max)
AC Charge Input (Voltage and Amperage)
220-240V~50Hz/60Hz, 10A
Solar Charge Input
11-100V 13A Max, 800W max
Car Charge Input
Supports 12V/24V Battery, Default 8A
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Supports up to 2 DELTA Max Smart Extra Batteries (sold separately)
Smart Generator
Supported (sold separately)
Wi-Fi
Supported
Specs of DELTA Max (1600)
Dimension
Charge Temperature
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 16.8 Hours (12V Car Charger) 4.5-9 Hours (Using 4x 110W Solar Panels) 3.4-6.8 Hours (Using 4x 160W Solar Panels) 2.5-5 Hours (Using 2x 400W Solar Panels)
1612Wh
Cell Chemistry
NCM
Cycle life
500 Cycles to 80%+ capacity
Management Systems
CE WEEE CTP RCM KC
X-Stream charge (1600W max)
Solar Charge Input
Car Charge Input
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
12.6V/3A, per port
Smart Extra Battery
Smart Generator
Wi-Fi
Supported
Car charger shares power with the DC5521 output port offering maximum output of 126W.
Whether the product can be charged or discharged depends on the actual temperature of the battery pack
DELTA Max (2000) needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Customer Reviews
Based on 25 reviews
92%
(23)
8%
(2)
0%
(0)
0%
(0)
0%
(0)
A
Anonymous
I recently purchased the Ecoflow Delta Max Portable Power Station, and I am incredibly impressed with its performance. The battery life is excellent, and it can quickly charge all of my devices multiple times. The compact and lightweight design makes it easy to take on the go, and the multiple outlets and USB ports are very convenient. I also appreciate that it is eco-friendly and doesn't produce any emissions. Overall, I highly recommend the Ecoflow Delta Max to anyone needing a reliable and portable power source.
As a person from Ukraine, I would say it is a perfect fit for our situation with frequent power outages.
A
Anonymous
I'm from Ukraine, so it really helps my family now to survive and work remotely during constant blackouts.
2 KWh is enough to feed 2 laptops+Monitors, natural gas heat equipment, some lights, router, Starlink, and
occasionally microwave for 8-10h.
The passthrough function works also well, I use it as a really powerful UPS and sometimes don't realize moments when the electricity is on and off.
A recharge time of 1.5h helps to disturb neighbors by noisy Ecoflow generator work just for a small amount of time.
Above were pros
My contras -
- power surges protection system might be improved. I have to use an external voltage protector to get stable work when electricity puts on
- it's quite expensive
- there is no shipping to Ukraine, so I have to use outside agents' service which made it even more expensive
So the rate is 4
C
Customer
Die EcoFlow DELTA Max ist variabel einsetzbar und kann mit unterschiedlichen Stromquellen geladen werden!
In der App müsste noch die Temperaturanzeige von Fahrenheit in Celsius geändert werden.
A
Anonymous
I like it, but I would add the possibility to manage the settings directly on the device, therefore without a smartphone and to be able to recharge from the car alternator.
J
Julia B.
EcoFlow is a gamechanger! It makes using solar energy SUPER simple - they are portable and easy to use and great! Fully recommended!
A
Anonymous
Sehr gutes Produkt und ebenso guter Service und Kundenfreundlichkeit.
Ich habe jetzt 3x DELTA max (2000) im Einsatz und bin sehr zufrieden.
