EcoFlow PowerStream Balcony Solar System 600W/800W -200W Flexible Sola – EcoFlow Europe EcoFlow PowerStream Balcony Solar System 600W/800W -200W Flexible Sola - Incl. VAT / PowerStream 800 W / 200W Flexible Solar Panel (4 pieces) - EcoFlow Europe
EcoFlow Europe
EcoFlow PowerStream Balcony Solar System 600W/800W -200W Flexible Solar Panel
€739,00
EcoFlow 2025 Members' Festival 🎉
Regular price €739,00
Sale price €739,00 Regular price €897,00
Save up to €437
Apply member-only code [EFMember5off] at checkout for 5% off. Log in
Tax excluded.
  • 4.5 kg ultra-light solar panel, bends up to 213 degrees, perfect for most balconies.
  • Built to last, with an IP67 waterproof rating, unfazed by storms.
  • 23% solar conversion efficiency, maximising solar energy harness.
  • Simplified installation with pre-cut eyelets.
  • Effortlessly connect to your power systems with universal compatibility
  • Upgrade PowerStream 600W to 800W for free.
VAT
Micro Invertor
Number
€739,00 €897,00 -€158,00
Creative your balcony power station with EcoFlow PowerStream
Learn More
Power your balcony solar system
Fixed balcony installation with EcoFlow PowerStream
With EcoFlow PowerStream and an EcoFlow Portable Power Station, make a cost-efficient, sustainable home energy solution and power your home at all times.
Light and flexible
Only 4.5 kg and Bends to Fit Curved Edges
Exceptionally light and 70% lighter than traditional solar panels, making it convenient to move or mount. Easily flexes up to 213 degrees and is able to fit the unique shape of your balcony without affecting solar input.
Durable and waterproof, steadfast through any weather
Coated with Advanced Glass Fiber with an IP67 Waterproof Rating
With a protective ETFE film, the panel's solar cells can withstand many environments, while protecting the panel and enhancing performance. Use it year-round on your balcony without worry.
Charge faster with a high solar conversion
Made from Highly Efficient Monocrystalline Cells
Excellent efficiency rating of up to 23%. Charge faster with a more compact panel.
Installation flexible
Œillets prédécoupés pour installer nos panneaux n’importe où
Grâce aux œillets prédécoupés, le panneau solaire flexible peut être suspendu à l’aide de crochets ou fixé solidement sur une surface à l'aide de colle pour une installation stable sur votre balcon.
200W Flexible Solar Panel × 2
Solar Parallel Connection Cable × 2
Metal Zip Tie × 8
Metal Zip Tie × 8
Self-Fastening Strap × 4
Safety Instructions
Safety Instructions
EcoFlow PowerStream Microinverter
BKW-AC Cable
BKW-AC Cable
BKW-Solar Cable
BKW-Solar Cable
Specs of 200W Flexible Solar Panel
4.5kg
1083 x 1104 x 2.5 mm
Cell Type
Monocrystalline Silicon
Efficiency
23%
Waterproof & Dustproof
IP67
Rated Power
200W(TOL±5%)
Open Circuit Voltage
49.2V(TOL+/-5%)
Short Circuit Current
5.1A(TOL+/-5%)
-0.45%/C
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
Certification
CE, FCC, TUV, RoHS, REACH
12 Months
Specs of Microinvertor
Dimension
242*169*33 (mm)
Weight
Approximately 3 kg
PV Input Power
400 W x 2
DC Input Output
600W
Max. Input Voltage
55Vd.c. (PV Port)/ 59Vd.c. (DC Port)
Maximum input current
13 A
AC Output-Grid Tied
800W/600W
Max. AC Output Current
3.7A/2.8A
Max. Charging & Discharging Power
600W
Charging Voltage
30 - 58 Vd.c.
Ingress Protection rating
IP67
Wi-Fi (2.4G)
Frequency range: 20M: 2412 - 2472 MHz / 40M: 2422- 2462 MHz
Maximum output power: ≤ 20 dBm
Bluetooth®
Frequency range: 2402-2480MHz
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
