With ultra-fast charging, you'll always be ready for the next getaway or sudden power outage. Charge 0-100% using an AC outlet in only 70 min. It's five times faster than the industry norm and 27% faster than the previous generation.
Safe and reliable for 10 years of use.
With over 3000+ battery 100% cycles, you can use RIVER 2 Pro almost every day for pretty much ten years. LFP battery chemistry doesn't just offer long life. It's more reliable, efficient and safe even in high temperatures. RIVER 2 Pro has one of the longest warranties in the industry, so we've got you protected for the next 5 years.
With four versatile charging options, we've made sure you can charge RIVER 2 Pro pretty much anywhere you are. Charge using an AC outlet for ultra-fast 70 minute charging, charge on the go with car charging, and go off-grid or green with fast solar charging. RIVER 2 Pro has an all-new charging option, USB-C. Plug in and conveniently charge anywhere that has an outlet.
With a 800W output, RIVER 2 Pro has most of your essentials covered. But why not take power to another level with X-Boost mode? Turn it on to power appliances with an output of up to 1600W, including the coffee machine and hair dryer.
With a lightweight of only 7.8kg and an easy to carry design, RIVER 2 Pro makes on-the-go power plain-sailing.
Prepare your appliances for unexpected outages. With a fast 30ms switch-over speed, RIVER 2 Pro keeps your must-have-power appliances running.
Use the EcoFlow app to control and monitor RIVER 2 Pro from the convenience of your phone. Connect using Wi-Fi or Bluetooth to use nearby or remotely.
Customer reviews
5 star
4 star
3 star
2 star
1 star
Power. Never Been This Easy
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes. That’s 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you’ll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That’s pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
AC Charging | Car Charging | Solar Charging | USB-C Charging |
The most easy-to-use independent solar power system. Take it to camping, RV trips, or run your home essentials with it. Whether you are on the go or chilling at home, have stable, durable, and reliable energy on hand whenever you need. Join hands with us in this energy-sharing world and live green.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential home appliances smoothly for almost half a day. Sudden power outages? You'll always be ready.
Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 284kg. That's like planting 16 trees in a year!*
Up to 23% Solar Conversion | Faster Solar Charging 0-100% in 4.5-9 hr | IP68 Waterproof |
Easily Plug & Unplug | 10 Years of Use | Long-term Saving |
IP68 Waterproof | Easily Plug & Unplug |
X-Boost Up to 1600W
Small size. Big power.
RIVER 2 Pro has an AC output of up to 800W. Need to power a hair dryer, microwave or electric kettle? Crank it up to 1600W with X-Boost mode to run up to 80% of high-wattage home appliances.
Lightweight at only 7.8 kg
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for overnight outages to keep essentials running from a light to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Learn More >
Power. Anywhere. Anytime.
1. RIVER 2 Pro2. AC Charging Cable3. Car Charging Cable4. DC5521 Connection Cable5. Quick Start Guide
768Wh
Approximately 7.8kg
270 x 260 x 226mm
AC Input
220-240V~ 50Hz/60Hz, 940W Max
Solar Input
11-50V 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 800W total (surge 1600W), 230V ~ 50Hz/60Hz
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)
Car Input
12V/24V, 8A, 100W Max
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
